    MMM-MonthlyCalendar, config and .css
    11 Posts 3 Posters 5.4k Views 3 Watching
      bicolorbore586 @sdetweil
      @sdetweil Ok, so will using css (which at present, seems waaaaay beyond me, so much so that I’m considering giving up) mean that each time I add an event that is under “steve” it will be green? Even watching introduction to css youtube videos is turning out to be unproductive.
        sdetweil @bicolorbore586
        @bicolorbore586 said in MMM-MonthlyCalendar, config and .css:
        so will using css … mean that each time I add an event that is under “steve” it will be green
        yes, if u select the right web page element and the method u select (css selector) is repeatable
        some modules provide config mechanisms to specify those (css) selectable items
        (in default cal, its symbolClass, titleClass and timeClass, for the 3 fields in the display)
        ‘YOU’ have to specify arbitrary made up names to be able to select them in css
        for example
        in default cal
              module: "calendar"
                     titleClass:'foo'
        in css
        .calendar  .foo {
              color:  green;
        this means, every time u find an element with class:“foo” inside the content with a class:“calendar” set the text color to green
        the . is because u are selecting (css selector clause) a CLASS
        this effects ONLY the title of the cal event row to green (because we are selecting the ‘titleClass’ to assign that effect to
        • F Offline
          Fuergrissa
          I’m trying to work through the same issue. I have specified a titleClass in the calendars module, in the main.css I have:
          .family {
               color: rgba(255,52,255,0.7);
          and this causes events in the calandar module to show as magenta, however in the fourweeks calendar (MMM_MonthlyCalendar) thet still appear in white.
          Does this imply that this module does not use the event title, but some other part of the event? or am I missing something? I also tried
          .MMM-MonthlyCalendar.family {
          S 3 Replies Last reply Reply Quote 0
            sdetweil @Fuergrissa
            @Fuergrissa never edit main.css it will stop upgrades. never edit any file we ship
            all your config for css goes in css/custom.css
            if it doesn’t exist create it
              @Fuergrissa there needs to be spaces between the classes unless u mean they are in the same element
                @Fuergrissa use the dev window link I posted to be able to see and fiddle w css live without file edit , try , no, edit, try, no loop
                • F Offline
                  Fuergrissa
                  Thanks I did all of the things you suggest. The developer pane is really handy, but when I drill all the way down to individual calendar events there is no difference in class for events coming from different calendars (which do have the titleClass assigned). Looking in MMM-MonthlyCalendar.js there is a section at the end that looks like it is intended to inherit the color information from the event, but this doesn’t actually happen?
                  if (e.color) {
                              var c = e.color;
                              if (e.fullDayEvent) {
                                div.style.backgroundColor = c;
                                if (getLuminance(div.style.backgroundColor) >= self.config.luminanceThreshold) {
                                  div.style.color = "black";
                              } else {
                                div.style.color = c;
                    @Fuergrissa don’t know this module’s workings
                      @Fuergrissa so it looks like this module gets it’s events from the base calendar
                      and if the base is not shown
                      anyhow, use multiple { url: …}
                      blocks in the based calendar add a name: attribute to each
                      that will carry forward on the event. I don’t know if this cal will use it
                      but then u could set styles for events by cal name
