    MMM-Newsfeedticker Error
    11 Posts 2 Posters 7.5k Views 2 Watching
    • P
      pgwr
      I had been running this module but when I had to restart MM I got an error and can’t determine how to resolve the issue. I am new to this so not good at unscrambling the error messages. Any help on this appreciated.
      I am running;
      Raspberry Pi 4 Model B Rev 1.4
      Debian V 12
      config.js (APIkeys, etc changed):
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "172.16.0.18", "172.16.0.25", "172.16.0.16", "172.16.0.14", "172.16.0.0/24"], 	// Set [] to allow all IP addresses
      	language: "en",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      				timeFormat: 12,
      				displaySeconds: false
      			header: "Upcoming Events",
      						symbol: "calendar",
      						url: "https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/basic.ics",
      						maximumNumberOfDays: 180
      						symbol: "calendar",
      						url: " https://calendar.google.com/calendar/embed?src=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
      						maximumNumberOfDays: 180,
        color: "#fc9403"
      				fade: false
      			module: "weather",
      			header: "Current Forecast - ",
      				// weatherProvider: "openweathermap",
      				// weatherEndpoint: "/onecall",
      				type: 'current',
      				apiKey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
      				initialLoadDelay: 0,
      				locationID: xxxxxx,
      				lat: xxxxxx,
      				lon: xxxx,
      				timeFormat: 12,
      				units: "imperial",
      				showFeelsLike: false
      			module: "weather",
      			header: "Daily Forecast",
      				type: "forecast",
      				// locationID: "xxxx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				maxNumberOfDays: 7,
      				colored: true,
      				showPrecipitationAmount: true,
      				units: "imperial",
      				fade: false,
      				apiKey: "xxxxxxxxxxxxxxxxx"
      			module: "MMM-MyScoreboard",
      			position: "top_center",
      			classes: "default everyone",
      			header: "Scoreboard",
      				showLeagueSeparators: true,
      				colored: true,
      				rolloverHours: 24,
      				viewStyle: "mediumLogos",
      				sports: [
      						league: "NFL",
      						teams: ["KC", "SEA"],
      						groups: ["AFC", "NFC"]
      						league: "NCAAM",
      						teams: ["MIZ"],
      						groups: ["SEC"]
      						league: "NCAAM_MM",
      						label: "March Madness"
      						league: "MLB",
      						teams: ["KC", "STL"]
      			disabled: false,
                              module: "MMM-NewsFeedTicker",
      			position: "bottom_bar",
      			//classes: "day_scheduler",
      				feeds: [
      						title: "New York Times",
      						url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml",
      						customLogo: "NYT_logo_rss_250x40.png"
      						title: "USA Today",
      						url: "http://rssfeeds.usatoday.com/UsatodaycomNation-TopStories",
      						customLogo: "RSS_Syndication_Logo-USATN.png"
      						title: "BBC World News",
      						url: "http://feeds.bbci.co.uk/news/world/rss.xml#",
      						customLogo: "bbc_news_120x60.gif"
      			module: "newsfeed",
      				feeds: [
      						title: "Latest News",
      						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      Error:
      > magicmirror@2.25.0 start
      [06.12.2023 10:45.00.689] [LOG]   Starting MagicMirror: v2.25.0
      [06.12.2023 10:45.00.694] [LOG]   Loading config ...
      [06.12.2023 10:45.00.697] [DEBUG] config template file not exists, no envsubst
      [06.12.2023 10:45.00.701] [LOG]   Loading module helpers ...
      [06.12.2023 10:45.00.703] [LOG]   No helper found for module: alert.
      [06.12.2023 10:45.00.732] [LOG]   Initializing new module helper ...
      [06.12.2023 10:45.00.733] [LOG]   Module helper loaded: updatenotification
      [06.12.2023 10:45.00.733] [LOG]   No helper found for module: clock.
      [06.12.2023 10:45.00.892] [LOG]   Initializing new module helper ...
      [06.12.2023 10:45.00.893] [LOG]   Module helper loaded: calendar
      [06.12.2023 10:45.01.008] [LOG]   Initializing new module helper ...
      [06.12.2023 10:45.01.008] [LOG]   Module helper loaded: MMM-Remote-Control
      [06.12.2023 10:45.01.009] [LOG]   No helper found for module: weather.
      [06.12.2023 10:45.01.013] [LOG]   Initializing new module helper ...
      [06.12.2023 10:45.01.013] [LOG]   Module helper loaded: MMM-MyScoreboard
      [06.12.2023 10:45.01.013] [WARN]  No /home/xxxxxxx/MagicMirror/js/../modules/internet-monitor/internet-monitor.js found for module: internet-monitor.
      [06.12.2023 10:45.01.014] [LOG]   No helper found for module: internet-monitor.
      [06.12.2023 10:45.01.017] [ERROR] (node:7591) UnhandledPromiseRejectionWarning: Error: Cannot find module 'valid-url'
      Require stack:
      - /home/xxxxxxxx/MagicMirror/modules/MMM-NewsFeedTicker/node_helper.js
      - /home/xxxxxxxx/MagicMirror/js/app.js
      - /home/xxxxxxxx/MagicMirror/js/electron.js
      - /home/xxxxxxxx/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
          at node:internal/modules/cjs/loader:1084:15
          at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
          at Module._resolveFilename (/home/xxxxxxxx/MagicMirror/node_modules/module-alias/index.js:49:29)
          at node:internal/modules/cjs/loader:929:27
          at Function._load (node:electron/js2c/asar_bundle:2:13327)
          at Module.require (node:internal/modules/cjs/loader:1150:19)
          at require (node:internal/modules/cjs/helpers:110:18)
          at Object.<anonymous> (/home/xxxxxxxx/MagicMirror/modules/MMM-NewsFeedTicker/node_helper.js:9:16)
          at Module._compile (node:internal/modules/cjs/loader:1271:14)
          at Object..js (node:internal/modules/cjs/loader:1326:10)
          at Module.load (node:internal/modules/cjs/loader:1126:32)
          at node:internal/modules/cjs/loader:967:12
          at loadModule (/home/xxxxxxxx/MagicMirror/js/app.js:180:19)
      (Use `electron --trace-warnings ...` to show where the warning was created)
      [06.12.2023 10:45.01.018] [ERROR] (node:7591) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      [7626:1206/104502.070074:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.070580:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.070900:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.071513:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.071988:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.072542:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.073076:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.075660:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.076044:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.076776:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.077295:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.077776:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.078249:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      [7626:1206/104502.078728:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
      S P 3 Replies Last reply Reply Quote 0
      • P
        pgwr @pgwr
        @pgwr okay, missed that. So sounds like i need to install the request module in the newsfeedticker module folder. I assume
        npm install request
          sdetweil @pgwr
          @pgwr please use code block around config and errors
          paste text
          empty line above and below
          select pasted text
          hit </> button for code block wrapper
          I fixed this time
          error
          yes module is missing a library we used to ship
          but wasn’t documented
          see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
          fix is (the same for any missing lib, there are 8 I think)
          cd to the module folder
          npm install valid-url
          P 4 Replies Last reply Reply Quote 0
          • P
            pgwr @sdetweil
            @sdetweil thanks much!
            • P
              pgwr @sdetweil
              @sdetweil checked the list and installed valid-url. Same result. Hmmmm…
                sdetweil @pgwr
                @pgwr show the errors again.
                • P
                  pgwr @sdetweil
                  [29.12.2023 11:26.31.512] [LOG]   Starting MagicMirror: v2.25.0
                  [29.12.2023 11:26.31.517] [LOG]   Loading config ...
                  [29.12.2023 11:26.31.520] [DEBUG] config template file not exists, no envsubst
                  [29.12.2023 11:26.31.524] [LOG]   Loading module helpers ...
                  [29.12.2023 11:26.31.526] [LOG]   No helper found for module: alert.
                  [29.12.2023 11:26.31.555] [LOG]   Initializing new module helper ...
                  [29.12.2023 11:26.31.555] [LOG]   Module helper loaded: updatenotification
                  [29.12.2023 11:26.31.556] [LOG]   No helper found for module: clock.
                  [29.12.2023 11:26.31.713] [LOG]   Initializing new module helper ...
                  [29.12.2023 11:26.31.714] [LOG]   Module helper loaded: calendar
                  [29.12.2023 11:26.31.715] [LOG]   No helper found for module: weather.
                  [29.12.2023 11:26.31.719] [LOG]   Initializing new module helper ...
                  [29.12.2023 11:26.31.719] [LOG]   Module helper loaded: MMM-MyScoreboard
                  [29.12.2023 11:26.31.750] [ERROR] (node:271795) UnhandledPromiseRejectionWarning: Error: Cannot find module 'request'
                  Require stack:
                  - /home/xxxxxxxx/MagicMirror/modules/MMM-NewsFeedTicker/fetcher.js
                      at Object.<anonymous> (/home/xxxxxxxx/MagicMirror/modules/MMM-NewsFeedTicker/fetcher.js:9:15)
                      at Object.<anonymous> (/home/xxxxxxxx/MagicMirror/modules/MMM-NewsFeedTicker/node_helper.js:10:15)
                  [29.12.2023 11:26.31.751] [ERROR] (node:271795) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                  [271828:1229/112632.791848:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.792586:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.793028:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.793413:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.793786:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.794156:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.794523:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.796415:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.796862:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.797250:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.797619:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.797990:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.798355:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [271828:1229/112632.798715:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  ^C/home/xxxxxxxx/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                  • P
                    pgwr @sdetweil
                    @sdetweil Resubmitted the error log. Hopefully did the code block correctly.
                      sdetweil @pgwr
                      @pgwr said in MMM-Newsfeedticker Error:
                      [29.12.2023 11:26.31.750] [ERROR] (node:271795) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
                      yep
                      • P
                        pgwr @pgwr
                        npm install request
                          sdetweil @pgwr
                          @pgwr yes, as I said there are multiple missing libraries, all get corrected the same way
                          • P
                            pgwr @pgwr
                            @pgwr thanks…
