    MMM-CalendarExt2 vertical orientation positioning
    17 Posts 3 Posters 5.4k Views 3 Watching
      MMRIZE @Michelle.H2020
      @Michelle-H2020
      CX2 doesn’t respect usual MM’s positioning. It manage number of “views” in multi-positions, so you need to assign position to each “view”, not module itself.
      Read manuals.
      • https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/main/docs/Configuration.md
      • https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/main/docs/Configuration/View.md
      And other documents also.
        sdetweil @MMRIZE
        @MMRIZE I think she’s trying EXT 3 now
          Michelle.H2020 @sdetweil
          [01.11.2023 19:44.21.401] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/mirror/MagicMirror/config/config.js:189
          if (typeof module !== “undefined”) {module.exports = config;}
          SyntaxError: Unexpected token ‘typeof’
          at internalCompileFunction (node:internal/vm:73:18)
          at wrapSafe (node:internal/modules/cjs/loader:1185:20)
          at Module._compile (node:internal/modules/cjs/loader:1227:27)
          at Object…js (node:internal/modules/cjs/loader:1326:10)
          at Module.load (node:internal/modules/cjs/loader:1126:32)
          at node:internal/modules/cjs/loader:967:12
          at Function._load (node:electron/js2c/asar_bundle:2:13327)
          at Module.require (node:internal/modules/cjs/loader:1150:19)
          at require (node:internal/modules/cjs/helpers:110:18)
          at loadConfig (/home/mirror/MagicMirror/js/app.js:117:14)
          at App.start (/home/mirror/MagicMirror/js/app.js:247:18)
          at Object. (/home/mirror/MagicMirror/js/electron.js:190:7)
          at Module._compile (node:internal/modules/cjs/loader:1271:14)
          This is starting at line 180 so there is nothing really there at all??
            sdetweil @Michelle.H2020
            @Michelle-H2020 well, it appears you deleted a closing }
            when u pasted in the new module entry
            look at the bottom of the config.js.sample file in the same folder
              Not sure what I did :/ pretty sure I will have to start over and just copy and paste a default config. Do you think I can delete and just copy the whole screw of the sample ?
                @Michelle-H2020 when i use my script, I copy the sample to config.js
                mv config.js broken-config
                cp config.js.sample config.js
                then move your good parts from broken to config.js
                a module is
                   module: ...name
                always make sure the open { matches the close }
                  Michelle.H2020
                  I seem to have got it working I am just wondering how I adjust the events so I don’t just see a few letters of the event, and also the cell height adjustment code when I looked under the module it says
                  manipulateDateCell callback function See the manipulating dateCell part.
                  can you give me any info on this? thanks
