    Calendar has stopped working
    23 Posts 2 Posters 6.6k Views 2 Watching
      sdetweil @Jonsar
      @Jonsar said in Calendar has stopped working:
      Sorry. I can with the html version
      what does that mean? does it download the ics file or not?
      not view the cal in the web,… that is the embedded version, we need the raw data…
        sdetweil @Jonsar
        @Jonsar ok, lets turn on debugging
        change config.js
        logLevel: ["INFO", "LOG", "WARN", "ERROR"],
        to
        logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
        then start mm like this
        cd ~/MagicMirror
        npm  start >somefile.txt 2>&1
        wait til the error,
        ctrl-q to stop MM
        then edit the somefile.txt
        error should be at the bottom
          Jonsar @sdetweil
          @sdetweil Thanks for all your help.
          These are the last 4 or so entries. It seems that it’s trying to pick up entries from 2021 and then comes across an old entry that it can’t parse.
          {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E0080000000093B227D5977DD701000000000000000010000000E1C248455EE3E241BFC9D2FBFB730A57”,“summary”:“Materials Due - MunichRe - Speaking & Writing Communication Skills”,“start”:$
          [18.09.2022 22:22.12.572] [DEBUG] start: Tue Sep 21 2021 09:00:00 GMT-0400 (Eastern Daylight Time)
          [18.09.2022 22:22.12.573] [DEBUG] end:: Tue Sep 21 2021 09:30:00 GMT-0400 (Eastern Daylight Time)
          [18.09.2022 22:22.12.573] [DEBUG] duration: 1800000
          [18.09.2022 22:22.12.573] [DEBUG] title: Materials Due - MunichRe - Speaking & Writing Communication Skills
          [18.09.2022 22:22.12.574] [DEBUG] Processing entry…
          [18.09.2022 22:22.12.574] [DEBUG] Event:
          {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E00800000000EBF569C6329CD7010000000000000000100000007A6D0A4DBF5A8C43863B8DBA1D58CFC5”,“summary”:“DIANA - Calendly”,“start”:“2021-09-21T17:30:00.000Z”,“datetype”:“date-time”,$
          [18.09.2022 22:22.12.575] [DEBUG] start: Tue Sep 21 2021 13:30:00 GMT-0400 (Eastern Daylight Time)
          [18.09.2022 22:22.12.575] [DEBUG] end:: Tue Sep 21 2021 15:00:00 GMT-0400 (Eastern Daylight Time)
          [18.09.2022 22:22.12.576] [DEBUG] duration: 5400000
          [18.09.2022 22:22.12.576] [DEBUG] title: DIANA - Calendly
          [18.09.2022 22:22.12.577] [DEBUG] Processing entry…
          [18.09.2022 22:22.12.577] [DEBUG] Event:
          {“type”:“VEVENT”,“params”:[],“rrule”:{“_cache”:{“all”:false,“before”:[],“after”:[],“between”:[]},“origOptions”:{“tzid”:“undefined”,“dtstart”:“2021-09-21T22:30:00.000Z”,“freq”:2,“until”:“2021-11-23T23:30:00.000Z”,“interval”:1,“byweekday”:$
          [18.09.2022 22:22.12.578] [DEBUG] start: Tue Sep 21 2021 18:30:00 GMT-0400 (Eastern Daylight Time)
          [18.09.2022 22:22.12.578] [DEBUG] end:: Tue Sep 21 2021 21:30:00 GMT-0400 (Eastern Daylight Time)
          [18.09.2022 22:22.12.579] [DEBUG] duration: 10800000
          [18.09.2022 22:22.12.579] [DEBUG] title: Sarah ASL 1C (Units 7-9)
          [18.09.2022 22:22.12.580] [DEBUG] Search for recurring events between: Sun Sep 18 2022 22:22:12 GMT-0400 (Eastern Daylight Time) and Sun Sep 17 2023 23:59:59 GMT-0400 (Eastern Daylight Time)
          [18.09.2022 22:22.12.598] [DEBUG] Title: Sarah ASL 1C (Units 7-9), with dates: [null,null,null,null,null,null,null,null,null,null]
          [18.09.2022 22:22.12.598] [DEBUG] event.recurrences: [object Object]
          [18.09.2022 22:22.12.604] [ERROR] Calendar Error. Could not fetch calendar: https://outlook.office365.com/owa/calendar/4d70fc7a1bf94d5ab75018902050b8f9@tssg.ca/34612ac6511e4af9824700a66f879c90976 RangeError:$
          at Date.toISOString (:null:null)
          at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
          at Array.forEach (:null:null)
          at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
          at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
          at processTicksAndRejections (node:internal/process/task_queues:96:5)
            sdetweil @Jonsar
            hm… i fixed that problem last year…
              Jonsar @sdetweil
              @sdetweil Your help is greatly appreciated. It really is a great feature we constantly use for the family to keep everyone informed. If you can suggest a fix, that would be awesome.
                sdetweil @Jonsar
                @Jonsar looking at it… no idea yet
                  sdetweil @Jonsar
                  @Jonsar ok, fun time… MS screws us again
                  they changed the format of the timezone reporting…lovely
                  not our code, but the calendar parser we use (that I fixed the last 2 times)
                  workaround
                  cd ~/MagicMirror/node_modules/node-ical
                  nano ical.js , scroll down to line 120
                  delete the whole line and paste in the new one (cursor has to be on that line to paste it there)
                  change this (line 120 is the code, 119 is the comment)
                    // If this is the custom timezone from MS Outlook
                    if (tz === 'tzone://Microsoft/Custom' ) {
                  to this
                    if (tz === 'tzone://Microsoft/Custom' || tz === 'Customized Time Zone' || tz.startsWith('tzone://Microsoft/')) {
                  also need to fix our code
                  cd ~/MagicMirror/modules/default/calendar
                  nano calendarutils.js
                  change this , line 518
                  	getIanaTZFromMS: function (msTZName) {
                  		// Get hash entry
                  to this
                  		if(msTZName ==='Customized Time Zone'){
                  			return moment.tz.guess()
                  		// Get hash entry
                  J S 2 Replies Last reply Reply Quote 0
                    Jonsar @sdetweil
                    @sdetweil said in Calendar has stopped working:
                    Thanks for this. It didn’t exactly work. It definitely got further than before but I ended up with this error.
                    Invalid time value
                      sdetweil @Jonsar
                      @Jonsar can u show me the cal event data in the logs right before the error?
                        || tz === ‘Customized Time Zone’
                        I see there were two place in ical.js
                        and there is a timezone like this
                        ‘Customized Time Zone 1’
                        so this will fail
                        change to this
                         tz.startsWith('Customized Time Zone')
                        in all three places … 2 in node ical.j one in caldendarutils.js
                        • 2 / 3
