    MMM-CalendarExt2 vertical orientation positioning
    17 Posts 3 Posters 6.4k Views 3 Watching
      Michelle.H2020 @sdetweil
        module: 'MMM-CalendarExt2',
      position:.......  //<-----  mm position missing.
          calendars : [
              url: "https://calendar.google.com/calendar/XXXXXXCXXXbasic.ics",
        url: "https://calendar.google.com/calendarXXXXXXXXXXXXbasic.ics",
        maxItems: 20,
        scanInterval: 1000*60*30,
        beforeDays: 60,
        afterDays: 365,
        maxIterations: 100,
        forceLocalTZ: false,
        replaceTitle:[],
        icon: "noto-beach-with-umbrella",
        className: "michelle",
        filter: (event)=>{return true}
          views: [
              mode: "week",
        mode: "weekly",
        position: "halfscreen_below",
        title: "My Schedule",
        fromNow: -1,
        slotCount: 4,
        slotMaxHeight: "60px",
        showWeekends: true,
        mode: "daily",
          scenes: [
        sdetweil @Michelle.H2020
        @Michelle-H2020
        1st you should move to CalendarExt3, as ext2 is not really supported anymore…
        @MMRIZE can you help here?
          @sdetweil ahh ok let me try the ext3 I had only used this one because of a youtube video that I was following, and a calander that finally actually worked for me as the others were not showing up on the screen.
            @Michelle-H2020 ext no longer reads the calendar itself, but relies on the built in calendar module to do that and broadcast the event data and Ext3 reads that broadcast…
            you can have the default cal not on screen (no position), but still broadcasting so there is a decent amount of change, but ext3 does honor some MM positions, so you can have it lower,
              I get a bunch of red errors when trying to run the Ext 3
                module: "MMM-CalendarExt3",
                position: "bottom_bar",
                title: "test",
                  mode: "month",
                  instanceId: "basicCalendar",
                  locale: 'de-DE',
                  maxEventLines: 5,
                  firstDayOfWeek: 1,
                  calendarSet: "my test",
                  broadcastPastEvents: true,
              	url: "https://calendar.google.com/calendar/XXXXXXXXX/public/basic.ics",
                      color: "red",
              I use this and get the error
              01.11.2023 17:10.06.203] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/mirror/MagicMirror/config/config.js:186
              SyntaxError: Unexpected token ‘;’
              at internalCompileFunction (node:internal/vm:73:18)
              at wrapSafe (node:internal/modules/cjs/loader:1185:20)
              at Module._compile (node:internal/modules/cjs/loader:1227:27)
              at Object…js (node:internal/modules/cjs/loader:1326:10)
              not sure where the error is
                @Michelle-H2020 So what is above line 186 where the semicolon is?
                  MMRIZE @Michelle.H2020
                  @Michelle-H2020
                  CX2 doesn’t respect usual MM’s positioning. It manage number of “views” in multi-positions, so you need to assign position to each “view”, not module itself.
                  Read manuals.
                  • https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/main/docs/Configuration.md
                  • https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/main/docs/Configuration/View.md
                  And other documents also.
                    sdetweil @MMRIZE
                    @MMRIZE I think she’s trying EXT 3 now
                      [01.11.2023 19:44.21.401] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/mirror/MagicMirror/config/config.js:189
                      if (typeof module !== “undefined”) {module.exports = config;}
                      SyntaxError: Unexpected token ‘typeof’
                      at Module.load (node:internal/modules/cjs/loader:1126:32)
                      at node:internal/modules/cjs/loader:967:12
                      at Function._load (node:electron/js2c/asar_bundle:2:13327)
                      at Module.require (node:internal/modules/cjs/loader:1150:19)
                      at require (node:internal/modules/cjs/helpers:110:18)
                      at loadConfig (/home/mirror/MagicMirror/js/app.js:117:14)
                      at App.start (/home/mirror/MagicMirror/js/app.js:247:18)
                      at Object. (/home/mirror/MagicMirror/js/electron.js:190:7)
                      at Module._compile (node:internal/modules/cjs/loader:1271:14)
                      This is starting at line 180 so there is nothing really there at all??
                        @Michelle-H2020 well, it appears you deleted a closing }
                        when u pasted in the new module entry
                        look at the bottom of the config.js.sample file in the same folder
                          Not sure what I did :/ pretty sure I will have to start over and just copy and paste a default config. Do you think I can delete and just copy the whole screw of the sample ?
                            @Michelle-H2020 when i use my script, I copy the sample to config.js
                            mv config.js broken-config
                            cp config.js.sample config.js
                            then move your good parts from broken to config.js
                            a module is
                               module: ...name
                            always make sure the open { matches the close }
                              Michelle.H2020
                              I seem to have got it working I am just wondering how I adjust the events so I don’t just see a few letters of the event, and also the cell height adjustment code when I looked under the module it says
                              manipulateDateCell callback function See the manipulating dateCell part.
                              can you give me any info on this? thanks
