    install upgrade scripts changed for version 2.25 and node 20
    35 Posts 4 Posters 19.3k Views 4 Watching
      sdetweil @bdream
      @bdream ok
      probably missing library on some module
      do this
      pm2 stop all
      npm start >/somefile.txt 2>&1
      wait 15 seconds
      in this same terminal window do
      ctrl-c
      then examine somefile.txt
        bdream
        @sdetweil do I have to use sudo?
        And what exactly you mean “then examine somefile.txt”?
        cheers, bdream
          sdetweil @bdream
          @bdream edit sorry, typo
          2>./somefile.txt
          (notice the missing leading .)
          examine… edit, view, look inside
            Jonae @sdetweil
            this run this script:
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/testit/raspberry.sh)”
            get this error:
            system running in command line mode, configured for graphical desktop, please reboot
            after reboot, same error
              sdetweil @Jonae
              @Jonae are you running the OS in commandline mode?
              boot to prompt… not desktop
              do , and show results
              lsb_release -a
              uname -a
              or email me the ~/install.log
              same userid at gmail
                Jonae @sdetweil
                @sdetweil said in install upgrade scripts changed for version 2.25 and node 20:
                lsb_release -a
                uname -a
                i think i have a problem with the imager software … checking right now
                  Jonae @Jonae
                  i tryed to install on rpi4, i changed to rpi3 and now it works. Does MM not support rpi4 anymore?
                    sdetweil @Jonae
                    @Jonae you have to use the new test versions.
                    listed at the top.of this topic… I just installed on the pi 4. which image did u pick? 32 bit or 64 bit?
                    uname -a
                    will show it
                      Jonae @sdetweil
                      32bit, as i always did …
                      S 3 Replies Last reply Reply Quote 0
                        sdetweil @Jonae
                        @Jonae ok. I will be away for a couple hours, but will test that again when I return.
                          sdetweil @Jonae
                          @Jonae could u email me the ~/install.log
                            sdetweil @Jonae
                            @Jonae can u try the install script again…
                              bdream
                              Here is my somefile.txt
                              > magicmirror@2.25.0 start
                              [12.10.2023 09:50.23.491] [LOG]   Starting MagicMirror: v2.25.0
                              [12.10.2023 09:50.23.502] [LOG]   Loading config ...
                              [12.10.2023 09:50.23.510] [DEBUG] config template file not exists, no envsubst
                              [12.10.2023 09:50.23.544] [LOG]   Loading module helpers ...
                              [12.10.2023 09:50.23.705] [LOG]   Initializing new module helper ...
                              [12.10.2023 09:50.23.707] [LOG]   Module helper loaded: MMM-ServerStatus
                              [12.10.2023 09:50.23.715] [LOG]   Initializing new module helper ...
                              [12.10.2023 09:50.23.716] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.25.0
                              [12.10.2023 09:50.23.719] [LOG]   Version is ok!
                              [12.10.2023 09:50.23.720] [LOG]   Module helper loaded: MMM-Fuel
                              [12.10.2023 09:50.23.735] [LOG]   No helper found for module: alert.
                              [12.10.2023 09:50.23.748] [LOG]   Initializing new module helper ...
                              [12.10.2023 09:50.23.748] [LOG]   Module helper loaded: updatenotification
                              [12.10.2023 09:50.23.751] [LOG]   No helper found for module: MMM-bernwordclock.
                              [12.10.2023 09:50.23.753] [LOG]   No helper found for module: MMM-Carousel.
                              [12.10.2023 09:50.23.756] [LOG]   No helper found for module: clock.
                              [12.10.2023 09:50.23.770] [LOG]   No helper found for module: MMM-WeatherChart.
                              [12.10.2023 09:50.24.376] [LOG]   Initializing new module helper ...
                              [12.10.2023 09:50.24.377] [LOG]   Module helper loaded: calendar
                              [12.10.2023 09:50.25.685] [LOG]   Initializing new module helper ...
                              [12.10.2023 09:50.25.686] [LOG]   Module helper loaded: MMM-Todoist
                              [12.10.2023 09:50.25.689] [LOG]   No helper found for module: weather.
                              [12.10.2023 09:50.25.781] [LOG]   Initializing new module helper ...
                              [12.10.2023 09:50.25.782] [LOG]   Module helper loaded: MMM-PublicTransportHafas
                              [12.10.2023 09:50.25.782] [LOG]   All module helpers loaded.
                              [12.10.2023 09:50.25.803] [LOG]   Starting server on port 3336 ...
                              [12.10.2023 09:50.25.825] [WARN]  You're using a full whitelist configuration to allow for all IPs
                              [12.10.2023 09:50.25.868] [LOG]   Server started ...
                              [12.10.2023 09:50.25.870] [LOG]   Connecting socket for: MMM-ServerStatus
                              [12.10.2023 09:50.25.871] [LOG]   Ping helper started; waiting for requests...
                              [12.10.2023 09:50.25.872] [LOG]   Connecting socket for: MMM-Fuel
                              [12.10.2023 09:50.25.873] [LOG]   Starting module helper: MMM-Fuel
                              [12.10.2023 09:50.25.874] [LOG]   Connecting socket for: updatenotification
                              [12.10.2023 09:50.25.875] [LOG]   Starting module helper: updatenotification
                              [12.10.2023 09:50.25.875] [LOG]   Connecting socket for: calendar
                              [12.10.2023 09:50.25.876] [LOG]   Starting node helper for: calendar
                              [12.10.2023 09:50.25.877] [LOG]   Connecting socket for: MMM-Todoist
                              [12.10.2023 09:50.25.878] [LOG]   Starting node helper for: MMM-Todoist
                              [12.10.2023 09:50.25.878] [LOG]   Connecting socket for: MMM-PublicTransportHafas
                              [12.10.2023 09:50.25.879] [LOG]   Sockets connected & modules started ...
                              [12.10.2023 09:50.27.599] [LOG]   Launching application.
                              [29556:1012/095028.951245:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                              [29601:1012/095030.501129:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                              [12.10.2023 09:50.39.404] [LOG]   Create new calendarfetcher for url: https://<link> - Interval: 120000
                              [12.10.2023 09:50.39.795] [ERROR] Calendar Error. Could not fetch calendar:  https://<link> TypeError: Request cannot be constructed from a URL that includes credentials: https://<link>
                                  at Object.fetch (node:internal/deps/undici/undici:11457:11)
                                  at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                              [12.10.2023 09:50.39.816] [LOG]   Create new calendarfetcher for url: https://<link> - Interval: 120000
                              [12.10.2023 09:50.39.822] [ERROR] Calendar Error. Could not fetch calendar:  https://<link> TypeError: Request cannot be constructed from a URL that includes credentials: https://<link>
                              [12.10.2023 09:50.41.499] [LOG]   Create new calendarfetcher for url: https://www.schulferien.eu/downloads/ical4.php?land=HE&type=0&year=2022 - Interval: 120000
                              [12.10.2023 09:50.41.520] [LOG]   Create new calendarfetcher for url: https://www.schulferien.eu/downloads/ical4.php?land=8&type=1&year=2022 - Interval: 120000
                              [12.10.2023 09:50.41.650] [INFO]  Checking git for module: MMM-ServerStatus
                              [12.10.2023 09:50.42.329] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://www.schulferien.eu/downloads/ical4.php?land=HE&type=0&year=2022.
                              [12.10.2023 09:50.42.378] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://www.schulferien.eu/downloads/ical4.php?land=8&type=1&year=2022.
                              [12.10.2023 09:50.42.566] [INFO]  Checking git for module: MMM-bernwordclock
                              [12.10.2023 09:50.42.820] [INFO]  Checking git for module: MMM-Carousel
                              /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                              cheers, bdream
                                sdetweil @bdream
                                @bdream said in install upgrade scripts changed for version 2.25 and node 20:
                                12.10.2023 09:50.39.795] [ERROR] Calendar Error. Could not fetch calendar: https:// TypeError: Request cannot be constructed from a URL that includes credentials: https://
                                that looks like the problem.
                                note that we removed digest fetch in this release.
                                I would disable the calendar module as a test to see if that fixes the problem.
                                  bdream
                                  @sdetweil as I made
                                  pm2 stop all
                                  npm start >./somefile.txt 2>&1
                                  it worked fine until CTRL + C
                                  Yes the problem with the calendar is next I need help to fix. For now I wonder how to get MM starting after reboot again?
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream
                                    pm2 start all
                                    pm2 save
                                    and
                                    sudo reboot
                                      bdream
                                      @sdetweil yeah, now it works again :grinning_face:
                                      What does it “note that we removed digest fetch in this release.” mean?
                                      Is it I cant get calendar from nextcloud via webdav?
                                      cheers, bdream
                                        sdetweil @bdream
                                        we removed the code in the calendar module that does this type of authentication…
                                        https://en.wikipedia.org/wiki/Digest_access_authentication
                                        I personally don’t know the difference in the config or in using nextcloud…
                                        maybe someone else can chime in here
                                          bdream
                                          @sdetweil thanks!!!
                                          Will see how to solve the calendar issue.
                                          cheers, bdream
