    Calendar has stopped working
    23 Posts 2 Posters 6.6k Views 2 Watching
      Jonsar
      I followed the posted instructions
        sdetweil @Jonsar
        @Jonsar so, did the git pull succeed?
        do a
        git status
        in the MagicMirror folder
        and
        grep version package.json
          Jonsar @sdetweil
          @sdetweil I reinstalled and I am up to date. The error I get now is could not fetch calendar Error: forbidden. at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
          at processTicksAndRejections (node:internal/process/task_queues:96:5)
            sdetweil @Jonsar
            @Jonsar if u put the url in a browser, does it download the ics file?
            there was a forced change to the Google urls for calendars a while back
              Jonsar @sdetweil
              @sdetweil No, it doesn’t. It gets stuck on Preparing to download. Is there a workaround?
              Found this somewhere. Does it help?
              Bottom line was that the following lines needed to be added into the request.
              myHttpWebRequestOutlook.UserAgent = “SmileCRM”;
              myHttpWebRequestOutlook.AuthenticationLevel =System.Net.Security.AuthenticationLevel.None;
                sdetweil @Jonsar
                @Jonsar if u can’t download in a normal browser we can’t get it either.
                  Jonsar @sdetweil
                  @sdetweil Sorry. I can with the html version. The error I get now is this:
                  RangeError: Invalid time value
                  at Date.toISOString (:null:null)
                  at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
                  at Array.forEach (:null:null)
                  at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
                  at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
                    sdetweil @Jonsar
                    @Jonsar said in Calendar has stopped working:
                    what does that mean? does it download the ics file or not?
                    not view the cal in the web,… that is the embedded version, we need the raw data…
                      sdetweil @Jonsar
                      @Jonsar ok, lets turn on debugging
                      change config.js
                      logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                      to
                      logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
                      then start mm like this
                      npm  start >somefile.txt 2>&1
                      wait til the error,
                      ctrl-q to stop MM
                      then edit the somefile.txt
                      error should be at the bottom
                        Jonsar @sdetweil
                        @sdetweil Thanks for all your help.
                        These are the last 4 or so entries. It seems that it’s trying to pick up entries from 2021 and then comes across an old entry that it can’t parse.
                        {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E0080000000093B227D5977DD701000000000000000010000000E1C248455EE3E241BFC9D2FBFB730A57”,“summary”:“Materials Due - MunichRe - Speaking & Writing Communication Skills”,“start”:$
                        [18.09.2022 22:22.12.572] [DEBUG] start: Tue Sep 21 2021 09:00:00 GMT-0400 (Eastern Daylight Time)
                        [18.09.2022 22:22.12.573] [DEBUG] end:: Tue Sep 21 2021 09:30:00 GMT-0400 (Eastern Daylight Time)
                        [18.09.2022 22:22.12.573] [DEBUG] duration: 1800000
                        [18.09.2022 22:22.12.573] [DEBUG] title: Materials Due - MunichRe - Speaking & Writing Communication Skills
                        [18.09.2022 22:22.12.574] [DEBUG] Processing entry…
                        [18.09.2022 22:22.12.574] [DEBUG] Event:
                        {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E00800000000EBF569C6329CD7010000000000000000100000007A6D0A4DBF5A8C43863B8DBA1D58CFC5”,“summary”:“DIANA - Calendly”,“start”:“2021-09-21T17:30:00.000Z”,“datetype”:“date-time”,$
                        [18.09.2022 22:22.12.575] [DEBUG] start: Tue Sep 21 2021 13:30:00 GMT-0400 (Eastern Daylight Time)
                        [18.09.2022 22:22.12.575] [DEBUG] end:: Tue Sep 21 2021 15:00:00 GMT-0400 (Eastern Daylight Time)
                        [18.09.2022 22:22.12.576] [DEBUG] duration: 5400000
                        [18.09.2022 22:22.12.576] [DEBUG] title: DIANA - Calendly
                        [18.09.2022 22:22.12.577] [DEBUG] Processing entry…
                        [18.09.2022 22:22.12.577] [DEBUG] Event:
                        {“type”:“VEVENT”,“params”:[],“rrule”:{“_cache”:{“all”:false,“before”:[],“after”:[],“between”:[]},“origOptions”:{“tzid”:“undefined”,“dtstart”:“2021-09-21T22:30:00.000Z”,“freq”:2,“until”:“2021-11-23T23:30:00.000Z”,“interval”:1,“byweekday”:$
                        [18.09.2022 22:22.12.578] [DEBUG] start: Tue Sep 21 2021 18:30:00 GMT-0400 (Eastern Daylight Time)
                        [18.09.2022 22:22.12.578] [DEBUG] end:: Tue Sep 21 2021 21:30:00 GMT-0400 (Eastern Daylight Time)
                        [18.09.2022 22:22.12.579] [DEBUG] duration: 10800000
                        [18.09.2022 22:22.12.579] [DEBUG] title: Sarah ASL 1C (Units 7-9)
                        [18.09.2022 22:22.12.580] [DEBUG] Search for recurring events between: Sun Sep 18 2022 22:22:12 GMT-0400 (Eastern Daylight Time) and Sun Sep 17 2023 23:59:59 GMT-0400 (Eastern Daylight Time)
                        [18.09.2022 22:22.12.598] [DEBUG] Title: Sarah ASL 1C (Units 7-9), with dates: [null,null,null,null,null,null,null,null,null,null]
                        [18.09.2022 22:22.12.598] [DEBUG] event.recurrences: [object Object]
                        [18.09.2022 22:22.12.604] [ERROR] Calendar Error. Could not fetch calendar: https://outlook.office365.com/owa/calendar/4d70fc7a1bf94d5ab75018902050b8f9@tssg.ca/34612ac6511e4af9824700a66f879c90976 RangeError:$
