    Calendar has stopped working
    23 Posts 2 Posters 6.8k Views 2 Watching
      Jonsar @sdetweil
      @sdetweil Sorry. I can with the html version. The error I get now is this:
      RangeError: Invalid time value
      at Date.toISOString (:null:null)
      at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
      at Array.forEach (:null:null)
      at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
      at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
      at processTicksAndRejections (node:internal/process/task_queues:96:5)
        sdetweil @Jonsar
        @Jonsar said in Calendar has stopped working:
        what does that mean? does it download the ics file or not?
        not view the cal in the web,… that is the embedded version, we need the raw data…
          sdetweil @Jonsar
          @Jonsar ok, lets turn on debugging
          change config.js
          logLevel: ["INFO", "LOG", "WARN", "ERROR"],
          to
          logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
          then start mm like this
          npm  start >somefile.txt 2>&1
          wait til the error,
          ctrl-q to stop MM
          then edit the somefile.txt
          error should be at the bottom
            Jonsar @sdetweil
            @sdetweil Thanks for all your help.
            These are the last 4 or so entries. It seems that it’s trying to pick up entries from 2021 and then comes across an old entry that it can’t parse.
            {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E0080000000093B227D5977DD701000000000000000010000000E1C248455EE3E241BFC9D2FBFB730A57”,“summary”:“Materials Due - MunichRe - Speaking & Writing Communication Skills”,“start”:$
            [18.09.2022 22:22.12.572] [DEBUG] start: Tue Sep 21 2021 09:00:00 GMT-0400 (Eastern Daylight Time)
            [18.09.2022 22:22.12.573] [DEBUG] end:: Tue Sep 21 2021 09:30:00 GMT-0400 (Eastern Daylight Time)
            [18.09.2022 22:22.12.573] [DEBUG] duration: 1800000
            [18.09.2022 22:22.12.573] [DEBUG] title: Materials Due - MunichRe - Speaking & Writing Communication Skills
            [18.09.2022 22:22.12.574] [DEBUG] Processing entry…
            [18.09.2022 22:22.12.574] [DEBUG] Event:
            {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E00800000000EBF569C6329CD7010000000000000000100000007A6D0A4DBF5A8C43863B8DBA1D58CFC5”,“summary”:“DIANA - Calendly”,“start”:“2021-09-21T17:30:00.000Z”,“datetype”:“date-time”,$
            [18.09.2022 22:22.12.575] [DEBUG] start: Tue Sep 21 2021 13:30:00 GMT-0400 (Eastern Daylight Time)
            [18.09.2022 22:22.12.575] [DEBUG] end:: Tue Sep 21 2021 15:00:00 GMT-0400 (Eastern Daylight Time)
            [18.09.2022 22:22.12.576] [DEBUG] duration: 5400000
            [18.09.2022 22:22.12.576] [DEBUG] title: DIANA - Calendly
            [18.09.2022 22:22.12.577] [DEBUG] Processing entry…
            [18.09.2022 22:22.12.577] [DEBUG] Event:
            {“type”:“VEVENT”,“params”:[],“rrule”:{“_cache”:{“all”:false,“before”:[],“after”:[],“between”:[]},“origOptions”:{“tzid”:“undefined”,“dtstart”:“2021-09-21T22:30:00.000Z”,“freq”:2,“until”:“2021-11-23T23:30:00.000Z”,“interval”:1,“byweekday”:$
            [18.09.2022 22:22.12.578] [DEBUG] start: Tue Sep 21 2021 18:30:00 GMT-0400 (Eastern Daylight Time)
            [18.09.2022 22:22.12.578] [DEBUG] end:: Tue Sep 21 2021 21:30:00 GMT-0400 (Eastern Daylight Time)
            [18.09.2022 22:22.12.579] [DEBUG] duration: 10800000
            [18.09.2022 22:22.12.579] [DEBUG] title: Sarah ASL 1C (Units 7-9)
            [18.09.2022 22:22.12.580] [DEBUG] Search for recurring events between: Sun Sep 18 2022 22:22:12 GMT-0400 (Eastern Daylight Time) and Sun Sep 17 2023 23:59:59 GMT-0400 (Eastern Daylight Time)
            [18.09.2022 22:22.12.598] [DEBUG] Title: Sarah ASL 1C (Units 7-9), with dates: [null,null,null,null,null,null,null,null,null,null]
            [18.09.2022 22:22.12.598] [DEBUG] event.recurrences: [object Object]
            [18.09.2022 22:22.12.604] [ERROR] Calendar Error. Could not fetch calendar: https://outlook.office365.com/owa/calendar/4d70fc7a1bf94d5ab75018902050b8f9@tssg.ca/34612ac6511e4af9824700a66f879c90976 RangeError:$
              sdetweil @Jonsar
              hm… i fixed that problem last year…
                Jonsar @sdetweil
                @sdetweil Your help is greatly appreciated. It really is a great feature we constantly use for the family to keep everyone informed. If you can suggest a fix, that would be awesome.
                  sdetweil @Jonsar
                  @Jonsar looking at it… no idea yet
                    sdetweil @Jonsar
                    @Jonsar ok, fun time… MS screws us again
                    they changed the format of the timezone reporting…lovely
                    not our code, but the calendar parser we use (that I fixed the last 2 times)
                    workaround
                    cd ~/MagicMirror/node_modules/node-ical
                    nano ical.js , scroll down to line 120
                    delete the whole line and paste in the new one (cursor has to be on that line to paste it there)
                    change this (line 120 is the code, 119 is the comment)
                      // If this is the custom timezone from MS Outlook
                      if (tz === 'tzone://Microsoft/Custom' ) {
                    to this
                      if (tz === 'tzone://Microsoft/Custom' || tz === 'Customized Time Zone' || tz.startsWith('tzone://Microsoft/')) {
                    also need to fix our code
                    cd ~/MagicMirror/modules/default/calendar
                    nano calendarutils.js
                    change this , line 518
                    	getIanaTZFromMS: function (msTZName) {
                    		// Get hash entry
                    to this
                    		if(msTZName ==='Customized Time Zone'){
                    			return moment.tz.guess()
                    		// Get hash entry
                    J S 2 Replies Last reply Reply Quote 0
                      Jonsar @sdetweil
                      @sdetweil said in Calendar has stopped working:
                      Thanks for this. It didn’t exactly work. It definitely got further than before but I ended up with this error.
                      Invalid time value
                        sdetweil @Jonsar
                        @Jonsar can u show me the cal event data in the logs right before the error?
                          || tz === ‘Customized Time Zone’
                          I see there were two place in ical.js
                          and there is a timezone like this
                          ‘Customized Time Zone 1’
                          so this will fail
                          change to this
                           tz.startsWith('Customized Time Zone')
                          in all three places … 2 in node ical.j one in caldendarutils.js
                            Jonsar @sdetweil
                            @sdetweil Thank you, but I can only find 1 place in ical.js. There is one place in calendarutils.js but it is:
                            if(msTZName === ‘Customized Time Zone’){
                            The whole error I get is:
                            [19.09.2022 21:46.41.439] [DEBUG] Search for recurring events between: Mon Sep 19 2022 21:46:41 GMT-0400 (Eastern Daylight Time) and Mon Sep 18 2023 23:59:59 GMT-0400 (Eastern Daylight Time)
                            [19.09.2022 21:46.41.441] [DEBUG] Title: Tentative: XX, with dates: [null,null]
                            [19.09.2022 21:46.41.442] [DEBUG] event.recurrences: [object Object]
                            [19.09.2022 21:46.41.449] [ERROR] Calendar Error. Could not fetch calendar: https://outlook.office365.com/owa/calendar/4d70fc7a1bf94d5ab75018902050b8f9@tssg.ca/XXXXXXcalendar.ics RangeError: Invalid time value
                              sdetweil @Jonsar
                              yes, I said above that there were actually 2… in ical.js
                              and to make the second look like the 1st
                              yes, in calendarutils, 1, which I gave instructions to change
                              if(msTZName.startsWith(‘Customized Time Zone’){
                                Jonsar @sdetweil
                                @sdetweil Sorry, I missed the second one in ical.js. It works now! Thanks so much for your help.
