Problem installing new module (beginner), CalendarEXT3 not displaying
36 Posts 4 Posters 10.2k Views 4 Watching
    MMRIZE @Manino
    @Manino
    I tested URL you sent me. (Green is that one. I hope this will not be too privacy things.)
      module: "MMM-CalendarExt3",
      position: "bottom_bar",
        mode: 'month',
        locale: 'sv-SE',
        broadcastPastEvents: true,
            symbol: "calendar-check",
            url: "https://ics.calendarlabs.com/709/45a0bb64/Fun_Holidays.ics",
            color: "red",
            url: "https://calendar.google.com/calendar/ical/7a9...4/basic.ics", // <- Your real iCAL URL
            color: "green",
    M 2 Replies Last reply Sep 21, 2023, 8:42 PM Reply Quote 0
      Manino @MMRIZE
      @MMRIZE No pivacy things, its ok thank you.
      Glad to see it works for you, in that way there is’nt anything wrong with my google calendar. I appreciate you took your time and look it up!
      I did copy paste your config into mine and sorry to say but it did’nt work. Then i get back to my own config again but that does’nt work either.
      You can see I get the calendar into the default one. But the month is all empty. And I have to choose “lower_third” becuase on “bottom_bar” september is drowning, I can hardly see it then. Something is really wrong. Maybe I have to start from the beginning again. I mean, it works for you so something is really wrong over here.
      M 1 Reply Last reply Sep 22, 2023, 6:29 AM Reply Quote 0
        Manino @MMRIZE
        @MMRIZE this one is from an all brand new installation of the MM and EXT3. I did end the installation with the ”npm install”. Copy paste your config into mine and got this. I’am clearly doing something wrong but I can’t undestand what to do different.
          MMRIZE @Manino
          @Manino
          Let’s test things.
          1. Remove all other modules except calendar and MMM-CalendarExt3 then run again.
            1-1) If no issue; Some of other modules might make interference.
            1-2) Still happens; Run MM as dev mode (npm run start:dev) => This will show front-end dev console and there might be some useful console log. (or you can populate dev-console on MM with Ctrl+Shift+i or equivalent shortcut keys by your system)
          2. Just in case, the first rendering takes time so wait a while after running it.
          M 1 Reply Last reply Sep 22, 2023, 7:37 AM Reply Quote 0
            Manino @MMRIZE
            @MMRIZE Can you see something? I takes time for my posts to be accepted but now I have an all band new installation of the MM and the EXT3.
            I did comment out(?) all the default models except the calendar. Correct? Still got the same view as above (my latest post), except the clock and date.
            manino@raspberrypi:~ $ cd MagicMirror
            manino@raspberrypi:~/MagicMirror $ npm run start:dev
            magicmirror@2.24.0 start:dev
            DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js dev
            [22.09.2023 09:26.03.030] [LOG] Starting MagicMirror: v2.24.0
            [22.09.2023 09:26.03.044] [LOG] Loading config …
            [22.09.2023 09:26.03.053] [DEBUG] config template file not exists, no envsubst
            [22.09.2023 09:26.03.067] [LOG] Loading module helpers …
            [22.09.2023 09:26.03.070] [LOG] No helper found for module: MMM-CalendarExt3.
            [22.09.2023 09:26.03.620] [LOG] Initializing new module helper …
            [22.09.2023 09:26.03.621] [LOG] Module helper loaded: calendar
            [22.09.2023 09:26.03.622] [LOG] All module helpers loaded.
            [22.09.2023 09:26.03.640] [LOG] Starting server on port 8080 …
            [22.09.2023 09:26.04.084] [ERROR] Whoops! There was an uncaught exception…
            [22.09.2023 09:26.04.097] [ERROR] Error: listen EADDRINUSE: address already in use ::1:8080
            at Server.setupListenHandle [as _listen2] (node:net:1740:16)
            at listenInCluster (node:net:1788:12)
            at GetAddrInfoReqWrap.doListen [as callback] (node:net:1937:7)
            at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:110:8) {
            code: ‘EADDRINUSE’,
            errno: -98,
            syscall: ‘listen’,
            address: ‘::1’,
            port: 8080
            [22.09.2023 09:26.04.098] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [22.09.2023 09:26.04.098] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            MESA-LOADER: failed to retrieve device information
            M 1 Reply Last reply Sep 22, 2023, 2:49 PM Reply Quote 0
              MMRIZE @Manino
              @Manino
              You need to stop “pm2” first before try dev mode. This error means just you are executing mm twice(one from pm2 and one from npm run start:dev). That error is not related with your original issue.
              S M 2 Replies Last reply Sep 22, 2023, 2:51 PM Reply Quote 0
                sdetweil @MMRIZE
                @MMRIZE @Manino do
                pm2 stop all
                then u can do
                npm start
                (ctrl-c to stop)
                to test
                  Manino @MMRIZE
                  @MMRIZE @sdetweil Oh, tnx! This is what I got. Have no idea if this is correct either. Thanks for your patience.
                  manino@raspberrypi:~/MagicMirror $ pm2 stop all
                  [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                  [PM2] [MagicMirror](0) ✓
                  │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                  │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                  manino@raspberrypi:~/MagicMirror $ npm start
                  [22.09.2023 21:59.20.958] [LOG]   Starting MagicMirror: v2.24.0
                  [22.09.2023 21:59.20.971] [LOG]   Loading config ...
                  [22.09.2023 21:59.20.980] [DEBUG] config template file not exists, no envsubst
                  [22.09.2023 21:59.20.989] [LOG]   Loading module helpers ...
                  [22.09.2023 21:59.20.997] [LOG]   No helper found for module: MMM-CalendarExt3.
                  [22.09.2023 21:59.21.413] [LOG]   Initializing new module helper ...
                  [22.09.2023 21:59.21.414] [LOG]   Module helper loaded: calendar
                  [22.09.2023 21:59.21.415] [LOG]   All module helpers loaded.
                  [22.09.2023 21:59.21.436] [LOG]   Starting server on port 8080 ...
                  [22.09.2023 21:59.21.866] [LOG]   Server started ...
                  [22.09.2023 21:59.21.869] [LOG]   Connecting socket for: calendar
                  [22.09.2023 21:59.21.870] [LOG]   Starting node helper for: calendar
                  [22.09.2023 21:59.21.872] [LOG]   Sockets connected & modules started ...
                  [22.09.2023 21:59.21.950] [LOG]   Launching application.
                  ../../buildtools/third_party/libc++/trunk/include/vector:1471: assertion __n < size() failed: vector[] index out of bounds[1602:0922/215923.760165:ERROR:gpu_process_host.cc(954)] GPU process exited unexpectedly: exit_code=6
                  ../../buildtools/third_party/libc++/trunk/include/vector:1471: assertion __n < size() failed: vector[] index out of bounds[1602:0922/215924.743937:ERROR:gpu_process_host.cc(954)] GPU process exited unexpectedly: exit_code=6
                  ../../buildtools/third_party/libc++/trunk/include/vector:1471: assertion __n < size() failed: vector[] index out of bounds[1602:0922/215925.960665:ERROR:gpu_process_host.cc(954)] GPU process exited unexpectedly: exit_code=6
                  [22.09.2023 21:59.25.999] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/709/45a0bb64/Fun_Holidays.ics - Interval: 3600000
                  [22.09.2023 21:59.26.871] [INFO]  Calendar-Fetcher: Broadcasting 59 events.
                  [1645:0922/215926.898550:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                  ^C/home/manino/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                  S 2 Replies Last reply Sep 22, 2023, 7:37 PM Reply Quote 0
                    sdetweil @Manino
                    @Manino
                    ‘/home/manino/package.json’
                    you are not in the MagicMirror folder
                    cd MagicMirror
                      sdetweil @Manino
                      @Manino do this
                      export ELECTRON_DISABLE_GPU=1
                      npm start
                      if that works, the add
                      in the ~/MagicMirror/installers/mm.sh
                      on a new line before the line with npm start
                      • 3 / 4
                      3 / 4
