    High CPU usage when using MMM-BackgroundSlideshow
    modulestroubleshootcore
    4 Posts 2 Posters 1.3k Views 2 Watching
      Mats 0
      Hi All,
      I’m using Raspberry Pi 4, 8GB, for my MM connected to a 4k TV. Following version of OS and MM are installed:
      • Raspberry Pi OS: Debian Linux 12 (bookworm)
      • Magic Mirror: Version 2.25.0
      • Electron: Version v26.6.3
        The installation runs well. When MMM-BackgroundSlideshow ist installed and local stored pictures used for Background-Slideshow there ist a high CPU usage during the slide of the pictures. After some hours the pi freezes. The modules options are shown below.
        I know, that in 2017 with earlier Versions of OS und MM there was a similar problem that could be fixed with a downgrade of electron, but it was a downgrade from 1.17.x to 1.14.x. Since then we have a big step in versions so I think that is not a solution.
        I hope that there is an newer and better solution in relation to the actual versions of OS, MM and electron.
        Please help!
        Thanks in advance
        Mats 0
        sdetweil @Mats 0
        @Mats-0 I don’t see that kind of behavior with the MMM-ImagesPhotos module. but I have modified it in full screen to maintain the image aspect ratio. neither cover nor contain.
        mine
        https://github.com/sdetweil/MMM-ImagesPhotos
        the public version (in 3rd party list) does cover or contain
        I’d give it a try to see if it does the same. it uses a hard coded folder to load the images, but you can link it anywhere. so mark the current module
        disabled and link to the current images folder
        all my machines are 4gb or less. and I link to a samba file server to access the images.
          Mats 0 @sdetweil
          Hi Sam, thank you for your quick reply. I wish you a happy new year!
          I have tested your module and it runs without any problems. The CPU load is low when measured with htop.
          As you mentioned, you can change the directory from which the images are read. Since I’m not the Linux specialist, I’d be grateful for a tip. I would prefer to read the images from a shared directory of my Synology NAS. Thank you!
          Yours sincerely
          Mathias
            sdetweil @Mats 0
            @Mats-0 so you mount that shared folder on your mm system in some location. typically those end up in the /media/username folder
            then you use the ln command to create a linked directory to that folder
            in the MMM-ImagesPhotos folder, rename the upload folder out out the way
            mv upload upload-old
            then create the linked upload
            sudo ln -s the-mounted-path  upload
            I add a line to my /etc/fstab to create the link to my server share at boot time.
            I have never seen a Synology mas, so I don’t know how you get those volumes mounted on the consuming systems are they using windows
            samba shares?
