    Calendar not loading after update to 2.26
    22 Posts 2 Posters 8.8k Views 2 Watching
      avano
      Hi there
      I have potentially the same issue as https://forum.magicmirror.builders/topic/18325/calendar-not-updating?page=1 except that my calendar does not load at all. It’s stuck on “Loading…”
      The issue started after updating to 2.26.0 from a very old version from April 2022.
      Using a RPI 3 B on Bullseye.
      node version v21.5.0
      All other default modules work fine.
      Thanks for the support.
      ~/MagicMirror $ npm start
      > magicmirror@2.26.0 start
      [01.01.2024 22:30.20.942] [LOG]   Starting MagicMirror: v2.26.0
      [01.01.2024 22:30.20.954] [LOG]   Loading config ...
      [01.01.2024 22:30.20.961] [DEBUG] config template file not exists, no envsubst
      [01.01.2024 22:30.20.977] [LOG]   Loading module helpers ...
      [01.01.2024 22:30.20.980] [LOG]   No helper found for module: alert.
      [01.01.2024 22:30.21.042] [LOG]   Initializing new module helper ...
      [01.01.2024 22:30.21.044] [LOG]   Module helper loaded: updatenotification
      [01.01.2024 22:30.21.046] [LOG]   No helper found for module: clock.
      [01.01.2024 22:30.21.371] [LOG]   Initializing new module helper ...
      [01.01.2024 22:30.21.373] [LOG]   Module helper loaded: calendar
      [01.01.2024 22:30.21.375] [LOG]   No helper found for module: compliments.
      [01.01.2024 22:30.21.377] [LOG]   No helper found for module: weather.
      [01.01.2024 22:30.21.617] [LOG]   Initializing new module helper ...
      [01.01.2024 22:30.21.618] [LOG]   Module helper loaded: newsfeed
      [01.01.2024 22:30.21.619] [LOG]   All module helpers loaded.
      [01.01.2024 22:30.21.638] [LOG]   Starting server on port 8080 ...
      [01.01.2024 22:30.22.091] [LOG]   Server started ...
      [01.01.2024 22:30.22.093] [LOG]   Connecting socket for: updatenotification
      [01.01.2024 22:30.22.095] [LOG]   Starting module helper: updatenotification
      [01.01.2024 22:30.22.097] [LOG]   Connecting socket for: calendar
      [01.01.2024 22:30.22.099] [LOG]   Starting node helper for: calendar
      [01.01.2024 22:30.22.100] [LOG]   Connecting socket for: newsfeed
      [01.01.2024 22:30.22.102] [LOG]   Starting node helper for: newsfeed
      [01.01.2024 22:30.22.103] [LOG]   Sockets connected & modules started ...
      [01.01.2024 22:30.22.128] [LOG]   Launching application.
      [01.01.2024 22:30.26.448] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/*****/basic.ics - Interval: 60000
      [01.01.2024 22:30.26.786] [LOG]   Create new newsfetcher for url: http://feeds.bbci.co.uk/news/world/rss.xml - Interval: 300000
      [01.01.2024 22:30.26.805] [LOG]   Create new newsfetcher for url: https://www.francetvinfo.fr/titres.rss - Interval: 300000
      [01.01.2024 22:30.26.834] [INFO]  updatenotification: Updater Class Loaded!
      [01.01.2024 22:30.26.838] [INFO]  updatenotification: Checking PM2 using...
      [01.01.2024 22:30.26.846] [INFO]  Checking git for module: MagicMirror
      [01.01.2024 22:30.28.718] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
      [01.01.2024 22:30.28.829] [INFO]  Newsfeed-Fetcher: reloadInterval set to ttl=900000 for url http://feeds.bbci.co.uk/news/world/rss.xml
      [01.01.2024 22:30.29.764] [INFO]  Newsfeed-Fetcher: Broadcasting 55 items.
      [01.01.2024 22:30.29.889] [INFO]  updatenotification: You are not using pm2
      [01.01.2024 22:34.21.451] [INFO]  Calendar-Fetcher: Broadcasting 196 events from https://calendar.google.com/calendar/ical/*****/basic.ics.
      Warning: vkCreateInstance: Found no drivers!
      Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
          at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
          at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
          at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
          at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
          at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                              header: "What's next",
                                                      symbol: "calendar-check",
                                                      url: "https://calendar.google.com/calendar/ical/***/basic.ics"
                                      limitDays: 30,
                                      maximumEntries: 15,
                                      wrapEvents: true,
                                      hidePrivate: true
      I tried with the sample calendar too (www.calendarlabs.com), it shows “no future events” but I assume it loaded the calendar just fine. I get the same warnings though.
      S A 3 Replies Last reply Reply Quote 1
        sdetweil @avano
        @avano can you show me output of
        uname -a
        lsb_release -a
          avano @avano
          @sdetweil here they are:
          pi@raspberrypi:~ $ uname -a
          Linux raspberrypi 5.15.32-v8+ #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022 aarch64 GNU/Linux
          pi@raspberrypi:~ $ lsb_release -a
          No LSB modules are available.
          Distributor ID: Debian
          Description: Debian GNU/Linux 11 (bullseye)
          Release: 11
          Codename: bullseye
            sdetweil @avano
            @avano cool, thx
            can u try the text fix I posted here
            https://github.com/MagicMirrorOrg/MagicMirror/issues/3329
            you DID get events once…
              avano
              @sdetweil I replaced lines 58 to 84, but I can’t see any difference in the logs:
              [02.01.2024 22:16.00.050] [LOG]   Starting MagicMirror: v2.26.0
              [02.01.2024 22:16.00.062] [LOG]   Loading config ...
              [02.01.2024 22:16.00.069] [DEBUG] config template file not exists, no envsubst
              [02.01.2024 22:16.00.078] [LOG]   Loading module helpers ...
              [02.01.2024 22:16.00.082] [LOG]   No helper found for module: alert.
              [02.01.2024 22:16.00.142] [LOG]   Initializing new module helper ...
              [02.01.2024 22:16.00.144] [LOG]   Module helper loaded: updatenotification
              [02.01.2024 22:16.00.146] [LOG]   No helper found for module: clock.
              [02.01.2024 22:16.00.475] [LOG]   Initializing new module helper ...
              [02.01.2024 22:16.00.478] [LOG]   Module helper loaded: calendar
              [02.01.2024 22:16.00.480] [LOG]   No helper found for module: compliments.
              [02.01.2024 22:16.00.482] [LOG]   No helper found for module: weather.
              [02.01.2024 22:16.00.724] [LOG]   Initializing new module helper ...
              [02.01.2024 22:16.00.725] [LOG]   Module helper loaded: newsfeed
              [02.01.2024 22:16.00.726] [LOG]   All module helpers loaded.
              [02.01.2024 22:16.00.745] [LOG]   Starting server on port 8080 ...
              [02.01.2024 22:16.01.207] [LOG]   Server started ...
              [02.01.2024 22:16.01.210] [LOG]   Connecting socket for: updatenotification
              [02.01.2024 22:16.01.213] [LOG]   Starting module helper: updatenotification
              [02.01.2024 22:16.01.215] [LOG]   Connecting socket for: calendar
              [02.01.2024 22:16.01.218] [LOG]   Starting node helper for: calendar
              [02.01.2024 22:16.01.221] [LOG]   Connecting socket for: newsfeed
              [02.01.2024 22:16.01.224] [LOG]   Starting node helper for: newsfeed
              [02.01.2024 22:16.01.227] [LOG]   Sockets connected & modules started ...
              [02.01.2024 22:16.01.257] [LOG]   Launching application.
              [02.01.2024 22:16.05.686] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/*****/basic.ics - Interval: 3600000
              [02.01.2024 22:16.06.038] [LOG]   Create new newsfetcher for url: http://feeds.bbci.co.uk/news/world/rss.xml - Interval: 300000
              [02.01.2024 22:16.06.071] [LOG]   Create new newsfetcher for url: https://www.francetvinfo.fr/titres.rss - Interval: 300000
              [02.01.2024 22:16.06.081] [INFO]  updatenotification: Updater Class Loaded!
              [02.01.2024 22:16.06.082] [INFO]  updatenotification: Checking PM2 using...
              [02.01.2024 22:16.06.115] [INFO]  Checking git for module: MagicMirror
              [02.01.2024 22:16.07.782] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
              [02.01.2024 22:16.07.989] [INFO]  Newsfeed-Fetcher: reloadInterval set to ttl=900000 for url http://feeds.bbci.co.uk/news/world/rss.xml
              [02.01.2024 22:16.08.942] [INFO]  Newsfeed-Fetcher: Broadcasting 53 items.
              [02.01.2024 22:16.08.957] [INFO]  updatenotification: You are not using pm2
              [02.01.2024 22:20.00.092] [INFO]  Calendar-Fetcher: Broadcasting 241 events from https://calendar.google.com/calendar/ical/*****/basic.ics.
              [02.01.2024 22:21.08.585] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                sdetweil @avano
                @avano said in Calendar not loading after update to 2.26:
                well, it sent 241 entries to be put on the calendar
                update is 3600 000 milliseconds , or 1 hour
                did u wait that long?
                  @sdetweil and you redo
                  cd ~/MagicMirror
                  npm run install-mm
                    avano
                    pi@raspberrypi:~/MagicMirror $ npm run install-mm
                    > magicmirror@2.26.0 install-mm
                    > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                    npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
                    > magicmirror@2.26.0 postinstall
                    > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                    > magicmirror@2.26.0 install-vendor
                    > echo "Installing vendor files ...
                    > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    up to date in 2s
                    > magicmirror@2.26.0 install-fonts
                    > echo "Installing fonts ...
                    > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    up to date in 9s
                    > magicmirror@2.26.0 prepare
                    > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                    no husky installed.
                    up to date in 33s
                    I changed to fetchInterval to 1 minute:
                    [02.01.2024 22:52.55.268] [LOG]   Starting MagicMirror: v2.26.0
                    [02.01.2024 22:52.55.289] [LOG]   Loading config ...
                    [02.01.2024 22:52.55.296] [DEBUG] config template file not exists, no envsubst
                    [02.01.2024 22:52.55.305] [LOG]   Loading module helpers ...
                    [02.01.2024 22:52.55.308] [LOG]   No helper found for module: alert.
                    [02.01.2024 22:52.55.369] [LOG]   Initializing new module helper ...
                    [02.01.2024 22:52.55.370] [LOG]   Module helper loaded: updatenotification
                    [02.01.2024 22:52.55.373] [LOG]   No helper found for module: clock.
                    [02.01.2024 22:52.55.698] [LOG]   Initializing new module helper ...
                    [02.01.2024 22:52.55.700] [LOG]   Module helper loaded: calendar
                    [02.01.2024 22:52.55.703] [LOG]   No helper found for module: compliments.
                    [02.01.2024 22:52.55.705] [LOG]   No helper found for module: weather.
                    [02.01.2024 22:52.55.944] [LOG]   Initializing new module helper ...
                    [02.01.2024 22:52.55.945] [LOG]   Module helper loaded: newsfeed
                    [02.01.2024 22:52.55.946] [LOG]   All module helpers loaded.
                    [02.01.2024 22:52.55.965] [LOG]   Starting server on port 8080 ...
                    [02.01.2024 22:52.56.423] [LOG]   Server started ...
                    [02.01.2024 22:52.56.426] [LOG]   Connecting socket for: updatenotification
                    [02.01.2024 22:52.56.429] [LOG]   Starting module helper: updatenotification
                    [02.01.2024 22:52.56.431] [LOG]   Connecting socket for: calendar
                    [02.01.2024 22:52.56.433] [LOG]   Starting node helper for: calendar
                    [02.01.2024 22:52.56.434] [LOG]   Connecting socket for: newsfeed
                    [02.01.2024 22:52.56.436] [LOG]   Starting node helper for: newsfeed
                    [02.01.2024 22:52.56.438] [LOG]   Sockets connected & modules started ...
                    [02.01.2024 22:52.56.466] [LOG]   Launching application.
                    [02.01.2024 22:53.00.880] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/*****/basic.ics - Interval: 60000
                    [02.01.2024 22:53.01.212] [LOG]   Create new newsfetcher for url: http://feeds.bbci.co.uk/news/world/rss.xml - Interval: 300000
                    [02.01.2024 22:53.01.230] [LOG]   Create new newsfetcher for url: https://www.francetvinfo.fr/titres.rss - Interval: 300000
                    [02.01.2024 22:53.01.240] [INFO]  updatenotification: Updater Class Loaded!
                    [02.01.2024 22:53.01.242] [INFO]  updatenotification: Checking PM2 using...
                    [02.01.2024 22:53.01.246] [INFO]  Checking git for module: MagicMirror
                    [02.01.2024 22:53.05.311] [INFO]  updatenotification: You are not using pm2
                    [02.01.2024 22:53.05.398] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                    [02.01.2024 22:53.05.608] [INFO]  Newsfeed-Fetcher: reloadInterval set to ttl=900000 for url http://feeds.bbci.co.uk/news/world/rss.xml
                    [02.01.2024 22:53.06.250] [INFO]  Newsfeed-Fetcher: Broadcasting 50 items.
                    [02.01.2024 22:56.58.233] [INFO]  Calendar-Fetcher: Broadcasting 241 events from https://calendar.google.com/calendar/ical/*****/basic.ics.
                    [02.01.2024 23:01.53.895] [INFO]  Calendar-Fetcher: Broadcasting 241 events from https://calendar.google.com/calendar/ical/*****/basic.ics.
                    [02.01.2024 23:01.54.614] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                    Indeed, it says 241 events were found, but I meant that despite that the mirror shows “Loading…” in the calendar module.
                      sdetweil @avano
                      fun times…
                      can you open the developers window, ctrl-shift-i on the MM screen (on pi or remote browser if you have that configured)
                      select the console tab, and put calendar in the filter field to see if there are any errors shown on the browser side
                        avano
                        @sdetweil I’ll give this a try in the morning, but thanks a lot for the help!
                          avano
                          @sdetweil, I checked the browser log. At first, I saw errors about not finding the custom.css.
                          So I created one from the sample css file. Now I only see the remaining issue.
                          Any idea? Should I consider a fresh install instead?
                          S 3 Replies Last reply Reply Quote 0
                            sdetweil @avano
                            @avano its a noise error… if the file doesn’t exist, then its an error when trying to load it, its hard coded in the MM shell web page…
                            just create it and the error will go away
                            touch ~/MagicMirror/css/custom.css
                            if u had used my script to install, I would have done that for you
                            also many people don’t know how to create a file, …
                            so I tell them to add styles there and the file is missing and they don’t know what to do
                              sdetweil @avano
                              @avano ok, no crashes in the browser side…
                                sdetweil @avano
                                @avano can u show the cal config, just xxx out the url
                                  avano
                                  @sdetweil, do you mean from the config.js? If so, it is in the first post of this thread.
                                    sdetweil @avano
        limitDays: 30,
        maximumEntries: 15,
        wrapEvents: true,
        hidePrivate: true
                                    can u comment these out , add // in front
                                      @avano alomao try this
                                      cd ~/MagicMirror
                                      npm install electron@28.1.1
                                        avano @sdetweil
                                        @sdetweil I tried both the above suggestions, but no change.
                                        However, I enabled the DEBUG mode and saw that some events in my calendar took a lot longer to be processed. These events are open-ended events in my Google calendar. They look like the below extract. So I removed them temporarily.
                                        I no longer get the Warning: vkCreateInstance: Found no drivers!
                                        The calendar now loads.
                                        But I’ll try to re-create them and see if they are formatted the same way.
                                        [06.01.2024 17:35.14.090] [DEBUG] Event:
                                        {"type":"VEVENT","params":[],"start":"2021-01-19T13:00:00.000Z","datetype":"date-time","end":"2021-01-19T14:00:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"tzid":"Europe/Paris","dtstart":"2021-01-19T13:00:00.000Z","freq":0,"wkst":{"weekday":1}},"options":{"freq":0,"dtstart":"2021-01-19T13:00:00.000Z","interval":1,"wkst":1,"count":null,"until":null,"tzid":"Europe/Paris","bysetpos":null,"bymonth":[1],"bymonthday":[19],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":null,"bynweekday":null,"byhour":[13],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2024-01-06T16:34:29.000Z","uid":"clhj8p9p6gqmab9ncoq3ab9k68p3ab9pcgq6cb9kcgr3acpn70o62dpkcg@google.com","created":"2021-01-19T15:21:58.000Z","lastmodified":"2021-01-19T15:22:30.000Z","sequence":"1","status":"CONFIRMED","summary":"Event xyz","transparency":"OPAQUE","method":"PUBLISH"}
                                        [06.01.2024 17:35.14.091] [DEBUG] start: Tue Jan 19 2021 14:00:00 GMT+0100 (Central European Standard Time)
                                        [06.01.2024 17:35.14.091] [DEBUG] end:: Tue Jan 19 2021 15:00:00 GMT+0100 (Central European Standard Time)
                                        [06.01.2024 17:35.14.091] [DEBUG] duration: 3600000
                                        [06.01.2024 17:35.14.092] [DEBUG] title: Event xyz
                                        [06.01.2024 17:35.14.092] [DEBUG] Search for recurring events between: Sat Jan 06 2024 17:35:14 GMT+0100 (Central European Standard Time) and Sat Jan 04 2025 23:59:59 GMT+0100 (Central European Standard Time)
                                        [06.01.2024 17:35.40.211] [DEBUG] Title: Event xyz, with dates: [null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,
                                        ... I removed about 8000 "nulls" here...
                                        null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null]
                                        [06.01.2024 17:35.40.243] [DEBUG] event.recurrences: undefined
                                        [06.01.2024 17:35.40.243] [DEBUG] Processing entry...
                                          sdetweil @avano
                                          @avano cool… any chance u can find the VEVENT in the downloaded ICS file
                                          curl -sL cal_url >someicsfile.txt
                                          my fix should remove all those null entries…
                                          and the vulcan thing is a bug in electron putting out a spurious message
                                          can u edit
                                          ~/MagicMirror/modules/default/calendar/calendarfetcherutils.js
                                          and look at line 293
                                          					let dates = rule.between(pastLocal, futureLocal, true, limitFunction);
                                          					Log.debug(`Title: ${event.summary}, with dates: ${JSON.stringify(dates)}`);
                                          					dates = dates.filter((d) => {   // my fix starts here
                                          						if (JSON.stringify(d) === "null") return false;
                                          						else return true;
                                            avano
                                            @sdetweil I put back an open-ended event into my calendar, here is the VEVENT: (the calendar no longer loads, and the warning is back.)
                                            BEGIN:VEVENT
                                            DTSTART;TZID=Europe/Zurich:20240119T100000
                                            DTEND;TZID=Europe/Zurich:20240119T110000
                                            RRULE:FREQ=YEARLY
                                            DTSTAMP:20240107T194354Z
                                            UID:abcxyz4@google.com
                                            CREATED:20240107T194031Z
                                            LAST-MODIFIED:20240107T194031Z
                                            SEQUENCE:0
                                            STATUS:CONFIRMED
                                            SUMMARY:Event xyz
                                            TRANSP:OPAQUE
                                            END:VEVENT
                                            I looked into ~/MagicMirror/modules/default/calendar/calendarfetcherutils.js line 293, it looks like I have your fix already:
                                            Log.debug(`Search for recurring events between: ${pastLocal} and ${futureLocal}`);
                                            	else return true;
