    Merge conflict detected in your package.json
    19 Posts 3 Posters 4.6k Views 3 Watching
      docransom
      Updated to the latest and now only see localhost refused to connect.
      Nodejs is v 18
      Bullseye
      npm start asks me to resolve the conflict in package.json
      All help is appreciated
        sdetweil @Guku
        @Guku I’m guessing because of the merge conflict the install didn’t work
        do
        cd ~/MagicMirror
        npm install
        then start again
          sdetweil @docransom
          @docransom show the file
            docransom @sdetweil
            log file from error:
            0 verbose cli /usr/bin/node /usr/bin/npm
            1 info using npm@9.6.7
            2 info using node@v18.17.1
            3 timing npm:load:whichnode Completed in 4ms
            4 timing config:load:defaults Completed in 6ms
            5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 6ms
            6 timing config:load:builtin Completed in 7ms
            7 timing config:load:cli Completed in 6ms
            8 timing config:load:env Completed in 1ms
            9 timing config:load:file:/home/hamonation/MagicMirror/.npmrc Completed in 6ms
            10 timing config:load:project Completed in 8ms
            11 timing config:load:file:/home/hamonation/.npmrc Completed in 0ms
            12 timing config:load:user Completed in 2ms
            13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
            14 timing config:load:global Completed in 1ms
            15 timing config:load:setEnvs Completed in 3ms
            16 timing config:load Completed in 36ms
            17 timing npm:load:configload Completed in 36ms
            18 timing npm:load:mkdirpcache Completed in 1ms
            19 timing npm:load:mkdirplogs Completed in 2ms
            20 verbose title npm start
            21 verbose argv "start"
            22 timing npm:load:setTitle Completed in 3ms
            23 timing config:load:flatten Completed in 10ms
            24 timing npm:load:display Completed in 13ms
            25 verbose logfile logs-max:10 dir:/home/hamonation/.npm/_logs/2023-10-02T21_06_09_813Z-
            26 verbose logfile /home/hamonation/.npm/_logs/2023-10-02T21_06_09_813Z-debug-0.log
            27 timing npm:load:logFile Completed in 37ms
            28 timing npm:load:timers Completed in 0ms
            29 timing npm:load:configScope Completed in 0ms
            30 timing npm:load Completed in 99ms
            31 timing command:run-script Completed in 21ms
            32 timing command:start Completed in 77ms
            33 verbose stack JSONParseError: Unexpected token "<" (0x3C) in JSON at position 26 while parsing near "...me\": >
            33 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json-fast/lib/index.js:7:61
            33 verbose stack     at async RunScript.run (/usr/lib/node_modules/npm/lib/commands/run-script.js:73:19)
            33 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:89:5)
            34 verbose cwd /home/hamonation/MagicMirror
            35 verbose Linux 6.1.21-v8+
            36 verbose node v18.17.1
            37 verbose npm  v9.6.7
            38 error code EJSONPARSE
            39 error path /home/hamonation/MagicMirror/package.json
            40 error Merge conflict detected in your package.json.
            40 error
            40 error Please resolve the package.json conflict and retry.
            41 verbose exit 1
            42 timing npm Completed in 239ms
            43 verbose code 1
            44 error A complete log of this run can be found in: /home/hamonation/.npm/_logs/2023-10-02T21_06_09_813Z-debug-0>
            package.json:
                    "name": "magicmirror",
            <<<<<<< HEAD
                    "version": "2.25.0",
                    "version": "2.23.0",
            >>>>>>> parent of e87f50e6 (Release 2.24.0 (#3141))
                    "description": "The open source modular smart mirror platform.",
                    "main": "js/electron.js",
                    "scripts": {
                            "start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
                            "start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
                            "server": "node ./serveronly",
                            "install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                            "install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                            "install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=>
                            "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --n>
                            "postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installati>
                            "test": "NODE_ENV=test jest -i --forceExit",
                            "test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
                            "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
                            "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
                            "test:unit": "NODE_ENV=test jest --selectProjects unit",
                            "test:prettier": "prettier . --check",
                            "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'tr>
                            "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --c>
                            "test:calendar": "node ./modules/default/calendar/debug.js",
                            "config:check": "node js/check_config.js",
                            "lint:prettier": "prettier . --write",
                            "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'tr>
                            "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --c>
                            "lint:staged": "lint-staged",
                            "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
                    "repository": {
                            "type": "git",
                            "url": "git+https://github.com/MichMich/MagicMirror.git"
                    "keywords": [
                            "magic mirror",
                            "magicmirror",
                            "smart mirror",
                            "mirror UI",
                            "modular"
                    "author": "Michael Teeuw",
                    "contributors": [
                            "https://github.com/MichMich/MagicMirror/graphs/contributors"
                    "license": "MIT",
                    "bugs": {
                            "url": "https://github.com/MichMich/MagicMirror/issues"
                    "homepage": "https://magicmirror.builders",
                    "devDependencies": {
            <<<<<<< HEAD
                            "eslint-config-prettier": "^9.0.0",
                            "eslint-plugin-import": "^2.28.1",
                            "eslint-plugin-jest": "^27.4.2",
                            "eslint-plugin-jsdoc": "^46.8.2",
                            "eslint-plugin-prettier": "^5.0.0",
                            "express-basic-auth": "^1.2.1",
                            "husky": "^8.0.3",
                            "jest": "^29.7.0",
                            "jsdom": "^22.1.0",
                            "lint-staged": "^14.0.1",
                            "lodash": "^4.17.21",
                            "playwright": "^1.38.1",
                            "prettier": "^3.0.3",
                            "sinon": "^16.0.0",
                            "stylelint": "^15.10.3",
                            "stylelint-config-standard": "^34.0.0",
                            "stylelint-prettier": "^4.0.2",
                            "suncalc": "^1.9.0"
                    "optionalDependencies": {
                            "electron": "^26.2.4"
                    "dependencies": {
                            "colors": "^1.4.0",
                            "console-stamp": "^3.1.2",
                            "envsub": "^4.1.0",
                            "eslint": "^8.50.0",
                            "express": "^4.18.2",
                            "express-ipfilter": "^1.3.1",
                            "feedme": "^2.0.2",
                            "helmet": "^7.0.0",
                            "html-to-text": "^9.0.5",
                            "eslint-config-prettier": "^8.8.0",
                            "eslint-plugin-import": "^2.27.5",
                            "eslint-plugin-jest": "^27.2.1",
                            "eslint-plugin-jsdoc": "^40.1.0",
                            "eslint-plugin-prettier": "^4.2.1",
                            "husky": "^8.0.3",
                            "jest": "^29.5.0",
                            "jsdom": "^21.1.1",
                            "playwright": "^1.32.1",
                            "prettier": "^2.8.7",
                            "pretty-quick": "^3.1.3",
                            "sinon": "^15.0.2",
                            "stylelint": "^15.3.0",
                            "stylelint-config-standard": "^31.0.0",
                            "stylelint-prettier": "^3.0.0",
                            "suncalc": "^1.9.0"
                            "electron": "^22.3.4"
                    "dependencies": {
                            "colors": "^1.4.0",
                            "console-stamp": "^3.1.1",
                            "digest-fetch": "^2.0.1",
                            "envsub": "^4.1.0",
                            "eslint": "^8.36.0",
                            "feedme": "^2.0.2",
                            "helmet": "^6.0.1",
                            "iconv-lite": "^0.6.3",
                            "luxon": "^1.28.1",
                            "module-alias": "^2.2.2",
                            "moment": "^2.29.4",
            <<<<<<< HEAD
                            "node-ical": "^0.16.1",
                            "socket.io": "^4.7.2"
                    "lint-staged": {
                            "*": "prettier --write",
                            "*.js": "eslint",
                            "*.css": "stylelint"
                            "node-fetch": "^2.6.9",
                            "node-ical": "^0.16.0",
                            "socket.io": "^4.6.1"
                    "_moduleAliases": {
                            "node_helper": "js/node_helper.js",
                            "logger": "js/logger.js"
                    "engines": {
            <<<<<<< HEAD
                            "node": ">=18"
                            "node": ">=14"
              sdetweil @docransom
              @docransom thanks. weird
              see this
              https://docs.github.com/en/pull-requests/collaborating-with-pull-requests/addressing-merge-conflicts/resolving-a-merge-conflict-using-the-command-line
              but for you the simple explanation
              edit the package.json file
              find the line with ======
              delete that line thru the line with >>>>>>>>
              repeat til all are gone
              go back to top
              delete all lines with
              save the file
              git add package.json
              git commit -m " save new"
              the git commit may require you to identify yourself
              | updated
              git config --local user.name ??? <----your name
              git config --local user.email ??? <----your email
              • G Offline
                Guku @sdetweil
                @sdetweil Hi, so i had the same issue and after running the commands i get this
                MagicMirror $ git commit -m"save new"
                U package-lock.json
                error: Committing is not possible because you have unmerged files.
                hint: Fix them up in the work tree, and then use ‘git add/rm ’
                hint: as appropriate to mark resolution and make a commit.
                  sdetweil @Guku
                  @Guku i hate package-lock.json… should NEVER be shipped…
                  its used in the test env to get the right level of code, but we have SO many platforms, that the lock file is garbage…
                  anyhow
                  cd ~/MagicMirror
                  git checkout package-lock.json
                  • G Offline
                    Guku @sdetweil
                    @sdetweil just more errors…
                    /MagicMirror $ git checkout package-lock.json
                    error: path ‘package-lock.json’ is unmerged
                    i just started fresh with version 2.25 few months ago and this is the 1st update, how are things go wrong so quickly? the old build i had for few years without and issue.
                      sdetweil @Guku
                      @Guku rm package-lock.json
                      to erase it
                      my upgrade script handles this for you
                      • G Offline
                        Guku @sdetweil
                        @sdetweil said in Merge conflict detected in your package.json:
                        ran your upgrade script and now see this
                        MagicMirror $ npm run server
                        npm ERR! code EJSONPARSE
                        npm ERR! JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3552 while parsing ‘{
                        npm ERR! JSON.parse “name”: “magicmirror”,
                        npm ERR! JSON.parse “version”: "2’
                        npm ERR! JSON.parse Failed to parse JSON data.
                        npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
                        npm ERR! A complete log of this run can be found in: /home/lolo/.npm/_logs/2024-01-01T18_11_41_122Z-debug-0.log
                          sdetweil @Guku
                          @Guku did you use apply?
                          can u look at package.json too?
                          • G Offline
                            Guku @sdetweil
                            @sdetweil i did use apply at the end and here the file
                            	"version": "2.26.0",
                            	"scripts": {
                            		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                            		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                            		"postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
                            		"test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*'",
                            		"test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
                            		"lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --fix",
                            		"lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
                            	"repository": {
                            		"type": "git",
                            	"keywords": [
                            		"magic mirror",
                            		"magicmirror",
                            		"smart mirror",
                            		"mirror UI",
                            		"modular"
                            	"contributors": [
                            	"license": "MIT",
                            	"bugs": {
                            		"@stylistic/eslint-plugin": "^1.5.1",
                            		"eslint-plugin-import": "^2.29.1",
                            		"eslint-plugin-jest": "^27.6.0",
                            		"eslint-plugin-jsdoc": "^46.9.1",
                            		"husky": "^8.0.3",
                            		"jest": "^29.7.0",
                            		"jsdom": "^23.0.1",
                            		"lint-staged": "^15.2.0",
                            		"playwright": "^1.40.1",
                            		"prettier": "^3.1.1",
                            		"sinon": "^17.0.1",
                            		"stylelint": "^16.1.0",
                            		"stylelint-config-standard": "^36.0.0",
                            		"stylelint-prettier": "^5.0.0",
                            		"suncalc": "^1.9.0"
                            		"electron": "^27.2.0"
                            	"dependencies": {
                            		"colors": "^1.4.0",
                            		"command-exists": "^1.2.9",
                            		"envsub": "^4.1.0",
                            		"eslint": "^8.56.0",
                            		"feedme": "^2.0.2",
                            		"helmet": "^7.1.0",
                            		"module-alias": "^2.2.3",
                            	"lint-staged": {
                            		"*.js": "eslint",
                            	"_moduleAliases": {
                            	"engines": {
                            		"node": ">=18"
                              sdetweil @Guku
                              @Guku weird… missing some of file
                              cd ~/MagicMirror
                              git checkout package.json
                                @Guku also, can u send me the ~/MagicMirror/installers/upgrade.log
                                same userid at gmail
                                • G Offline
                                  Guku @sdetweil
                                  @sdetweil ran the command and this is it
                                  Updated 1 path from the index
                                  sent email with upgrade log
                                    sdetweil @Guku
                                    @Guku now
                                    cd ~/MagicMirror
                                    npm start
                                      sdetweil @Guku
                                      @Guku I ran upgarde on my very old desktop, 2.8 to 2.26
                                      all ok
                                      • G Offline
                                        Guku @sdetweil
                                        @sdetweil now this
                                        npm run server
                                        magicmirror@2.26.0 server
                                        node ./serveronly
                                        [01.01.2024 13:52.17.327] [LOG] Starting MagicMirror: v2.26.0
                                        [01.01.2024 13:52.17.329] [LOG] Loading config …
                                        [01.01.2024 13:52.17.330] [DEBUG] config template file not exists, no envsubst
                                        [01.01.2024 13:52.17.332] [LOG] Loading module helpers …
                                        [01.01.2024 13:52.17.332] [LOG] No helper found for module: alert.
                                        [01.01.2024 13:52.17.336] [ERROR] Whoops! There was an uncaught exception…
                                        [01.01.2024 13:52.17.339] [ERROR] Error: Cannot find module ‘command-exists’
                                        Require stack:
                                        • /home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js
                                        • /home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js
                                        • /home/lolo/MagicMirror/js/app.js
                                        • /home/lolo/MagicMirror/serveronly/index.js
                                          at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                                          at Module._resolveFilename (/home/lolo/MagicMirror/node_modules/module-alias/index.js:49:29)
                                          at Module._load (node:internal/modules/cjs/loader:901:27)
                                          at Module.require (node:internal/modules/cjs/loader:1115:19)
                                          at require (node:internal/modules/helpers:130:18)
                                          at Object. (/home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js:3:23)
                                          at Module._compile (node:internal/modules/cjs/loader:1241:14)
                                          at Module._extensions…js (node:internal/modules/cjs/loader:1295:10)
                                          at Module.load (node:internal/modules/cjs/loader:1091:32)
                                          at Module._load (node:internal/modules/cjs/loader:938:12)
                                          at Object. (/home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js:4:22)
                                          at Module.load (node:internal/modules/cjs/loader:1091:32) {
                                          code: ‘MODULE_NOT_FOUND’,
                                          requireStack: [
                                          ‘/home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js’,
                                          ‘/home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js’,
                                          ‘/home/lolo/MagicMirror/js/app.js’,
                                          ‘/home/lolo/MagicMirror/serveronly/index.js’
                                          [01.01.2024 13:52.17.339] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          [01.01.2024 13:52.17.339] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          sdetweil @Guku
                                          do
                                          cd ~/MagicMirror
                                          npm install
                                          then start again
                                          • G Offline
                                            Guku @sdetweil
                                            @sdetweil i think that finally did it!
                                            thank you so much for your help Sam!
