    ALT not doing anything
    44 Posts 6 Posters 21.8k Views 5 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @sdetweil
      @sdetweil I assume it is on you all to resolve MM’s conflict with the newest version of Electron?
      I could see that going both ways. If new version of Electron broke EVERYONE’s application that uses Electron is different than if it only breaks one or two applications.
        @sdetweil I went to the Github Issue to see what you wrote and I don’t see anything relating to to how to retrieve an older version of the repository. All my Googling I had found how each version has tag associated with it but I can’t find in the issue stream anywhere.
        S 2 Replies Last reply Reply Quote 1
          sdetweil @ankonaskiff17
          @ankonaskiff17 issue stream?
          have to look at the changelog of the tag
          you should be able to
          git checkout -b branch_name tagname
          I think.
          but if you used my script to install, then I strip out all the extra branches to save space
          so you would have to use the clone approach
            @ankonaskiff17 I did this
            git clone -b v2.19.0 https://github.com/MichMich/MagicMirror.git mm2.19
            to get the v2.19.0 tag into the folder called mm2.19
            if you don’t have the name at the end the folder will be MagicMirror
            (and fail if there is one already)
            ankonaskiff17A 1 Reply Last reply Reply Quote 0
              @sdetweil Used your script and worked like a charm. Didnt put in mm2.22 at end since I had no previous install.
              Then did the various appropriate steps from the “official” manual install, like node and everything running as desired.
              S ankonaskiff17A 2 Replies Last reply Reply Quote 0
                @ankonaskiff17 my script does everything… no extra steps required
                  ankonaskiff17 @ankonaskiff17
                  @ankonaskiff17 I meant the one where you use the version tag. Not the one that
                  alternative Installation methods is in . That pulls in the current version which is causing me problems with the ALT key
                  I was unsure if git clone -b v2.19.0 https://github.com/... was going to install node.js, or PM2 so I did those portions of manual installation.
                    @ankonaskiff17 ah
                    • E Offline
                      EricD
                      Hello all,
                      I just install MagiMirror on a new RPI5 and I get the same problem : Alt key doesn’t give me the menu.
                      I have compared electron.js from an old installation that works fine with the one I just install on my RPI5 and I remark the line “electronOptionsDefaults.autoHideMenuBar = true;” is missing in the new version. I add this line in the new version, similar place in the code list, and now the Alt command works like the old version : I get the menu.
                      So it is solved for me, until the next update of electron.js file…
                      If it can help you…
                      EricD
                        sdetweil @EricD
                        @EricD yes electron changed the key behavior again. nothing we can do
                        • 4 / 5
