    install upgrade scripts changed for version 2.25 and node 20
    35 Posts 4 Posters 18.8k Views 4 Watching
      sdetweil @bdream
      @bdream interesting… never seen a problem like that before…
        bdream @sdetweil
        @sdetweil I wonder as both scrips are nearly same.
        one is running other gives error in line 1 from script. I can’t see a difference :(
        cheers, bdream
        • mumblebajM Offline
          @sdetweil Great work Sam. Do we need to run the node script first?
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)”
          Or just the normal upgrade process with apply?
          After fixing my dev machine I am about ready to give your script a go on my mirror but want to just double check if the node script is still required.
            sdetweil @bdream
            @bdream try this
            curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/testit/upgrade-script.sh
            B mumblebajM 2 Replies Last reply Reply Quote 0
              bdream @sdetweil
              @sdetweil I get the whole script shown on the screen
              cheers, bdream
                sdetweil @bdream
                @bdream as it should,
                I see there was a problem with the " in the 1st post…
                try again, copy/paste that line again
                  @sdetweil Just to let you know this script worked fine on my Mirror first time. Did not need to run the Node one
                    sdetweil @mumblebaj
                    @mumblebaj said in install upgrade scripts changed for version 2.25 and node 20:
                    correct… it is part of the install and upgrade scripts now
                    did u run the testit branch version?
                      @sdetweil That is correct and worked first time. Checked the installers log and no errors or issues either. Strange thing though, it had no issue with MMM-NewsAPI either and that works fine.
                        bdream
                        @sdetweil yes, script is running now :beaming_face_with_smiling_eyes:
                        MM is not starting automatic, also not after reboot.
                        But this work fine
                          pm2 start 0
                        cheers, bdream
                          sdetweil @bdream
                          @bdream ok
                          probably missing library on some module
                          do this
                          pm2 stop all
                          npm start >/somefile.txt 2>&1
                          wait 15 seconds
                          in this same terminal window do
                          ctrl-c
                          then examine somefile.txt
                            bdream
                            @sdetweil do I have to use sudo?
                            And what exactly you mean “then examine somefile.txt”?
                            cheers, bdream
                              sdetweil @bdream
                              @bdream edit sorry, typo
                              2>./somefile.txt
                              (notice the missing leading .)
                              examine… edit, view, look inside
                                Jonae @sdetweil
                                this run this script:
                                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/testit/raspberry.sh)”
                                get this error:
                                system running in command line mode, configured for graphical desktop, please reboot
                                after reboot, same error
                                  sdetweil @Jonae
                                  @Jonae are you running the OS in commandline mode?
                                  boot to prompt… not desktop
                                  do , and show results
                                  lsb_release -a
                                  uname -a
                                  or email me the ~/install.log
                                  same userid at gmail
                                    Jonae @sdetweil
                                    @sdetweil said in install upgrade scripts changed for version 2.25 and node 20:
                                    lsb_release -a
                                    uname -a
                                    i think i have a problem with the imager software … checking right now
                                      Jonae @Jonae
                                      i tryed to install on rpi4, i changed to rpi3 and now it works. Does MM not support rpi4 anymore?
                                        sdetweil @Jonae
                                        @Jonae you have to use the new test versions.
                                        listed at the top.of this topic… I just installed on the pi 4. which image did u pick? 32 bit or 64 bit?
                                        uname -a
                                        will show it
                                          Jonae @sdetweil
                                          32bit, as i always did …
                                          S 3 Replies Last reply Reply Quote 0
                                            sdetweil @Jonae
                                            @Jonae ok. I will be away for a couple hours, but will test that again when I return.
