MM does not start - Cannot find module 'html-to-text'
14 Posts 2 Posters 1.5k Views 3 Watching
    sdetweil @Klinge
    @Klinge looks like pm2 is having some trouble
    try this
    pm2 stop all
    pm2 delete 0
    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
    K 1 Reply Last reply Oct 4, 2023, 5:16 PM Reply Quote 0
    • K Offline
      Klinge @sdetweil
      @sdetweil No, nothing changes. The MM start every one to two minutes.
      This is the pm2 log
      pi@raspberrypi:~ $ pm2 logs --lines=50
      [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
      /home/pi/.pm2/pm2.log last 50 lines:
      PM2        |     at WriteStream.emit (node:domain:552:15)
      PM2        |     at node:internal/fs/streams:75:16
      PM2        |     at FSReqCallback.oncomplete (node:fs:200:23)
      PM2        | 2023-10-04T19:11:21: PM2 log: App [MagicMirror:0] online
      PM2        | 2023-10-04T19:12:46: PM2 log: pm2 has been killed by signal, dumping process list before exit...
      PM2        | 2023-10-04T19:12:47: PM2 log: Deleting process 0
      PM2        | 2023-10-04T19:12:47: PM2 log: Stopping app:MagicMirror id:0
      PM2        | 2023-10-04T19:12:47: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGTERM]
      PM2        | 2023-10-04T19:12:47: PM2 log: pid=2895 msg=process killed
      PM2        | 2023-10-04T19:12:47: PM2 log: Exited peacefully
      PM2        | 2023-10-04T19:13:18: PM2 error: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received type number (3126)
      PM2        |     at Object.writeFileSync (node:fs:2314:5)
      PM2        |     at Daemon.innerStart (/usr/lib/node_modules/pm2/lib/Daemon.js:89:8)
      PM2        |     at Domain.<anonymous> (/usr/lib/node_modules/pm2/lib/Daemon.js:62:10)
      PM2        |     at Domain.run (node:domain:389:15)
      PM2        |     at Daemon.start (/usr/lib/node_modules/pm2/lib/Daemon.js:61:5)
      PM2        |     at Object.<anonymous> (/usr/lib/node_modules/pm2/lib/Daemon.js:453:10)
      PM2        |     at Module._compile (node:internal/modules/cjs/loader:1256:14)
      PM2        |     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      PM2        |     at Module.load (node:internal/modules/cjs/loader:1119:32)
      PM2        |     at Module._load (node:internal/modules/cjs/loader:960:12)
      PM2        | 2023-10-04T19:13:18: PM2 log: ===============================================================================
      PM2        | 2023-10-04T19:13:18: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
      PM2        | 2023-10-04T19:13:18: PM2 log: Time                 : Wed Oct 04 2023 19:13:18 GMT+0200 (Mitteleuropäische Sommerzeit)
      PM2        | 2023-10-04T19:13:18: PM2 log: PM2 version          : 4.1.2
      PM2        | 2023-10-04T19:13:18: PM2 log: Node.js version      : 18.18.0
      PM2        | 2023-10-04T19:13:18: PM2 log: Current arch         : arm
      PM2        | 2023-10-04T19:13:18: PM2 log: PM2 home             : /home/pi/.pm2
      PM2        | 2023-10-04T19:13:18: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
      PM2        | 2023-10-04T19:13:18: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
      PM2        | 2023-10-04T19:13:18: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
      PM2        | 2023-10-04T19:13:18: PM2 log: Application log path : /home/pi/.pm2/logs
      PM2        | 2023-10-04T19:13:18: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
      PM2        | 2023-10-04T19:13:18: PM2 log: Concurrent actions   : 2
      PM2        | 2023-10-04T19:13:18: PM2 log: SIGTERM timeout      : 1600
      PM2        | 2023-10-04T19:13:18: PM2 log: [Watch] Start watching MagicMirror
      PM2        | 2023-10-04T19:13:18: PM2 log: App [MagicMirror:0] starting in -fork mode-
      PM2        | 2023-10-04T19:13:18: PM2 error: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received type number (3138)
      PM2        |     at /usr/lib/node_modules/pm2/lib/God/ForkMode.js:258:12
      PM2        |     at wrapper (/usr/lib/node_modules/pm2/node_modules/async/internal/once.js:12:16)
      PM2        |     at next (/usr/lib/node_modules/pm2/node_modules/async/waterfall.js:96:20)
      PM2        |     at /usr/lib/node_modules/pm2/node_modules/async/internal/onlyOnce.js:12:16
      PM2        |     at WriteStream.<anonymous> (/usr/lib/node_modules/pm2/lib/Utility.js:186:13)
      PM2        |     at WriteStream.emit (node:events:517:28)
      PM2        | 2023-10-04T19:13:18: PM2 log: App [MagicMirror:0] online
      /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
      0|MagicMir |
      0|MagicMir | [04.10.2023 18:59.37.259] [ERROR] Failed to retrieve repo info for MagicMirror: Error: Command failed: cd /home/pi/MagicMirror/ && git fetch -n --dry-run
      0|MagicMir | fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Could not resolve host: github.com
      0|MagicMir |
      0|MagicMir | [04.10.2023 18:59.42.967] [ERROR] Whoops! There was an uncaught exception...
      0|MagicMir | [04.10.2023 18:59.42.985] [ERROR] Error: getaddrinfo EAI_AGAIN de.wikipedia.org
      0|MagicMir |     at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:108:26) {
      0|MagicMir |   errno: -3001,
      0|MagicMir |   code: 'EAI_AGAIN',
      0|MagicMir |   syscall: 'getaddrinfo',
      0|MagicMir |   hostname: 'de.wikipedia.org'
      0|MagicMir | }
      0|MagicMir | [04.10.2023 18:59.42.987] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [04.10.2023 18:59.42.989] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [04.10.2023 19:00.36.497] [WARN]  You're using a full whitelist configuration to allow for all IPs
      0|MagicMir | [1368:1004/190037.390496:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
      0|MagicMir | [1402:1004/190038.418478:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [1408:1004/190038.707389:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      0|MagicMir | [04.10.2023 19:02.30.100] [WARN]  You're using a full whitelist configuration to allow for all IPs
      0|MagicMir | [1586:1004/190230.991427:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
      0|MagicMir | [1618:1004/190231.867492:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [1625:1004/190232.164310:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      0|MagicMir | [04.10.2023 19:04.01.396] [WARN]  You're using a full whitelist configuration to allow for all IPs
      0|MagicMir | [1846:1004/190402.324609:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
      0|MagicMir | [1881:1004/190403.297619:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [1887:1004/190403.585748:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      0|MagicMir | [04.10.2023 19:05.32.230] [WARN]  You're using a full whitelist configuration to allow for all IPs
      0|MagicMir | [2062:1004/190533.694144:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
      0|MagicMir | [2096:1004/190534.078919:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [2102:1004/190534.389169:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      0|MagicMir | [04.10.2023 19:07.04.869] [WARN]  You're using a full whitelist configuration to allow for all IPs
      0|MagicMir | [2280:1004/190705.739184:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
      0|MagicMir | [2311:1004/190706.708371:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [2319:1004/190706.990307:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      0|MagicMir | [04.10.2023 19:08.33.769] [WARN]  You're using a full whitelist configuration to allow for all IPs
      0|MagicMir | [2494:1004/190834.629802:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
      0|MagicMir | [2527:1004/190835.803167:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [2533:1004/190836.118560:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      0|MagicMir | [04.10.2023 19:10.04.949] [WARN]  You're using a full whitelist configuration to allow for all IPs
      0|MagicMir | [2708:1004/191005.874878:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
      0|MagicMir | [2742:1004/191006.908739:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [2748:1004/191007.240281:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      0|MagicMir | [04.10.2023 19:11.35.785] [WARN]  You're using a full whitelist configuration to allow for all IPs
      0|MagicMir | [2923:1004/191136.688674:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
      0|MagicMir | [2981:1004/191137.787746:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [2987:1004/191138.169522:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      0|MagicMir | [04.10.2023 19:13.31.440] [WARN]  You're using a full whitelist configuration to allow for all IPs
      0|MagicMir | [3166:1004/191332.276711:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
      0|MagicMir | [3197:1004/191333.445082:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [3206:1004/191333.753392:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
      0|MagicMir | [04.10.2023 19:13.26.072] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
      0|MagicMir | [04.10.2023 19:13.26.424] [LOG]   Initializing new module helper ...
      0|MagicMir | [04.10.2023 19:13.26.425] [LOG]   Module helper loaded: calendar
      0|MagicMir | [04.10.2023 19:13.30.187] [LOG]   Initializing new module helper ...
      0|MagicMir | [04.10.2023 19:13.30.188] [LOG]   Module helper loaded: MMM-OnThisDay
      0|MagicMir | [04.10.2023 19:13.30.817] [LOG]   Initializing new module helper ...
      0|MagicMir | [04.10.2023 19:13.30.818] [LOG]   Module helper loaded: MMM-DWD-Pollen
      0|MagicMir | [04.10.2023 19:13.31.004] [LOG]   Initializing new module helper ...
      0|MagicMir | [04.10.2023 19:13.31.005] [LOG]   Module helper loaded: MMM-NINA
      0|MagicMir | [04.10.2023 19:13.31.121] [LOG]   Initializing new module helper ...
      0|MagicMir | [04.10.2023 19:13.31.122] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
      0|MagicMir | [04.10.2023 19:13.31.404] [LOG]   Initializing new module helper ...
      0|MagicMir | [04.10.2023 19:13.31.405] [LOG]   Module helper loaded: newsfeed
      0|MagicMir | [04.10.2023 19:13.31.406] [LOG]   All module helpers loaded.
      0|MagicMir | [04.10.2023 19:13.31.425] [LOG]   Starting server on port 8080 ...
      0|MagicMir | [04.10.2023 19:13.31.470] [LOG]   Server started ...
      0|MagicMir | [04.10.2023 19:13.31.474] [LOG]   Connecting socket for: updatenotification
      0|MagicMir | [04.10.2023 19:13.31.477] [LOG]   Starting module helper: updatenotification
      0|MagicMir | [04.10.2023 19:13.31.478] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
      0|MagicMir | [04.10.2023 19:13.31.480] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
      0|MagicMir | [04.10.2023 19:13.31.481] [LOG]   Connecting socket for: calendar
      0|MagicMir | [04.10.2023 19:13.31.481] [LOG]   Starting node helper for: calendar
      0|MagicMir | [04.10.2023 19:13.31.482] [LOG]   Connecting socket for: MMM-OnThisDay
      0|MagicMir | [04.10.2023 19:13.31.483] [LOG]   Starting module helper: MMM-OnThisDay
      0|MagicMir | [04.10.2023 19:13.31.484] [LOG]   Connecting socket for: MMM-DWD-Pollen
      0|MagicMir | [04.10.2023 19:13.31.485] [LOG]   MMM-DWD-Pollen helper started ...
      0|MagicMir | [04.10.2023 19:13.31.486] [LOG]   Connecting socket for: MMM-NINA
      0|MagicMir | [04.10.2023 19:13.31.487] [LOG]   MMM-NINA helper method started...
      0|MagicMir | [04.10.2023 19:13.31.488] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
      0|MagicMir | [04.10.2023 19:13.31.488] [LOG]   MMM-DWD-WarnWeather helper started...
      0|MagicMir | [04.10.2023 19:13.31.489] [LOG]   Connecting socket for: newsfeed
      0|MagicMir | [04.10.2023 19:13.31.490] [LOG]   Starting node helper for: newsfeed
      0|MagicMir | [04.10.2023 19:13.31.492] [LOG]   Sockets connected & modules started ...
      0|MagicMir | [04.10.2023 19:13.31.996] [LOG]   Launching application.
      0|MagicMir | [04.10.2023 19:13.37.603] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/...g%40gmail.com/.../basic.ics - Interval: 3600000
      0|MagicMir | [04.10.2023 19:13.37.900] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/....%40gmail.com/.../basic.ics - Interval: 3600000
      0|MagicMir | [04.10.2023 19:13.37.917] [LOG]   requesting:https://opendata.dwd.de/climate_environment/health/alerts/s31fg.json
      0|MagicMir | [04.10.2023 19:13.37.981] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
      0|MagicMir | [04.10.2023 19:13.38.049] [LOG]   MMM-OnThisDay: Received socket notification LOAD_EVENTS.
      0|MagicMir | [04.10.2023 19:13.38.050] [LOG]   MMM-OnThisDay: Load events ...
      0|MagicMir | [04.10.2023 19:13.38.073] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
      0|MagicMir | [04.10.2023 19:13.38.156] [INFO]  Checking git for module: MMM-OnThisDay
      0|MagicMir | [04.10.2023 19:13.38.441] [INFO]  Checking git for module: MMM-DWD-Pollen
      0|MagicMir | [04.10.2023 19:13.38.625] [INFO]  Checking git for module: MMM-NINA
      0|MagicMir | [04.10.2023 19:13.38.734] [INFO]  Checking git for module: MMM-DWD-WarnWeather
      0|MagicMir | [04.10.2023 19:13.38.843] [INFO]  Checking git for module: MagicMirror
      0|MagicMir | [04.10.2023 19:13.38.954] [LOG]   MMM-OnThisDay: Parse HTML data ...
      0|MagicMir | [04.10.2023 19:13.42.384] [INFO]  Newsfeed-Fetcher: reloadInterval set to ttl=5400000 for url http://www.tagesschau.de/xml/rss2
      0|MagicMir | [04.10.2023 19:13.44.341] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
      0|MagicMir | [04.10.2023 19:13.44.705] [LOG]   MMM-DWD-Pollen: Success loading
      S 1 Reply Last reply Oct 4, 2023, 6:26 PM Reply Quote 0
        sdetweil @Klinge
        @Klinge ok have to get a little forceful here
        do
        pm2 stop all
        pm2 unstartup
        the last command should give you another command to execute
        execute that command
        when it ends
        then do
        sudo npm uninstall pm2 -g
        then run my fixuppm2 script again to reinstall and reactivate pm2
        K 1 Reply Last reply Oct 5, 2023, 6:57 AM Reply Quote 0
        • K Offline
          Klinge @sdetweil
          @sdetweil Ok, now it seems that my MM is running.
          Thanks again for your help
          2 / 2
