    Raspberry Pi Zero W for Magic Mirror
    79 Posts 10 Posters 74.0k Views 11 Watching
      davidgagne @sdetweil
      @sdetweil I followed your tutorial on adding the Jeopardy module (just to see what would happen) and it worked fine. The last step is npm start and when I did that I got this:
      > magicmirror@2.27.0 start
      > ./run-start.sh $1
      [2024-05-29 10:30:09.649] [LOG] Starting MagicMirror: v2.27.0
      [2024-05-29 10:30:10.200] [LOG] Loading config ...
      [2024-05-29 10:30:10.267] [LOG] config template file not exists, no envsubst
      [2024-05-29 10:30:19.159] [LOG] Loading module helpers ...
      [2024-05-29 10:30:19.394] [LOG] No helper found for module: alert.
      [2024-05-29 10:30:53.041] [LOG] Initializing new module helper ...
      [2024-05-29 10:30:53.066] [LOG] Module helper loaded: updatenotification
      [2024-05-29 10:30:53.220] [LOG] No helper found for module: clock.
      [2024-05-29 10:31:18.754] [LOG] Initializing new module helper ...
      [2024-05-29 10:31:18.854] [LOG] Module helper loaded: calendar
      [2024-05-29 10:31:19.537] [ERROR] Whoops! There was an uncaught exception...
      [2024-05-29 10:31:20.316] [ERROR] Error: Cannot find module 'request'
      Require stack:
      - /home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js
      - /home/dvg/MagicMirror/js/app.js
      - /home/dvg/MagicMirror/serveronly/index.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
          at Module._resolveFilename (/home/dvg/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:901:27)
          at Module.require (node:internal/modules/cjs/loader:1115:19)
          at require (node:internal/modules/helpers:130:18)
          at Object.<anonymous> (/home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js:8:17)
          at Module._compile (node:internal/modules/cjs/loader:1241:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
          at Module.load (node:internal/modules/cjs/loader:1091:32)
          at Module._load (node:internal/modules/cjs/loader:938:12)
          at loadModule (/home/dvg/MagicMirror/js/app.js:183:19)
          at loadModules (/home/dvg/MagicMirror/js/app.js:213:10)
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          at async App.start (/home/dvg/MagicMirror/js/app.js:261:3) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js',
          '/home/dvg/MagicMirror/js/app.js',
          '/home/dvg/MagicMirror/serveronly/index.js'
      [2024-05-29 10:31:20.470] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2024-05-29 10:31:20.593] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
      [2024-05-29 10:34:40.779] [INFO] System information:
      ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi Zero W Rev 1.1; raspberry: [object Object]; virtual: false
      ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21+
      ### VERSIONS: electron: undefined; used node: 20.8.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.4.0
      ### OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
      Starting chromium browser now, have patience, it takes a minute
      Chromium_browser not installed
      FYI: There is definitely an internet connection, so we can rule that out. Otherwise I have no idea.
        sdetweil @davidgagne
        @davidgagne yep,
        not my tutorial just one I reference
        see this
          @sdetweil Hmmm. Okay. I tried that for the ‘alert’ module but it didn’t seem to have any impact:
          dvg@hyperspace:~/MagicMirror $ cd modules/
          dvg@hyperspace:~/MagicMirror/modules $ ls
          default  MMM-JEOPARDY
          dvg@hyperspace:~/MagicMirror/modules $ cd default/
          dvg@hyperspace:~/MagicMirror/modules/default $ ls
          alert  calendar  clock  compliments  defaultmodules.js  helloworld  newsfeed  updatenotification  utils.js  weather
          dvg@hyperspace:~/MagicMirror/modules/default $ cd alert
          dvg@hyperspace:~/MagicMirror/modules/default/alert $ ls package.json
          ls: cannot access 'package.json': No such file or directory
          dvg@hyperspace:~/MagicMirror/modules/default/alert $ npm init -y
          Wrote to /home/dvg/MagicMirror/modules/default/alert/package.json:
            "name": "alert",
            "version": "1.0.0",
            "description": "The alert module is one of the default modules of the MagicMirror². This module displays notifications from other modules.",
            "main": "alert.js",
            "scripts": {
              "test": "echo \"Error: no test specified\" && exit 1"
            "keywords": [],
            "author": "",
            "license": "ISC"
          dvg@hyperspace:~/MagicMirror/modules/default/alert $ cd ..
          dvg@hyperspace:~/MagicMirror/modules/default $ cd ..
          dvg@hyperspace:~/MagicMirror/modules $ cd ..
          dvg@hyperspace:~/MagicMirror $ pm2 start MagicMirror
          [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
          [PM2] [MagicMirror](0) ✓
          [PM2] Process successfully started
          │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
          │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 16303    │ 0s     │ 744  │ online    │ 0%       │ 18.5mb   │ dvg      │ disabled │
          Same result; just a bunch more restarts and nothing appearing. (The Pi desktop is there, though.)
            @davidgagne why alert? it’s the mmm-jeopady module that is missing a library
              @davidgagne said in Raspberry Pi Zero 2 W for Magic Mirror:
              code: ‘MODULE_NOT_FOUND’,
              requireStack: [
              ‘/home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js’,
                @sdetweil So, because I am relentless, I rebooted to see if that would help. It didn’t, but now it looks like I have a different problem altogether:
                cd MagicMirror/
                [PM2] Spawning PM2 daemon with pm2_home=/home/dvg/.pm2
                [PM2] PM2 Successfully daemonized
                [PM2][ERROR] Script not found: /home/dvg/MagicMirror/MagicMirror
                  @davidgagne pm2 status
                    @sdetweil Oh. I thought the alert module was also indicating it was missing. Okay, I’ve tried npm init -y inside the MMM-Jeopardy dir, too, now.
                    pm2 status gives me:
                    │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 1865     │ 11s    │ 28   │ online    │ 21.4%    │ 38.6mb   │ dvg      │ disabled │
                    And now a subsequent pm2 start MagicMirror gives me:
                    │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 1986     │ 0s     │ 34   │ online    │ 0%       │ 22.6mb   │ dvg      │ disabled │
                    But there’s still nothing displaying (aside from the generic Pi OS desktop, I mean).
                      @davidgagne there are more commands after npm init
                        @sdetweil Ah. I see that. But … I don’t think the Jeopardy module is the main problem here. I’d prefer to simply remove that and try to get back to where I can even get MM to run in the first place; then I’ll screw around with adding modules. As it is I still can’t get MM to even run at all (plus all the restarts).
                          @sdetweil Am I wrong about this? It actually appears that ‘electron’ is the missing module. But that’s not in /modules it’s in /js … Do I follow the same npm init steps to get it?
                            @davidgagne no the electron missing is a problem in MagicMirror code…
                            hang on…
                              @davidgagne ok, lets clean up and restart
                              all command line commands
                              pm2 flush (to get clear out the old logs)
                              pm2 status
                              npm start
                              all show work… and if you loaded the missing library in the MMM-Jeopardy module then all should be ok.
                              then ctrl-q on the MM screen should stop it
                              then
                              pm2 restart 0
                              and MM should come back up
                                @sdetweil Okay! I’m doing this right now and will keep you posted. THANK YOU AGAIN.
                                  `@sdetweil Sadly that didn’t seem to work at all.
                                  pm2 flush gave me:
                                  [PM2] Flushing /home/dvg/.pm2/pm2.log
                                  [PM2] Logs flushed
                                  Then pm2 status gave me:
                                  │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                  │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 23.3%    │ 40.3mb   │
                                  Then I did cd ~/MagicMirror/ and ran npm start which spit out this:
                                  > ./run-start.sh $1
                                  [2024-05-29 23:08:58.949] [LOG] Starting MagicMirror: v2.27.0
                                  [2024-05-29 23:08:59.437] [LOG] Loading config ...
                                  [2024-05-29 23:08:59.497] [LOG] config template file not exists, no envsubst
                                  [2024-05-29 23:09:07.135] [LOG] Loading module helpers ...
                                  [2024-05-29 23:09:07.356] [LOG] No helper found for module: alert.
                                  [2024-05-29 23:09:36.395] [LOG] Initializing new module helper ...
                                  [2024-05-29 23:09:36.558] [LOG] Module helper loaded: updatenotification
                                  [2024-05-29 23:09:36.688] [LOG] No helper found for module: clock.
                                  [2024-05-29 23:10:00.038] [LOG] Initializing new module helper ...
                                  [2024-05-29 23:10:00.109] [LOG] Module helper loaded: calendar
                                  [2024-05-29 23:10:00.684] [ERROR] Whoops! There was an uncaught exception...
                                  [2024-05-29 23:10:01.570] [ERROR] Error: Cannot find module 'request'
                                  Require stack:
                                    requireStack: [
                                  [2024-05-29 23:10:01.664] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  [2024-05-29 23:10:01.745] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                                  [2024-05-29 23:12:53.308] [INFO] System information:
                                  This all seemed pointless, but I ran pm2 restart 0 anyway and got this:
                                  [PM2] Applying action restartProcessId on app [0](ids: [ '0' ])
                                  │ 0  │ MagicMirror        │ fork     │ 47   │ online    │ 0%       │ 23.5mb   │
                                  At this point I’m going to give up and go back to square one and flash the drive again and start over. Ugh.
                                    @davidgagne said in Raspberry Pi Zero W for Magic Mirror:
                                    024-05-29 23:10:01.570] [ERROR] Error: Cannot find module ‘request’
                                    Require stack:
                                    • /home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js
                                    no… just fix the MMM-Jeopardy module as I suggested yesterday
                                    two steps
                                    you only did 1
                                    … the more concerning part is that pm2 didn’t get setup as a service and start on boot… i haven’t looked at the log yet
                                    S D 2 Replies Last reply Reply Quote 0
                                      @davidgagne the install log looks good…
                                      don’t know what is going on… will have to think on it while I sleep…
                                      time to rest… til tomorrow
                                        @sdetweil I understand what you’re saying about fixing the Jeopardy module, but I really think that’s secondary to not getting MM to run in the first place (and it not starting as a service on boot). Once I get MM running reliably in the first place I will play around with modules. :-)
                                          davidgagne
                                          How to Get MagicMirror to Run on a Raspberry Pi Zero W Rev 1.1
                                          Late-May 2024
                                          Huge thanks to @sdetweil for all his help!
                                          1. Flash card with Legacy 32-bit.
                                          2. Connect via ssh to run script:
                                            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                            Answer yes to disable screen saver and use pm2 questions.
                                          3. Remove chromium with:
                                            sudo apt-get remove chromium-browser
                                            sudo apt autoremove
                                          4. Add Firefox with:
                                            sudo apt-get update
                                            sudo apt-get install firefox-esr
                                          5. Enable VNC using GUI (Interface Options):
                                            sudo raspi-config
                                          6. Connect via TigerVNC (Apple app)
                                          7. Edit installers/mm.sh via VNC using Pi's baked-in text editor by adding:
                                            export external_browser=firefox
                                            DISPLAY=:0 npm start
                                          8. Execute fix'em-up script:
                                            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                                          9. cd ~/MagicMirror/
                                          10. sudo reboot
                                          Note: On my Pi Zero W it takes a solid ten minutes from reboot to actually seeing MM output via HDMI.
                                          S C plainbrokeP 4 Replies Last reply Reply Quote 1
                                            @davidgagne thanks.
                                            5 and 6 are optional
                                            as 7 can be done with nano over ssh
                                               scroll down with keyboard arrow keys
                                               hit enter to add a line
                                               type the export line
                                               ctrl-x to exit nano, yes to save contents
                                            8 and 9 over ssh
                                            9 pm2 can be run from any folder location
                                            • 3 / 4
