    MMM College top 25
    6 Posts 3 Posters 1.5k Views 3 Watching
      JGSteelerFan01
      Is anyone have tips or tricks to get this MMM to work? Any suggestions will be greatly appreciated. Thank you
        sdetweil @JGSteelerFan01
        @JGSteelerFan01 could you give more info?
          JGSteelerFan01 @sdetweil
          @sdetweil I guess I’m having trouble adding any Modules. The exact syntax is my challenge. I get the { and }, but not the [ or ]. I’ve made minor changes to the base defaults, but adding additional MM’s are a struggle. The code for MMM college top 25 looks intimidating. any help understanding the module coding would be helpful. I keep look at all the coding for patterns and/or similarities. thank you.
            @JGSteelerFan01 yes sometimes it’s a lot
            the list of module configuration definitions is
            [] means list/array
            {} means collection
                     module:...
                     position:...
                     config:  {
            what goes inside the config:{} collection for each module is unique to that module
            lists []
            can be numbers, strings, collections or other lists
            etc etc.
            blank lines are ok, extra commas are ok, lack of a comma is fatal!.. lol.
            get one of the ssh clients (winscp or bitvise) that provide file system access and u can edit on your windows machine with and editor like vscode or notepad++, which do brace{} and bracket[] matching
            always use indentation.
            see the two topics in my signature below, they will help.
            I didn’t write them…
            • W Offline
              Wenike @sdetweil
              @sdetweil And to add on to this because it can’t be said enough. You don’t make changes to any file within the module folder itself, you have a config.sys file in the root folder of your MagicMirror install and that config.sys is what is modified. The module’s readme would give you what different variables can be set for it to work how you want it to.
                sdetweil @Wenike
                @Wenike config/config.js
                not config.sys
                and not in the root of the MagicMirror folder
