Merge conflict detected in your package.json
@sdetweil i did use apply at the end and here the file
{ "name": "magicmirror", "version": "2.26.0", "description": "The open source modular smart mirror platform.", "main": "js/electron.js", "scripts": { "start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js", "start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev", "server": "node ./serveronly", "install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev", "install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier", "install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier", "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier", "postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"", "test": "NODE_ENV=test jest -i --forceExit", "test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit", "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit", "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit", "test:unit": "NODE_ENV=test jest --selectProjects unit", "test:prettier": "prettier . --check", "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*'", "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json", "test:calendar": "node ./modules/default/calendar/debug.js", "config:check": "node js/check_config.js", "lint:prettier": "prettier . --write", "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --fix", "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix", "lint:staged": "lint-staged", "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed." }, "repository": { "type": "git", "url": "git+https://github.com/MichMich/MagicMirror.git" }, "keywords": [ "magic mirror", "magicmirror", "smart mirror", "mirror UI", "modular" ], "author": "Michael Teeuw", "contributors": [ "https://github.com/MichMich/MagicMirror/graphs/contributors" ], "license": "MIT", "bugs": { "url": "https://github.com/MichMich/MagicMirror/issues" }, "homepage": "https://magicmirror.builders", "devDependencies": { "@stylistic/eslint-plugin": "^1.5.1", "eslint-plugin-import": "^2.29.1", "eslint-plugin-jest": "^27.6.0", "eslint-plugin-jsdoc": "^46.9.1", "express-basic-auth": "^1.2.1", "husky": "^8.0.3", "jest": "^29.7.0", "jsdom": "^23.0.1", "lint-staged": "^15.2.0", "lodash": "^4.17.21", "playwright": "^1.40.1", "prettier": "^3.1.1", "sinon": "^17.0.1", "stylelint": "^16.1.0", "stylelint-config-standard": "^36.0.0", "stylelint-prettier": "^5.0.0", "suncalc": "^1.9.0" }, "optionalDependencies": { "electron": "^27.2.0" }, "dependencies": { "colors": "^1.4.0", "command-exists": "^1.2.9", "console-stamp": "^3.1.2", "envsub": "^4.1.0", "eslint": "^8.56.0", "express": "^4.18.2", "express-ipfilter": "^1.3.1", "feedme": "^2.0.2", "helmet": "^7.1.0", "html-to-text": "^9.0.5", "iconv-lite": "^0.6.3", "module-alias": "^2.2.3", }, "lint-staged": { "*": "prettier --write", "*.js": "eslint", "*.css": "stylelint" }, "_moduleAliases": { "node_helper": "js/node_helper.js", "logger": "js/logger.js" }, "engines": { "node": ">=18" } } -
@Guku weird… missing some of file
cd ~/MagicMirror
git checkout package.json -
@Guku also, can u send me the ~/MagicMirror/installers/upgrade.log
same userid at gmail
@sdetweil ran the command and this is it
Updated 1 path from the indexsent email with upgrade log
@Guku now
cd ~/MagicMirror npm start -
@Guku I ran upgarde on my very old desktop, 2.8 to 2.26
all ok -
@sdetweil now this
npm run server
magicmirror@2.26.0 server
node ./serveronly[01.01.2024 13:52.17.327] [LOG] Starting MagicMirror: v2.26.0
[01.01.2024 13:52.17.329] [LOG] Loading config …
[01.01.2024 13:52.17.330] [DEBUG] config template file not exists, no envsubst
[01.01.2024 13:52.17.332] [LOG] Loading module helpers …
[01.01.2024 13:52.17.332] [LOG] No helper found for module: alert.
[01.01.2024 13:52.17.336] [ERROR] Whoops! There was an uncaught exception…
[01.01.2024 13:52.17.339] [ERROR] Error: Cannot find module ‘command-exists’
Require stack:- /home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js
 - /home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js
 - /home/lolo/MagicMirror/js/app.js
 - /home/lolo/MagicMirror/serveronly/index.js
at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
at Module._resolveFilename (/home/lolo/MagicMirror/node_modules/module-alias/index.js:49:29)
at Module._load (node:internal/modules/cjs/loader:901:27)
at Module.require (node:internal/modules/cjs/loader:1115:19)
at require (node:internal/modules/helpers:130:18)
at Object. (/home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js:3:23)
at Module._compile (node:internal/modules/cjs/loader:1241:14)
at Module._extensions…js (node:internal/modules/cjs/loader:1295:10)
at Module.load (node:internal/modules/cjs/loader:1091:32)
at Module._load (node:internal/modules/cjs/loader:938:12)
at Object. (/home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js:4:22)
at Module.load (node:internal/modules/cjs/loader:1091:32) {
code: ‘MODULE_NOT_FOUND’,
requireStack: [
‘/home/lolo/MagicMirror/modules/default/updatenotification/update_helper.js’,
‘/home/lolo/MagicMirror/modules/default/updatenotification/node_helper.js’,
‘/home/lolo/MagicMirror/js/app.js’,
‘/home/lolo/MagicMirror/serveronly/index.js’
[01.01.2024 13:52.17.339] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[01.01.2024 13:52.17.339] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
@Guku I’m guessing because of the merge conflict the install didn’t work
do
cd ~/MagicMirror npm installthen start again
@sdetweil i think that finally did it!
thank you so much for your help Sam!
