    install upgrade scripts changed for version 2.25 and node 20
    35 Posts 4 Posters 18.8k Views 4 Watching
      bdream @sdetweil
      @sdetweil I get the whole script shown on the screen
      cheers, bdream
        sdetweil @bdream
        @bdream as it should,
        I see there was a problem with the " in the 1st post…
        try again, copy/paste that line again
        • mumblebajM Offline
          @sdetweil Just to let you know this script worked fine on my Mirror first time. Did not need to run the Node one
            sdetweil @mumblebaj
            @mumblebaj said in install upgrade scripts changed for version 2.25 and node 20:
            correct… it is part of the install and upgrade scripts now
            did u run the testit branch version?
              @sdetweil That is correct and worked first time. Checked the installers log and no errors or issues either. Strange thing though, it had no issue with MMM-NewsAPI either and that works fine.
                bdream
                @sdetweil yes, script is running now :beaming_face_with_smiling_eyes:
                MM is not starting automatic, also not after reboot.
                But this work fine
                  pm2 start 0
                cheers, bdream
                  sdetweil @bdream
                  @bdream ok
                  probably missing library on some module
                  do this
                  pm2 stop all
                  npm start >/somefile.txt 2>&1
                  wait 15 seconds
                  in this same terminal window do
                  ctrl-c
                  then examine somefile.txt
                    bdream
                    @sdetweil do I have to use sudo?
                    And what exactly you mean “then examine somefile.txt”?
                    cheers, bdream
                      sdetweil @bdream
                      @bdream edit sorry, typo
                      2>./somefile.txt
                      (notice the missing leading .)
                      examine… edit, view, look inside
                        Jonae @sdetweil
                        this run this script:
                        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/testit/raspberry.sh)”
                        get this error:
                        system running in command line mode, configured for graphical desktop, please reboot
                        after reboot, same error
                          sdetweil @Jonae
                          @Jonae are you running the OS in commandline mode?
                          boot to prompt… not desktop
                          do , and show results
                          lsb_release -a
                          uname -a
                          or email me the ~/install.log
                          same userid at gmail
                            Jonae @sdetweil
                            @sdetweil said in install upgrade scripts changed for version 2.25 and node 20:
                            lsb_release -a
                            uname -a
                            i think i have a problem with the imager software … checking right now
                              Jonae @Jonae
                              i tryed to install on rpi4, i changed to rpi3 and now it works. Does MM not support rpi4 anymore?
                                sdetweil @Jonae
                                @Jonae you have to use the new test versions.
                                listed at the top.of this topic… I just installed on the pi 4. which image did u pick? 32 bit or 64 bit?
                                uname -a
                                will show it
                                  Jonae @sdetweil
                                  32bit, as i always did …
                                  S 3 Replies Last reply Reply Quote 0
                                    sdetweil @Jonae
                                    @Jonae ok. I will be away for a couple hours, but will test that again when I return.
                                      sdetweil @Jonae
                                      @Jonae could u email me the ~/install.log
                                        sdetweil @Jonae
                                        @Jonae can u try the install script again…
                                          bdream
                                          Here is my somefile.txt
                                          > magicmirror@2.25.0 start
                                          [12.10.2023 09:50.23.491] [LOG]   Starting MagicMirror: v2.25.0
                                          [12.10.2023 09:50.23.502] [LOG]   Loading config ...
                                          [12.10.2023 09:50.23.510] [DEBUG] config template file not exists, no envsubst
                                          [12.10.2023 09:50.23.544] [LOG]   Loading module helpers ...
                                          [12.10.2023 09:50.23.705] [LOG]   Initializing new module helper ...
                                          [12.10.2023 09:50.23.707] [LOG]   Module helper loaded: MMM-ServerStatus
                                          [12.10.2023 09:50.23.715] [LOG]   Initializing new module helper ...
                                          [12.10.2023 09:50.23.716] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.25.0
                                          [12.10.2023 09:50.23.719] [LOG]   Version is ok!
                                          [12.10.2023 09:50.23.720] [LOG]   Module helper loaded: MMM-Fuel
                                          [12.10.2023 09:50.23.735] [LOG]   No helper found for module: alert.
                                          [12.10.2023 09:50.23.748] [LOG]   Initializing new module helper ...
                                          [12.10.2023 09:50.23.748] [LOG]   Module helper loaded: updatenotification
                                          [12.10.2023 09:50.23.751] [LOG]   No helper found for module: MMM-bernwordclock.
                                          [12.10.2023 09:50.23.753] [LOG]   No helper found for module: MMM-Carousel.
                                          [12.10.2023 09:50.23.756] [LOG]   No helper found for module: clock.
                                          [12.10.2023 09:50.23.770] [LOG]   No helper found for module: MMM-WeatherChart.
                                          [12.10.2023 09:50.24.376] [LOG]   Initializing new module helper ...
                                          [12.10.2023 09:50.24.377] [LOG]   Module helper loaded: calendar
                                          [12.10.2023 09:50.25.685] [LOG]   Initializing new module helper ...
                                          [12.10.2023 09:50.25.686] [LOG]   Module helper loaded: MMM-Todoist
                                          [12.10.2023 09:50.25.689] [LOG]   No helper found for module: weather.
                                          [12.10.2023 09:50.25.781] [LOG]   Initializing new module helper ...
                                          [12.10.2023 09:50.25.782] [LOG]   Module helper loaded: MMM-PublicTransportHafas
                                          [12.10.2023 09:50.25.782] [LOG]   All module helpers loaded.
                                          [12.10.2023 09:50.25.803] [LOG]   Starting server on port 3336 ...
                                          [12.10.2023 09:50.25.825] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                          [12.10.2023 09:50.25.868] [LOG]   Server started ...
                                          [12.10.2023 09:50.25.870] [LOG]   Connecting socket for: MMM-ServerStatus
                                          [12.10.2023 09:50.25.871] [LOG]   Ping helper started; waiting for requests...
                                          [12.10.2023 09:50.25.872] [LOG]   Connecting socket for: MMM-Fuel
                                          [12.10.2023 09:50.25.873] [LOG]   Starting module helper: MMM-Fuel
                                          [12.10.2023 09:50.25.874] [LOG]   Connecting socket for: updatenotification
                                          [12.10.2023 09:50.25.875] [LOG]   Starting module helper: updatenotification
                                          [12.10.2023 09:50.25.875] [LOG]   Connecting socket for: calendar
                                          [12.10.2023 09:50.25.876] [LOG]   Starting node helper for: calendar
                                          [12.10.2023 09:50.25.877] [LOG]   Connecting socket for: MMM-Todoist
                                          [12.10.2023 09:50.25.878] [LOG]   Starting node helper for: MMM-Todoist
                                          [12.10.2023 09:50.25.878] [LOG]   Connecting socket for: MMM-PublicTransportHafas
                                          [12.10.2023 09:50.25.879] [LOG]   Sockets connected & modules started ...
                                          [12.10.2023 09:50.27.599] [LOG]   Launching application.
                                          [29556:1012/095028.951245:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                                          [29601:1012/095030.501129:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                          [12.10.2023 09:50.39.404] [LOG]   Create new calendarfetcher for url: https://<link> - Interval: 120000
                                          [12.10.2023 09:50.39.795] [ERROR] Calendar Error. Could not fetch calendar:  https://<link> TypeError: Request cannot be constructed from a URL that includes credentials: https://<link>
                                              at Object.fetch (node:internal/deps/undici/undici:11457:11)
                                              at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                          [12.10.2023 09:50.39.816] [LOG]   Create new calendarfetcher for url: https://<link> - Interval: 120000
                                          [12.10.2023 09:50.39.822] [ERROR] Calendar Error. Could not fetch calendar:  https://<link> TypeError: Request cannot be constructed from a URL that includes credentials: https://<link>
                                          [12.10.2023 09:50.41.499] [LOG]   Create new calendarfetcher for url: https://www.schulferien.eu/downloads/ical4.php?land=HE&type=0&year=2022 - Interval: 120000
                                          [12.10.2023 09:50.41.520] [LOG]   Create new calendarfetcher for url: https://www.schulferien.eu/downloads/ical4.php?land=8&type=1&year=2022 - Interval: 120000
                                          [12.10.2023 09:50.41.650] [INFO]  Checking git for module: MMM-ServerStatus
                                          [12.10.2023 09:50.42.329] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://www.schulferien.eu/downloads/ical4.php?land=HE&type=0&year=2022.
                                          [12.10.2023 09:50.42.378] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://www.schulferien.eu/downloads/ical4.php?land=8&type=1&year=2022.
                                          [12.10.2023 09:50.42.566] [INFO]  Checking git for module: MMM-bernwordclock
                                          [12.10.2023 09:50.42.820] [INFO]  Checking git for module: MMM-Carousel
                                          /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream said in install upgrade scripts changed for version 2.25 and node 20:
                                            12.10.2023 09:50.39.795] [ERROR] Calendar Error. Could not fetch calendar: https:// TypeError: Request cannot be constructed from a URL that includes credentials: https://
                                            that looks like the problem.
                                            note that we removed digest fetch in this release.
                                            I would disable the calendar module as a test to see if that fixes the problem.
