    install upgrade scripts changed for version 2.25 and node 20
    35 Posts 4 Posters 15.7k Views 4 Watching
      bdream
      @sdetweil as I made
      pm2 stop all
      cd ~/MagicMirror
      npm start >./somefile.txt 2>&1
      it worked fine until CTRL + C
      Yes the problem with the calendar is next I need help to fix. For now I wonder how to get MM starting after reboot again?
      cheers, bdream
        sdetweil @bdream
        @bdream
        pm2 start all
        pm2 save
        and
        sudo reboot
          bdream
          @sdetweil yeah, now it works again :grinning_face:
          What does it “note that we removed digest fetch in this release.” mean?
          Is it I cant get calendar from nextcloud via webdav?
          cheers, bdream
            sdetweil @bdream
            @bdream said in install upgrade scripts changed for version 2.25 and node 20:
            we removed the code in the calendar module that does this type of authentication…
            https://en.wikipedia.org/wiki/Digest_access_authentication
            I personally don’t know the difference in the config or in using nextcloud…
            maybe someone else can chime in here
              bdream
              @sdetweil thanks!!!
              Will see how to solve the calendar issue.
              cheers, bdream
              • 4 / 4
