    install upgrade scripts changed for version 2.25 and node 20
    35 Posts 4 Posters 16.1k Views 4 Watching
      given all the troubles with the node install process, I have rewritten that function to use the
      n
      command to do the upgrades for node and npm
      (n is a newer designed version of the nvm command (nvm= node version manager)
      | edit… all the changes have been merged back into master
      | too many using the master link as they didn’t look here…
      • upgrade
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
      • install
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
      everything else is the same … let me know
      so far all the places we’ve experienced troubles seem to be corrected now…
      just need some real test feedback…
      thanks for your time.
      mumblebajM 1 Reply Last reply Reply Quote 1
        bdream
        as I face the same “node 20.8.0, but got 20.5.1” problematic, I tried to use upgrade script and get the error:
        cheers, bdream
          sdetweil @bdream
          @bdream what system are you running on?
          show output of
          uname -a
            bdream @sdetweil
            @sdetweil said in install upgrade scripts changed for version 2.,25 and node 20:
            uname -a
            Linux MagicMirror 5.15.32-v7+ #1538 SMP Thu Mar 31 19:38:48 BST 2022 armv7l GNU/Linux
            cheers, bdream
              sdetweil @bdream
              @bdream if u click the link while viewing here, you should see the source of the script
              this sounds like an Internet issue
              that error says it could not download the script
                bdream @sdetweil
                @sdetweil I wonder as I can ping from the Raspi and also get the usual update script working.
                From my PC I can also see both scripts in testit and in master
                cheers, bdream
                  sdetweil @bdream
                  @bdream interesting… never seen a problem like that before…
                    bdream @sdetweil
                    @sdetweil I wonder as both scrips are nearly same.
                    one is running other gives error in line 1 from script. I can’t see a difference :(
                    cheers, bdream
                    • mumblebajM Offline
                      @sdetweil Great work Sam. Do we need to run the node script first?
                      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)”
                      Or just the normal upgrade process with apply?
                      After fixing my dev machine I am about ready to give your script a go on my mirror but want to just double check if the node script is still required.
                        sdetweil @bdream
                        @bdream try this
                        curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/testit/upgrade-script.sh
                        B mumblebajM 2 Replies Last reply Reply Quote 0
                        • 1 / 4
