    Raspberry Pi Zero W for Magic Mirror
    79 Posts 10 Posters 56.6k Views 11 Watching
      sdetweil @davidgagne
      @davidgagne there are more commands after npm init
        davidgagne @sdetweil
        @sdetweil Ah. I see that. But … I don’t think the Jeopardy module is the main problem here. I’d prefer to simply remove that and try to get back to where I can even get MM to run in the first place; then I’ll screw around with adding modules. As it is I still can’t get MM to even run at all (plus all the restarts).
          @sdetweil Am I wrong about this? It actually appears that ‘electron’ is the missing module. But that’s not in /modules it’s in /js … Do I follow the same npm init steps to get it?
            @davidgagne no the electron missing is a problem in MagicMirror code…
            hang on…
              @davidgagne ok, lets clean up and restart
              all command line commands
              pm2 flush (to get clear out the old logs)
              pm2 status
              cd ~/MagicMirror
              npm start
              all show work… and if you loaded the missing library in the MMM-Jeopardy module then all should be ok.
              then ctrl-q on the MM screen should stop it
              then
              pm2 restart 0
              and MM should come back up
                @sdetweil Okay! I’m doing this right now and will keep you posted. THANK YOU AGAIN.
                  `@sdetweil Sadly that didn’t seem to work at all.
                  pm2 flush gave me:
                  [PM2] Spawning PM2 daemon with pm2_home=/home/dvg/.pm2
                  [PM2] PM2 Successfully daemonized
                  [PM2] Flushing /home/dvg/.pm2/pm2.log
                  [PM2] Logs flushed
                  Then pm2 status gave me:
                  │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                  │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 23.3%    │ 40.3mb   │
                  Then I did cd ~/MagicMirror/ and ran npm start which spit out this:
                  > magicmirror@2.27.0 start
                  > ./run-start.sh $1
                  [2024-05-29 23:08:58.949] [LOG] Starting MagicMirror: v2.27.0
                  [2024-05-29 23:08:59.437] [LOG] Loading config ...
                  [2024-05-29 23:08:59.497] [LOG] config template file not exists, no envsubst
                  [2024-05-29 23:09:07.135] [LOG] Loading module helpers ...
                  [2024-05-29 23:09:07.356] [LOG] No helper found for module: alert.
                  [2024-05-29 23:09:36.395] [LOG] Initializing new module helper ...
                  [2024-05-29 23:09:36.558] [LOG] Module helper loaded: updatenotification
                  [2024-05-29 23:09:36.688] [LOG] No helper found for module: clock.
                  [2024-05-29 23:10:00.038] [LOG] Initializing new module helper ...
                  [2024-05-29 23:10:00.109] [LOG] Module helper loaded: calendar
                  [2024-05-29 23:10:00.684] [ERROR] Whoops! There was an uncaught exception...
                  [2024-05-29 23:10:01.570] [ERROR] Error: Cannot find module 'request'
                  Require stack:
                  - /home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js
                  - /home/dvg/MagicMirror/js/app.js
                  - /home/dvg/MagicMirror/serveronly/index.js
                      at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                      at Module._resolveFilename (/home/dvg/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at Module._load (node:internal/modules/cjs/loader:901:27)
                      at Module.require (node:internal/modules/cjs/loader:1115:19)
                      at require (node:internal/modules/helpers:130:18)
                      at Object.<anonymous> (/home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js:8:17)
                      at Module._compile (node:internal/modules/cjs/loader:1241:14)
                      at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
                      at Module.load (node:internal/modules/cjs/loader:1091:32)
                      at Module._load (node:internal/modules/cjs/loader:938:12)
                      at loadModule (/home/dvg/MagicMirror/js/app.js:183:19)
                      at loadModules (/home/dvg/MagicMirror/js/app.js:213:10)
                      at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                      at async App.start (/home/dvg/MagicMirror/js/app.js:261:3) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [
                      '/home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js',
                      '/home/dvg/MagicMirror/js/app.js',
                      '/home/dvg/MagicMirror/serveronly/index.js'
                  [2024-05-29 23:10:01.664] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2024-05-29 23:10:01.745] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                  [2024-05-29 23:12:53.308] [INFO] System information:
                  ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi Zero W Rev 1.1; raspberry: [object Object]; virtual: false
                  ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21+
                  ### VERSIONS: electron: undefined; used node: 20.8.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.4.0
                  ### OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                  Starting chromium browser now, have patience, it takes a minute
                  Chromium_browser not installed
                  This all seemed pointless, but I ran pm2 restart 0 anyway and got this:
                  Use --update-env to update environment variables
                  [PM2] Applying action restartProcessId on app [0](ids: [ '0' ])
                  [PM2] [MagicMirror](0) ✓
                  │ 0  │ MagicMirror        │ fork     │ 47   │ online    │ 0%       │ 23.5mb   │
                  At this point I’m going to give up and go back to square one and flash the drive again and start over. Ugh.
                    @davidgagne said in Raspberry Pi Zero W for Magic Mirror:
                    024-05-29 23:10:01.570] [ERROR] Error: Cannot find module ‘request’
                    Require stack:
                    • /home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js
                    no… just fix the MMM-Jeopardy module as I suggested yesterday
                    two steps
                    you only did 1
                    … the more concerning part is that pm2 didn’t get setup as a service and start on boot… i haven’t looked at the log yet
                    S D 2 Replies Last reply Reply Quote 0
                      @davidgagne the install log looks good…
                      don’t know what is going on… will have to think on it while I sleep…
                      time to rest… til tomorrow
                        @sdetweil I understand what you’re saying about fixing the Jeopardy module, but I really think that’s secondary to not getting MM to run in the first place (and it not starting as a service on boot). Once I get MM running reliably in the first place I will play around with modules. :-)
                        • 6
                        • 7
                        • 8
                        • 5 / 8
