    PIR problem RPi 4B, Bullseye 64 bit
    23 Posts 3 Posters 7.4k Views 3 Watching
      sdetweil @htilburgs
      @htilburgs easy to translate these days
      nice write up
      • W Offline
        wyovino @htilburgs
        @htilburgs said in PIR problem RPi 4B, Bullseye 64 bit:
        I had issues that look the same. After a system crash (defect SD card after 6 years) I could fallback on a backup, but I decided to do a fresh install wih the latest rPi OS. After that my PIR didn’t function anymore. Screen didn’t went of and back on again.
        In my case the solution to put the GL driver back to legacy.
        • sudo raspi-config
        • advanced options
        • GL driver
        • Legacy
        After that my Python script and the PIR worked as they should.p
        My Advanced Options menu doesn’t contain a reference to GL Driver
        • W Offline
          wyovino @wyovino
          Update. I started fresh with Buster instead of Bullseye and followed these instructions to get MMM-PIR-SENSOR working.
          https://www.reddit.com/r/MagicMirror/comments/u1eq9u/problem_setting_up_pirsensor_with_magicmirror/
