    install upgrade scripts changed for version 2.25 and node 20
    35 Posts 4 Posters 19.6k Views 4 Watching
      Jonae @Jonae
      i tryed to install on rpi4, i changed to rpi3 and now it works. Does MM not support rpi4 anymore?
        sdetweil @Jonae
        @Jonae you have to use the new test versions.
        listed at the top.of this topic… I just installed on the pi 4. which image did u pick? 32 bit or 64 bit?
        uname -a
        will show it
        J 1 Reply Last reply
          Jonae @sdetweil
          32bit, as i always did …
          S 3 Replies Last reply
            sdetweil @Jonae
            @Jonae ok. I will be away for a couple hours, but will test that again when I return.
              sdetweil @Jonae
              @Jonae could u email me the ~/install.log
              same userid at gmail
                sdetweil @Jonae
                @Jonae can u try the install script again…
                  bdream
                  Here is my somefile.txt
                  > magicmirror@2.25.0 start
                  [12.10.2023 09:50.23.491] [LOG]   Starting MagicMirror: v2.25.0
                  [12.10.2023 09:50.23.502] [LOG]   Loading config ...
                  [12.10.2023 09:50.23.510] [DEBUG] config template file not exists, no envsubst
                  [12.10.2023 09:50.23.544] [LOG]   Loading module helpers ...
                  [12.10.2023 09:50.23.705] [LOG]   Initializing new module helper ...
                  [12.10.2023 09:50.23.707] [LOG]   Module helper loaded: MMM-ServerStatus
                  [12.10.2023 09:50.23.715] [LOG]   Initializing new module helper ...
                  [12.10.2023 09:50.23.716] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.25.0
                  [12.10.2023 09:50.23.719] [LOG]   Version is ok!
                  [12.10.2023 09:50.23.720] [LOG]   Module helper loaded: MMM-Fuel
                  [12.10.2023 09:50.23.735] [LOG]   No helper found for module: alert.
                  [12.10.2023 09:50.23.748] [LOG]   Initializing new module helper ...
                  [12.10.2023 09:50.23.748] [LOG]   Module helper loaded: updatenotification
                  [12.10.2023 09:50.23.751] [LOG]   No helper found for module: MMM-bernwordclock.
                  [12.10.2023 09:50.23.753] [LOG]   No helper found for module: MMM-Carousel.
                  [12.10.2023 09:50.23.756] [LOG]   No helper found for module: clock.
                  [12.10.2023 09:50.23.770] [LOG]   No helper found for module: MMM-WeatherChart.
                  [12.10.2023 09:50.24.376] [LOG]   Initializing new module helper ...
                  [12.10.2023 09:50.24.377] [LOG]   Module helper loaded: calendar
                  [12.10.2023 09:50.25.685] [LOG]   Initializing new module helper ...
                  [12.10.2023 09:50.25.686] [LOG]   Module helper loaded: MMM-Todoist
                  [12.10.2023 09:50.25.689] [LOG]   No helper found for module: weather.
                  [12.10.2023 09:50.25.781] [LOG]   Initializing new module helper ...
                  [12.10.2023 09:50.25.782] [LOG]   Module helper loaded: MMM-PublicTransportHafas
                  [12.10.2023 09:50.25.782] [LOG]   All module helpers loaded.
                  [12.10.2023 09:50.25.803] [LOG]   Starting server on port 3336 ...
                  [12.10.2023 09:50.25.825] [WARN]  You're using a full whitelist configuration to allow for all IPs
                  [12.10.2023 09:50.25.868] [LOG]   Server started ...
                  [12.10.2023 09:50.25.870] [LOG]   Connecting socket for: MMM-ServerStatus
                  [12.10.2023 09:50.25.871] [LOG]   Ping helper started; waiting for requests...
                  [12.10.2023 09:50.25.872] [LOG]   Connecting socket for: MMM-Fuel
                  [12.10.2023 09:50.25.873] [LOG]   Starting module helper: MMM-Fuel
                  [12.10.2023 09:50.25.874] [LOG]   Connecting socket for: updatenotification
                  [12.10.2023 09:50.25.875] [LOG]   Starting module helper: updatenotification
                  [12.10.2023 09:50.25.875] [LOG]   Connecting socket for: calendar
                  [12.10.2023 09:50.25.876] [LOG]   Starting node helper for: calendar
                  [12.10.2023 09:50.25.877] [LOG]   Connecting socket for: MMM-Todoist
                  [12.10.2023 09:50.25.878] [LOG]   Starting node helper for: MMM-Todoist
                  [12.10.2023 09:50.25.878] [LOG]   Connecting socket for: MMM-PublicTransportHafas
                  [12.10.2023 09:50.25.879] [LOG]   Sockets connected & modules started ...
                  [12.10.2023 09:50.27.599] [LOG]   Launching application.
                  [29556:1012/095028.951245:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                  [29601:1012/095030.501129:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                  [12.10.2023 09:50.39.404] [LOG]   Create new calendarfetcher for url: https://<link> - Interval: 120000
                  [12.10.2023 09:50.39.795] [ERROR] Calendar Error. Could not fetch calendar:  https://<link> TypeError: Request cannot be constructed from a URL that includes credentials: https://<link>
                      at Object.fetch (node:internal/deps/undici/undici:11457:11)
                      at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                  [12.10.2023 09:50.39.816] [LOG]   Create new calendarfetcher for url: https://<link> - Interval: 120000
                  [12.10.2023 09:50.39.822] [ERROR] Calendar Error. Could not fetch calendar:  https://<link> TypeError: Request cannot be constructed from a URL that includes credentials: https://<link>
                  [12.10.2023 09:50.41.499] [LOG]   Create new calendarfetcher for url: https://www.schulferien.eu/downloads/ical4.php?land=HE&type=0&year=2022 - Interval: 120000
                  [12.10.2023 09:50.41.520] [LOG]   Create new calendarfetcher for url: https://www.schulferien.eu/downloads/ical4.php?land=8&type=1&year=2022 - Interval: 120000
                  [12.10.2023 09:50.41.650] [INFO]  Checking git for module: MMM-ServerStatus
                  [12.10.2023 09:50.42.329] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://www.schulferien.eu/downloads/ical4.php?land=HE&type=0&year=2022.
                  [12.10.2023 09:50.42.378] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://www.schulferien.eu/downloads/ical4.php?land=8&type=1&year=2022.
                  [12.10.2023 09:50.42.566] [INFO]  Checking git for module: MMM-bernwordclock
                  [12.10.2023 09:50.42.820] [INFO]  Checking git for module: MMM-Carousel
                  /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                  cheers, bdream
                    sdetweil @bdream
                    @bdream said in install upgrade scripts changed for version 2.25 and node 20:
                    12.10.2023 09:50.39.795] [ERROR] Calendar Error. Could not fetch calendar: https:// TypeError: Request cannot be constructed from a URL that includes credentials: https://
                    that looks like the problem.
                    note that we removed digest fetch in this release.
                    I would disable the calendar module as a test to see if that fixes the problem.
                      bdream
                      @sdetweil as I made
                      pm2 stop all
                      npm start >./somefile.txt 2>&1
                      it worked fine until CTRL + C
                      Yes the problem with the calendar is next I need help to fix. For now I wonder how to get MM starting after reboot again?
                      cheers, bdream
                        sdetweil @bdream
                        @bdream
                        pm2 start all
                        pm2 save
                        and
                        sudo reboot
                          bdream
                          @sdetweil yeah, now it works again :grinning_face:
                          What does it “note that we removed digest fetch in this release.” mean?
                          Is it I cant get calendar from nextcloud via webdav?
                          cheers, bdream
                            sdetweil @bdream
                            we removed the code in the calendar module that does this type of authentication…
                            https://en.wikipedia.org/wiki/Digest_access_authentication
                            I personally don’t know the difference in the config or in using nextcloud…
                            maybe someone else can chime in here
                              bdream
                              @sdetweil thanks!!!
                              Will see how to solve the calendar issue.
                              cheers, bdream
