    Calendar has stopped working
    23 Posts 2 Posters 7.9k Views 2 Watching
      Jonsar @sdetweil
      @sdetweil No, it doesn’t. It gets stuck on Preparing to download. Is there a workaround?
      Found this somewhere. Does it help?
      Bottom line was that the following lines needed to be added into the request.
      myHttpWebRequestOutlook.UserAgent = “SmileCRM”;
      myHttpWebRequestOutlook.AuthenticationLevel =System.Net.Security.AuthenticationLevel.None;
        sdetweil @Jonsar
        @Jonsar if u can’t download in a normal browser we can’t get it either.
          Jonsar @sdetweil
          @sdetweil Sorry. I can with the html version. The error I get now is this:
          RangeError: Invalid time value
          at Date.toISOString (:null:null)
          at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
          at Array.forEach (:null:null)
          at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
          at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
          at processTicksAndRejections (node:internal/process/task_queues:96:5)
            sdetweil @Jonsar
            @Jonsar said in Calendar has stopped working:
            what does that mean? does it download the ics file or not?
            not view the cal in the web,… that is the embedded version, we need the raw data…
              sdetweil @Jonsar
              @Jonsar ok, lets turn on debugging
              change config.js
              logLevel: ["INFO", "LOG", "WARN", "ERROR"],
              to
              logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
              then start mm like this
              npm  start >somefile.txt 2>&1
              wait til the error,
              ctrl-q to stop MM
              then edit the somefile.txt
              error should be at the bottom
                Jonsar @sdetweil
                @sdetweil Thanks for all your help.
                These are the last 4 or so entries. It seems that it’s trying to pick up entries from 2021 and then comes across an old entry that it can’t parse.
                {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E0080000000093B227D5977DD701000000000000000010000000E1C248455EE3E241BFC9D2FBFB730A57”,“summary”:“Materials Due - MunichRe - Speaking & Writing Communication Skills”,“start”:$
                [18.09.2022 22:22.12.572] [DEBUG] start: Tue Sep 21 2021 09:00:00 GMT-0400 (Eastern Daylight Time)
                [18.09.2022 22:22.12.573] [DEBUG] end:: Tue Sep 21 2021 09:30:00 GMT-0400 (Eastern Daylight Time)
                [18.09.2022 22:22.12.573] [DEBUG] duration: 1800000
                [18.09.2022 22:22.12.573] [DEBUG] title: Materials Due - MunichRe - Speaking & Writing Communication Skills
                [18.09.2022 22:22.12.574] [DEBUG] Processing entry…
                [18.09.2022 22:22.12.574] [DEBUG] Event:
                {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E00800000000EBF569C6329CD7010000000000000000100000007A6D0A4DBF5A8C43863B8DBA1D58CFC5”,“summary”:“DIANA - Calendly”,“start”:“2021-09-21T17:30:00.000Z”,“datetype”:“date-time”,$
                [18.09.2022 22:22.12.575] [DEBUG] start: Tue Sep 21 2021 13:30:00 GMT-0400 (Eastern Daylight Time)
                [18.09.2022 22:22.12.575] [DEBUG] end:: Tue Sep 21 2021 15:00:00 GMT-0400 (Eastern Daylight Time)
                [18.09.2022 22:22.12.576] [DEBUG] duration: 5400000
                [18.09.2022 22:22.12.576] [DEBUG] title: DIANA - Calendly
                [18.09.2022 22:22.12.577] [DEBUG] Processing entry…
                [18.09.2022 22:22.12.577] [DEBUG] Event:
                {“type”:“VEVENT”,“params”:[],“rrule”:{“_cache”:{“all”:false,“before”:[],“after”:[],“between”:[]},“origOptions”:{“tzid”:“undefined”,“dtstart”:“2021-09-21T22:30:00.000Z”,“freq”:2,“until”:“2021-11-23T23:30:00.000Z”,“interval”:1,“byweekday”:$
                [18.09.2022 22:22.12.578] [DEBUG] start: Tue Sep 21 2021 18:30:00 GMT-0400 (Eastern Daylight Time)
                [18.09.2022 22:22.12.578] [DEBUG] end:: Tue Sep 21 2021 21:30:00 GMT-0400 (Eastern Daylight Time)
                [18.09.2022 22:22.12.579] [DEBUG] duration: 10800000
                [18.09.2022 22:22.12.579] [DEBUG] title: Sarah ASL 1C (Units 7-9)
                [18.09.2022 22:22.12.580] [DEBUG] Search for recurring events between: Sun Sep 18 2022 22:22:12 GMT-0400 (Eastern Daylight Time) and Sun Sep 17 2023 23:59:59 GMT-0400 (Eastern Daylight Time)
                [18.09.2022 22:22.12.598] [DEBUG] Title: Sarah ASL 1C (Units 7-9), with dates: [null,null,null,null,null,null,null,null,null,null]
                [18.09.2022 22:22.12.598] [DEBUG] event.recurrences: [object Object]
                [18.09.2022 22:22.12.604] [ERROR] Calendar Error. Could not fetch calendar: https://outlook.office365.com/owa/calendar/4d70fc7a1bf94d5ab75018902050b8f9@tssg.ca/34612ac6511e4af9824700a66f879c90976 RangeError:$
                  sdetweil @Jonsar
                  hm… i fixed that problem last year…
                    Jonsar @sdetweil
                    @sdetweil Your help is greatly appreciated. It really is a great feature we constantly use for the family to keep everyone informed. If you can suggest a fix, that would be awesome.
                      sdetweil @Jonsar
                      @Jonsar looking at it… no idea yet
                        sdetweil @Jonsar
                        @Jonsar ok, fun time… MS screws us again
                        they changed the format of the timezone reporting…lovely
                        not our code, but the calendar parser we use (that I fixed the last 2 times)
                        workaround
                        cd ~/MagicMirror/node_modules/node-ical
                        nano ical.js , scroll down to line 120
                        delete the whole line and paste in the new one (cursor has to be on that line to paste it there)
                        change this (line 120 is the code, 119 is the comment)
                          // If this is the custom timezone from MS Outlook
                          if (tz === 'tzone://Microsoft/Custom' ) {
                        to this
                          if (tz === 'tzone://Microsoft/Custom' || tz === 'Customized Time Zone' || tz.startsWith('tzone://Microsoft/')) {
                        also need to fix our code
                        cd ~/MagicMirror/modules/default/calendar
                        nano calendarutils.js
                        change this , line 518
                        	getIanaTZFromMS: function (msTZName) {
                        		// Get hash entry
                        to this
                        		if(msTZName ==='Customized Time Zone'){
                        			return moment.tz.guess()
                        		// Get hash entry
                        J S 2 Replies Last reply Reply Quote 0
                          Jonsar @sdetweil
                          @sdetweil said in Calendar has stopped working:
                          Thanks for this. It didn’t exactly work. It definitely got further than before but I ended up with this error.
                          Invalid time value
                            sdetweil @Jonsar
                            @Jonsar can u show me the cal event data in the logs right before the error?
                              || tz === ‘Customized Time Zone’
                              I see there were two place in ical.js
                              and there is a timezone like this
                              ‘Customized Time Zone 1’
                              so this will fail
                              change to this
                               tz.startsWith('Customized Time Zone')
                              in all three places … 2 in node ical.j one in caldendarutils.js
                                Jonsar @sdetweil
                                @sdetweil Thank you, but I can only find 1 place in ical.js. There is one place in calendarutils.js but it is:
                                if(msTZName === ‘Customized Time Zone’){
                                The whole error I get is:
                                [19.09.2022 21:46.41.439] [DEBUG] Search for recurring events between: Mon Sep 19 2022 21:46:41 GMT-0400 (Eastern Daylight Time) and Mon Sep 18 2023 23:59:59 GMT-0400 (Eastern Daylight Time)
                                [19.09.2022 21:46.41.441] [DEBUG] Title: Tentative: XX, with dates: [null,null]
                                [19.09.2022 21:46.41.442] [DEBUG] event.recurrences: [object Object]
                                [19.09.2022 21:46.41.449] [ERROR] Calendar Error. Could not fetch calendar: https://outlook.office365.com/owa/calendar/4d70fc7a1bf94d5ab75018902050b8f9@tssg.ca/XXXXXXcalendar.ics RangeError: Invalid time value
                                  sdetweil @Jonsar
                                  yes, I said above that there were actually 2… in ical.js
                                  and to make the second look like the 1st
                                  yes, in calendarutils, 1, which I gave instructions to change
                                  if(msTZName.startsWith(‘Customized Time Zone’){
                                    Jonsar @sdetweil
                                    @sdetweil Sorry, I missed the second one in ical.js. It works now! Thanks so much for your help.
