    Calendar not loading after update to 2.26
    22 Posts 2 Posters 9.9k Views 2 Watching
    • A
      avano
      @sdetweil I’ll give this a try in the morning, but thanks a lot for the help!
      • A
        avano
        @sdetweil, I checked the browser log. At first, I saw errors about not finding the custom.css.
        So I created one from the sample css file. Now I only see the remaining issue.
        Any idea? Should I consider a fresh install instead?
        S 3 Replies Last reply
          sdetweil @avano
          @avano its a noise error… if the file doesn’t exist, then its an error when trying to load it, its hard coded in the MM shell web page…
          just create it and the error will go away
          touch ~/MagicMirror/css/custom.css
          if u had used my script to install, I would have done that for you
          also many people don’t know how to create a file, …
          so I tell them to add styles there and the file is missing and they don’t know what to do
            sdetweil @avano
            @avano ok, no crashes in the browser side…
              sdetweil @avano
              @avano can u show the cal config, just xxx out the url
              • A
                avano
                @sdetweil, do you mean from the config.js? If so, it is in the first post of this thread.
                  sdetweil @avano
                  @avano said in Calendar not loading after update to 2.26:
                                              limitDays: 30,
                                              maximumEntries: 15,
                                              wrapEvents: true,
                                              hidePrivate: true
                  can u comment these out , add // in front
                    @avano alomao try this
                    npm install electron@28.1.1
                    A 1 Reply Last reply
                    • A
                      avano @sdetweil
                      @sdetweil I tried both the above suggestions, but no change.
                      However, I enabled the DEBUG mode and saw that some events in my calendar took a lot longer to be processed. These events are open-ended events in my Google calendar. They look like the below extract. So I removed them temporarily.
                      I no longer get the Warning: vkCreateInstance: Found no drivers!
                      The calendar now loads.
                      But I’ll try to re-create them and see if they are formatted the same way.
                      [06.01.2024 17:35.14.090] [DEBUG] Event:
                      {"type":"VEVENT","params":[],"start":"2021-01-19T13:00:00.000Z","datetype":"date-time","end":"2021-01-19T14:00:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"tzid":"Europe/Paris","dtstart":"2021-01-19T13:00:00.000Z","freq":0,"wkst":{"weekday":1}},"options":{"freq":0,"dtstart":"2021-01-19T13:00:00.000Z","interval":1,"wkst":1,"count":null,"until":null,"tzid":"Europe/Paris","bysetpos":null,"bymonth":[1],"bymonthday":[19],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":null,"bynweekday":null,"byhour":[13],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2024-01-06T16:34:29.000Z","uid":"clhj8p9p6gqmab9ncoq3ab9k68p3ab9pcgq6cb9kcgr3acpn70o62dpkcg@google.com","created":"2021-01-19T15:21:58.000Z","lastmodified":"2021-01-19T15:22:30.000Z","sequence":"1","status":"CONFIRMED","summary":"Event xyz","transparency":"OPAQUE","method":"PUBLISH"}
                      [06.01.2024 17:35.14.091] [DEBUG] start: Tue Jan 19 2021 14:00:00 GMT+0100 (Central European Standard Time)
                      [06.01.2024 17:35.14.091] [DEBUG] end:: Tue Jan 19 2021 15:00:00 GMT+0100 (Central European Standard Time)
                      [06.01.2024 17:35.14.091] [DEBUG] duration: 3600000
                      [06.01.2024 17:35.14.092] [DEBUG] title: Event xyz
                      [06.01.2024 17:35.14.092] [DEBUG] Search for recurring events between: Sat Jan 06 2024 17:35:14 GMT+0100 (Central European Standard Time) and Sat Jan 04 2025 23:59:59 GMT+0100 (Central European Standard Time)
                      [06.01.2024 17:35.40.211] [DEBUG] Title: Event xyz, with dates: [null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,
                      ... I removed about 8000 "nulls" here...
                      null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null]
                      [06.01.2024 17:35.40.243] [DEBUG] event.recurrences: undefined
                      [06.01.2024 17:35.40.243] [DEBUG] Processing entry...
                        sdetweil @avano
                        @avano cool… any chance u can find the VEVENT in the downloaded ICS file
                        curl -sL cal_url >someicsfile.txt
                        my fix should remove all those null entries…
                        and the vulcan thing is a bug in electron putting out a spurious message
                        can u edit
                        ~/MagicMirror/modules/default/calendar/calendarfetcherutils.js
                        and look at line 293
                        					let dates = rule.between(pastLocal, futureLocal, true, limitFunction);
                        					Log.debug(`Title: ${event.summary}, with dates: ${JSON.stringify(dates)}`);
                        					dates = dates.filter((d) => {   // my fix starts here
                        						if (JSON.stringify(d) === "null") return false;
                        						else return true;
                        • A
                          avano
                          @sdetweil I put back an open-ended event into my calendar, here is the VEVENT: (the calendar no longer loads, and the warning is back.)
                          BEGIN:VEVENT
                          DTSTART;TZID=Europe/Zurich:20240119T100000
                          DTEND;TZID=Europe/Zurich:20240119T110000
                          RRULE:FREQ=YEARLY
                          DTSTAMP:20240107T194354Z
                          UID:abcxyz4@google.com
                          CREATED:20240107T194031Z
                          LAST-MODIFIED:20240107T194031Z
                          SEQUENCE:0
                          STATUS:CONFIRMED
                          SUMMARY:Event xyz
                          TRANSP:OPAQUE
                          END:VEVENT
                          I looked into ~/MagicMirror/modules/default/calendar/calendarfetcherutils.js line 293, it looks like I have your fix already:
                          Log.debug(`Search for recurring events between: ${pastLocal} and ${futureLocal}`);
                          	else return true;
                          • A
                            avano
                            Apologies, I must have refreshed something since my last post, because the calendar now loads including my open-ended event.
                            I updated my config.js back to it’s initial state (i.e. uncommenting all our tests, removed DEBUG mode), and I started the app with PM2 instead of “npm start”, but I can’t think of any other change I made.
                            Do you want me to run some more tests to try and identify the actual issue?
                            In any case, thanks for all your help.
                              sdetweil @avano
                              @avano no. I’ll look at the event and set it back to 2013 start.
                              I put in the fix cause there is a bug in rule with old events, where the count has expired…
