    Mirror mirror on the wall alexa skill
    20 Posts 8 Posters 14.2k Views 7 Watching
    • K Offline
      KMH0 @broberg
      @broberg Ive found the folder, but when I type chmod +x start.sh nothing happens
      • brobergB Offline
        broberg Project Sponsor @KMH0
        @KMH0 Nothing will happen, but now the script will start when you click it instead of opening in leafpad, right?
        K 2 Replies Last reply Reply Quote 1
        • K Offline
          KMH0 @broberg
          @broberg You are a hero mate! :) Thanks
          • K Offline
            KMH0 @broberg
            @broberg Wy did I start this journey, haha. You mind explaining the next steps? :)
            1. go to your local copy of this repo, create a folder called certs inside the src folder
            2. place all the credentials in the certs folder
            3. open MirrorMirror.js, replace the keyPath, certPath, and caPath with your own credentials’ paths
            • brobergB Offline
              @KMH0 That I better leave to someone else that have installed Alexa, Haven’t done that part :)
              K 1 Reply Last reply Reply Quote 1
              • K Offline
                KMH0 @broberg
                @broberg thanks, anyway! :)
                  joanaz @KMH0
                  @KMH0 create a new folder inside the src folder, call it certs, then place the files you downloaded and the generated root-CA.crt in it. I just started to create a guide with screenshots, but it will take me some time, in the meanwhile, you can just ask me
                  • K Offline
                    KMH0 @joanaz
                    @joanaz Would have been awzome! Thanks for the help :)
                      joanaz @KMH0
                      @KMH0 screenshots are added! let me know if the guide still doesn’t make sense
                        ring23 @joanaz
                        @joanaz I was able to config the skill and get it working. Now I’m trying to get it working with the MirrorMirrorOnTheWall module and I’m running into some issues. I’ve copied the cert folder into MagicMirror/modules/MMM-MirrorOnTheWall directory. The next step says to replace keyPath, certPath and caPath with your own credentials’ path, but inside MirrorMirror.js, it’s already defaulting to __dirname + “certs/MagicMirror.private.key”. Booting up MirrorMirror on the wall and invoking On the Wall, Alexa says “there was a problem with the requested skills response”. Now if I run tests in Service Simulator on AWS the lambda response is “The remote endpoint could not be called, or the response it returned was invalid.”
                        Any ideas?
