    MM² I fail at installation
    3 Posts 2 Posters 2.6k Views 2 Watching
      svenpisa
      Hi everyone,
      I’m a complete beginner, but I really want to build myself a Smart Mirror.
      Unfortunately I’m already failing at the installation and I hope that you can help me so that I can get it up and running at some point. I’ve already tried several times, but it just won’t work.
      I have got a Raspi 3 with Raspberry Pi OS (Legacy) Full
      What have i done:
      i took the installation tutorial from
      https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
      but first i took the update by sudo apt-get update
      Than installed node.js by sudo apt-get install -y ca-certificates curl gnupg
      and
      sudo mkdir -p /etc/apt/keyring
      curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
      and updated again.
      Everything fine and i got node Version V12.22.12
      so i started
      git clone https://github.com/MichMich/MagicMirror
      got following informations in my terminal
      Klone nach ‘MagicMirror’ …
      remote: Enumerating objects: 25814, done.
      remote: Counting objects: 100% (172/172), done.
      remote: Compressing objects: 100% (94/94), done.
      remote: Total 25814 (delta 79), reused 137 (delta 63), pack-reused 25642
      Empfange Objekte: 100% (25814/25814), 21.49 MiB | 4.92 MiB/s, fertig.
      Löse Unterschiede auf: 100% (15969/15969), fertig.
      go to
      raspberrypi:~ $ cd MagicMirror/
      raspberrypi:~/MagicMirror $
      npm run install-mm
      But than every time i got following Info:
      bash: npm: Kommando nicht gefunden.
      What am i doing wrong???
      I tried it one times more. Than changed the folder to MAgicMirror Old to start following
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
      I would really appreciate any help! :-)
      Greetings
      Sven
        sdetweil @svenpisa
        @svenpisa start from scratch, new sd card image
        boot, skip updates, then run my install script…
        it will install nodejs for you correctly…
        their (nodejs) instructions don’t work.
          svenpisa
          @sdetweil Yes it works!!! Thanks a lot!!! Great job!! :-)
