    MMM-MonthlyCalendar, config and .css
    11 Posts 3 Posters 6.5k Views 3 Watching
    • B
      bicolorbore586
      Hi all,
      Do all modules conform to the same structure?
      The reason I ask… Currently using the default calendar, and ext3, it displays the event, along with a symbol and the text in a color associated with a persons name. I’ve recently found that mmm-monthlycalendar suits the layout of my magicmirror better, however the color isn’t copying across.
      I’ve tried eventTransformer: (ev) => in the config for monthlycalendar, along with the default calendars, I’ve tried to get my head around css but can’t figure it out.
        sdetweil @bicolorbore586
        @bicolorbore586 said in MMM-MonthlyCalendar, config and .css:
        physical layout, yes
        operational process, no
        CalExt/Ext2 read and parse the calendar themselves, in addition to default calendar doing that
        CalExt3/Ext3Agenda , take the info provided by default calendar (only download once and parse once)
        MMM-MonthlyCalendar, also takes what default calendar gives, but color is an Ext3 option for default cal entry
        css is
        .modulename .class/element... (css selector clause) {
              styles
        like this
        .MMM-MonthlyCalendar  ???? {
        I use this for the css selector clause
        https://www.w3schools.com/cssref/css_selectors.php
        here is how to use the developers window to locate the elements u want to style and
        get what would go in custom.css
        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1666112801123
        B 1 Reply Last reply
        • B
          bicolorbore586 @sdetweil
          @sdetweil Ok, so will using css (which at present, seems waaaaay beyond me, so much so that I’m considering giving up) mean that each time I add an event that is under “steve” it will be green? Even watching introduction to css youtube videos is turning out to be unproductive.
            so will using css … mean that each time I add an event that is under “steve” it will be green
            yes, if u select the right web page element and the method u select (css selector) is repeatable
            some modules provide config mechanisms to specify those (css) selectable items
            (in default cal, its symbolClass, titleClass and timeClass, for the 3 fields in the display)
            ‘YOU’ have to specify arbitrary made up names to be able to select them in css
            for example
            in default cal
                  module: "calendar"
                         titleClass:'foo'
            in css
            .calendar  .foo {
                  color:  green;
            this means, every time u find an element with class:“foo” inside the content with a class:“calendar” set the text color to green
            the . is because u are selecting (css selector clause) a CLASS
            this effects ONLY the title of the cal event row to green (because we are selecting the ‘titleClass’ to assign that effect to
            • F
              Fuergrissa
              I’m trying to work through the same issue. I have specified a titleClass in the calendars module, in the main.css I have:
              .family {
                   color: rgba(255,52,255,0.7);
              and this causes events in the calandar module to show as magenta, however in the fourweeks calendar (MMM_MonthlyCalendar) thet still appear in white.
              Does this imply that this module does not use the event title, but some other part of the event? or am I missing something? I also tried
              .MMM-MonthlyCalendar.family {
              S 3 Replies Last reply
                sdetweil @Fuergrissa
                @Fuergrissa never edit main.css it will stop upgrades. never edit any file we ship
                all your config for css goes in css/custom.css
                if it doesn’t exist create it
                  @Fuergrissa there needs to be spaces between the classes unless u mean they are in the same element
                    @Fuergrissa use the dev window link I posted to be able to see and fiddle w css live without file edit , try , no, edit, try, no loop
                    • F
                      Fuergrissa
                      Thanks I did all of the things you suggest. The developer pane is really handy, but when I drill all the way down to individual calendar events there is no difference in class for events coming from different calendars (which do have the titleClass assigned). Looking in MMM-MonthlyCalendar.js there is a section at the end that looks like it is intended to inherit the color information from the event, but this doesn’t actually happen?
                      if (e.color) {
                                  var c = e.color;
                                  if (e.fullDayEvent) {
                                    div.style.backgroundColor = c;
                                    if (getLuminance(div.style.backgroundColor) >= self.config.luminanceThreshold) {
                                      div.style.color = "black";
                                  } else {
                                    div.style.color = c;
                      S 2 Replies Last reply
                        @Fuergrissa don’t know this module’s workings
                          @Fuergrissa so it looks like this module gets it’s events from the base calendar
                          and if the base is not shown
                          anyhow, use multiple { url: …}
                          blocks in the based calendar add a name: attribute to each
                          that will carry forward on the event. I don’t know if this cal will use it
                          but then u could set styles for events by cal name
