    Calendar has stopped working
    23 Posts 2 Posters 7.9k Views 2 Watching
      sdetweil @Jonsar
      @Jonsar ok, lets turn on debugging
      change config.js
      logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      to
      logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
      then start mm like this
      npm  start >somefile.txt 2>&1
      wait til the error,
      ctrl-q to stop MM
      then edit the somefile.txt
      error should be at the bottom
        Jonsar @sdetweil
        @sdetweil Thanks for all your help.
        These are the last 4 or so entries. It seems that it’s trying to pick up entries from 2021 and then comes across an old entry that it can’t parse.
        {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E0080000000093B227D5977DD701000000000000000010000000E1C248455EE3E241BFC9D2FBFB730A57”,“summary”:“Materials Due - MunichRe - Speaking & Writing Communication Skills”,“start”:$
        [18.09.2022 22:22.12.572] [DEBUG] start: Tue Sep 21 2021 09:00:00 GMT-0400 (Eastern Daylight Time)
        [18.09.2022 22:22.12.573] [DEBUG] end:: Tue Sep 21 2021 09:30:00 GMT-0400 (Eastern Daylight Time)
        [18.09.2022 22:22.12.573] [DEBUG] duration: 1800000
        [18.09.2022 22:22.12.573] [DEBUG] title: Materials Due - MunichRe - Speaking & Writing Communication Skills
        [18.09.2022 22:22.12.574] [DEBUG] Processing entry…
        [18.09.2022 22:22.12.574] [DEBUG] Event:
        {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E00800000000EBF569C6329CD7010000000000000000100000007A6D0A4DBF5A8C43863B8DBA1D58CFC5”,“summary”:“DIANA - Calendly”,“start”:“2021-09-21T17:30:00.000Z”,“datetype”:“date-time”,$
        [18.09.2022 22:22.12.575] [DEBUG] start: Tue Sep 21 2021 13:30:00 GMT-0400 (Eastern Daylight Time)
        [18.09.2022 22:22.12.575] [DEBUG] end:: Tue Sep 21 2021 15:00:00 GMT-0400 (Eastern Daylight Time)
        [18.09.2022 22:22.12.576] [DEBUG] duration: 5400000
        [18.09.2022 22:22.12.576] [DEBUG] title: DIANA - Calendly
        [18.09.2022 22:22.12.577] [DEBUG] Processing entry…
        [18.09.2022 22:22.12.577] [DEBUG] Event:
        {“type”:“VEVENT”,“params”:[],“rrule”:{“_cache”:{“all”:false,“before”:[],“after”:[],“between”:[]},“origOptions”:{“tzid”:“undefined”,“dtstart”:“2021-09-21T22:30:00.000Z”,“freq”:2,“until”:“2021-11-23T23:30:00.000Z”,“interval”:1,“byweekday”:$
        [18.09.2022 22:22.12.578] [DEBUG] start: Tue Sep 21 2021 18:30:00 GMT-0400 (Eastern Daylight Time)
        [18.09.2022 22:22.12.578] [DEBUG] end:: Tue Sep 21 2021 21:30:00 GMT-0400 (Eastern Daylight Time)
        [18.09.2022 22:22.12.579] [DEBUG] duration: 10800000
        [18.09.2022 22:22.12.579] [DEBUG] title: Sarah ASL 1C (Units 7-9)
        [18.09.2022 22:22.12.580] [DEBUG] Search for recurring events between: Sun Sep 18 2022 22:22:12 GMT-0400 (Eastern Daylight Time) and Sun Sep 17 2023 23:59:59 GMT-0400 (Eastern Daylight Time)
        [18.09.2022 22:22.12.598] [DEBUG] Title: Sarah ASL 1C (Units 7-9), with dates: [null,null,null,null,null,null,null,null,null,null]
        [18.09.2022 22:22.12.598] [DEBUG] event.recurrences: [object Object]
        [18.09.2022 22:22.12.604] [ERROR] Calendar Error. Could not fetch calendar: https://outlook.office365.com/owa/calendar/4d70fc7a1bf94d5ab75018902050b8f9@tssg.ca/34612ac6511e4af9824700a66f879c90976 RangeError:$
        at Date.toISOString (:null:null)
        at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
        at Array.forEach (:null:null)
        at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
        at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
        at processTicksAndRejections (node:internal/process/task_queues:96:5)
          sdetweil @Jonsar
          @Jonsar said in Calendar has stopped working:
          hm… i fixed that problem last year…
            Jonsar @sdetweil
            @sdetweil Your help is greatly appreciated. It really is a great feature we constantly use for the family to keep everyone informed. If you can suggest a fix, that would be awesome.
              sdetweil @Jonsar
              @Jonsar looking at it… no idea yet
                sdetweil @Jonsar
                @Jonsar ok, fun time… MS screws us again
                they changed the format of the timezone reporting…lovely
                not our code, but the calendar parser we use (that I fixed the last 2 times)
                workaround
                cd ~/MagicMirror/node_modules/node-ical
                nano ical.js , scroll down to line 120
                delete the whole line and paste in the new one (cursor has to be on that line to paste it there)
                change this (line 120 is the code, 119 is the comment)
                  // If this is the custom timezone from MS Outlook
                  if (tz === 'tzone://Microsoft/Custom' ) {
                to this
                  if (tz === 'tzone://Microsoft/Custom' || tz === 'Customized Time Zone' || tz.startsWith('tzone://Microsoft/')) {
                also need to fix our code
                cd ~/MagicMirror/modules/default/calendar
                nano calendarutils.js
                change this , line 518
                	getIanaTZFromMS: function (msTZName) {
                		// Get hash entry
                to this
                		if(msTZName ==='Customized Time Zone'){
                			return moment.tz.guess()
                		// Get hash entry
                J S 2 Replies Last reply Reply Quote 0
                  Jonsar @sdetweil
                  @sdetweil said in Calendar has stopped working:
                  Thanks for this. It didn’t exactly work. It definitely got further than before but I ended up with this error.
                  Invalid time value
                    sdetweil @Jonsar
                    @Jonsar can u show me the cal event data in the logs right before the error?
                      || tz === ‘Customized Time Zone’
                      I see there were two place in ical.js
                      and there is a timezone like this
                      ‘Customized Time Zone 1’
                      so this will fail
                      change to this
                       tz.startsWith('Customized Time Zone')
                      in all three places … 2 in node ical.j one in caldendarutils.js
                        Jonsar @sdetweil
                        @sdetweil Thank you, but I can only find 1 place in ical.js. There is one place in calendarutils.js but it is:
                        if(msTZName === ‘Customized Time Zone’){
                        The whole error I get is:
                        [19.09.2022 21:46.41.439] [DEBUG] Search for recurring events between: Mon Sep 19 2022 21:46:41 GMT-0400 (Eastern Daylight Time) and Mon Sep 18 2023 23:59:59 GMT-0400 (Eastern Daylight Time)
                        [19.09.2022 21:46.41.441] [DEBUG] Title: Tentative: XX, with dates: [null,null]
                        [19.09.2022 21:46.41.442] [DEBUG] event.recurrences: [object Object]
                        [19.09.2022 21:46.41.449] [ERROR] Calendar Error. Could not fetch calendar: https://outlook.office365.com/owa/calendar/4d70fc7a1bf94d5ab75018902050b8f9@tssg.ca/XXXXXXcalendar.ics RangeError: Invalid time value
                          sdetweil @Jonsar
                          yes, I said above that there were actually 2… in ical.js
                          and to make the second look like the 1st
                          yes, in calendarutils, 1, which I gave instructions to change
                          if(msTZName.startsWith(‘Customized Time Zone’){
                            Jonsar @sdetweil
                            @sdetweil Sorry, I missed the second one in ical.js. It works now! Thanks so much for your help.
