    install upgrade scripts changed for version 2.25 and node 20
    35 Posts 4 Posters 19.6k Views 4 Watching
      given all the troubles with the node install process, I have rewritten that function to use the
      n
      command to do the upgrades for node and npm
      (n is a newer designed version of the nvm command (nvm= node version manager)
      | edit… all the changes have been merged back into master
      | too many using the master link as they didn’t look here…
      • upgrade
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
      • install
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
      everything else is the same … let me know
      so far all the places we’ve experienced troubles seem to be corrected now…
      just need some real test feedback…
      thanks for your time.
      mumblebajM 1 Reply Last reply
        bdream
        as I face the same “node 20.8.0, but got 20.5.1” problematic, I tried to use upgrade script and get the error:
        cheers, bdream
          sdetweil @bdream
          @bdream what system are you running on?
          show output of
          uname -a
          B 1 Reply Last reply
            bdream @sdetweil
            @sdetweil said in install upgrade scripts changed for version 2.,25 and node 20:
            uname -a
            Linux MagicMirror 5.15.32-v7+ #1538 SMP Thu Mar 31 19:38:48 BST 2022 armv7l GNU/Linux
            cheers, bdream
              sdetweil @bdream
              @bdream if u click the link while viewing here, you should see the source of the script
              this sounds like an Internet issue
              that error says it could not download the script
                bdream @sdetweil
                @sdetweil I wonder as I can ping from the Raspi and also get the usual update script working.
                From my PC I can also see both scripts in testit and in master
                cheers, bdream
                  sdetweil @bdream
                  @bdream interesting… never seen a problem like that before…
                    bdream @sdetweil
                    @sdetweil I wonder as both scrips are nearly same.
                    one is running other gives error in line 1 from script. I can’t see a difference :(
                    cheers, bdream
                    • mumblebajM
                      @sdetweil Great work Sam. Do we need to run the node script first?
                      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)”
                      Or just the normal upgrade process with apply?
                      After fixing my dev machine I am about ready to give your script a go on my mirror but want to just double check if the node script is still required.
                        sdetweil @bdream
                        @bdream try this
                        curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/testit/upgrade-script.sh
                        B mumblebajM 2 Replies Last reply
                          bdream @sdetweil
                          @sdetweil I get the whole script shown on the screen
                          cheers, bdream
                            sdetweil @bdream
                            @bdream as it should,
                            I see there was a problem with the " in the 1st post…
                            try again, copy/paste that line again
                            • mumblebajM
                              @sdetweil Just to let you know this script worked fine on my Mirror first time. Did not need to run the Node one
                                sdetweil @mumblebaj
                                @mumblebaj said in install upgrade scripts changed for version 2.25 and node 20:
                                correct… it is part of the install and upgrade scripts now
                                did u run the testit branch version?
                                • mumblebajM
                                  @sdetweil That is correct and worked first time. Checked the installers log and no errors or issues either. Strange thing though, it had no issue with MMM-NewsAPI either and that works fine.
                                    bdream
                                    @sdetweil yes, script is running now :beaming_face_with_smiling_eyes:
                                    MM is not starting automatic, also not after reboot.
                                    But this work fine
                                      pm2 start 0
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream ok
                                      probably missing library on some module
                                      do this
                                      pm2 stop all
                                      npm start >/somefile.txt 2>&1
                                      wait 15 seconds
                                      in this same terminal window do
                                      ctrl-c
                                      then examine somefile.txt
                                        bdream
                                        @sdetweil do I have to use sudo?
                                        And what exactly you mean “then examine somefile.txt”?
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream edit sorry, typo
                                          2>./somefile.txt
                                          (notice the missing leading .)
                                          examine… edit, view, look inside
                                          J 1 Reply Last reply
                                            Jonae @sdetweil
                                            this run this script:
                                            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/testit/raspberry.sh)”
                                            get this error:
                                            system running in command line mode, configured for graphical desktop, please reboot
                                            after reboot, same error
