    install upgrade scripts changed for version 2.25 and node 20
    35 Posts 4 Posters 19.6k Views 4 Watching
      bdream @sdetweil
      @sdetweil I wonder as both scrips are nearly same.
      one is running other gives error in line 1 from script. I can’t see a difference :(
      cheers, bdream
      • mumblebajM
        @sdetweil Great work Sam. Do we need to run the node script first?
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)”
        Or just the normal upgrade process with apply?
        After fixing my dev machine I am about ready to give your script a go on my mirror but want to just double check if the node script is still required.
          sdetweil @bdream
          @bdream try this
          curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/testit/upgrade-script.sh
          B mumblebajM 2 Replies Last reply
            bdream @sdetweil
            @sdetweil I get the whole script shown on the screen
            cheers, bdream
              sdetweil @bdream
              @bdream as it should,
              I see there was a problem with the " in the 1st post…
              try again, copy/paste that line again
              • mumblebajM
                @sdetweil Just to let you know this script worked fine on my Mirror first time. Did not need to run the Node one
                  sdetweil @mumblebaj
                  @mumblebaj said in install upgrade scripts changed for version 2.25 and node 20:
                  correct… it is part of the install and upgrade scripts now
                  did u run the testit branch version?
                  mumblebajM 1 Reply Last reply
                  • mumblebajM
                    @sdetweil That is correct and worked first time. Checked the installers log and no errors or issues either. Strange thing though, it had no issue with MMM-NewsAPI either and that works fine.
                      bdream
                      @sdetweil yes, script is running now :beaming_face_with_smiling_eyes:
                      MM is not starting automatic, also not after reboot.
                      But this work fine
                        pm2 start 0
                      cheers, bdream
                        sdetweil @bdream
                        @bdream ok
                        probably missing library on some module
                        do this
                        pm2 stop all
                        npm start >/somefile.txt 2>&1
                        wait 15 seconds
                        in this same terminal window do
                        ctrl-c
                        then examine somefile.txt
                          bdream
                          @sdetweil do I have to use sudo?
                          And what exactly you mean “then examine somefile.txt”?
                          cheers, bdream
                            sdetweil @bdream
                            @bdream edit sorry, typo
                            2>./somefile.txt
                            (notice the missing leading .)
                            examine… edit, view, look inside
                            J 1 Reply Last reply
                              Jonae @sdetweil
                              this run this script:
                              bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/testit/raspberry.sh)”
                              get this error:
                              system running in command line mode, configured for graphical desktop, please reboot
                              after reboot, same error
                                sdetweil @Jonae
                                @Jonae are you running the OS in commandline mode?
                                boot to prompt… not desktop
                                do , and show results
                                lsb_release -a
                                uname -a
                                or email me the ~/install.log
                                same userid at gmail
                                  Jonae @sdetweil
                                  @sdetweil said in install upgrade scripts changed for version 2.25 and node 20:
                                  lsb_release -a
                                  uname -a
                                  i think i have a problem with the imager software … checking right now
                                    Jonae @Jonae
                                    i tryed to install on rpi4, i changed to rpi3 and now it works. Does MM not support rpi4 anymore?
                                      sdetweil @Jonae
                                      @Jonae you have to use the new test versions.
                                      listed at the top.of this topic… I just installed on the pi 4. which image did u pick? 32 bit or 64 bit?
                                      uname -a
                                      will show it
                                        Jonae @sdetweil
                                        32bit, as i always did …
                                        S 3 Replies Last reply
                                          sdetweil @Jonae
                                          @Jonae ok. I will be away for a couple hours, but will test that again when I return.
                                            sdetweil @Jonae
                                            @Jonae could u email me the ~/install.log
