    `GLIBCXX_3.4.26' not found (required by node)
    24 Posts 4 Posters 28.5k Views 4 Watching
      sdetweil @matt216
      @matt216 try my backup it saves the config the custom CSS and the URLs on GitHub of all of the modules you have installed
      then on restore it uses the URLs to download the modules
      check it out You can run them from GitHub without downloading onto your machine
      puts everything into a little folder MM _ backup just three files
      uses git tags to version the backup, and can push the GitHub if you want when you back up
      and will save the extra files found in any module folder like Google or Spotify token files etc
        matt216 @sdetweil
        @sdetweil beautiful!
        • N Offline
          nnvv3344
          I was having this problem and could not figure it out. Here is the fix that worked right away for me…
          I uninstalled the version of Node that I had (which was 20) and I went back to install node js 18. It works after doing this
          W 1 Reply Last reply Reply Quote 1
          • W Offline
            wyovino @nnvv3344
            @nnvv3344 Unfortunately, the module MMM-Jast requires Node above 18, so I can do that.
