    MMM-CalendarExt3 stopped working
    14 Posts 3 Posters 4.4k Views 3 Watching
      sdetweil @redink
      @redink doah! I updated post there
      calendarfetcher.js
        redink @sdetweil
        @sdetweil Thank you, but that didn’t seem to help. I use this script to update MM https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh
        So, I wonder if something isn’t getting updated.
          sdetweil @redink
          @redink can u send me the ~/MagicMirror/installers/upgrade.log
          ny userid at gmail
            redink @sdetweil
            @sdetweil thanks for taking the time. It’s sent.
              sdetweil @redink
              @redink so, the upgrade went perfectly. no issues.
              not sure what is going on yet.
              can you show output of
              ip addr
                redink @sdetweil
                1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                    inet 127.0.0.1/8 scope host lo
                       valid_lft forever preferred_lft forever
                    inet6 ::1/128 scope host
                2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
                    link/ether b8:27:eb:ee:09:64 brd ff:ff:ff:ff:ff:ff
                3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
                    link/ether 00:0f:60:04:20:d4 brd ff:ff:ff:ff:ff:ff
                    inet 192.168.1.100/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
                       valid_lft 45176sec preferred_lft 34376sec
                    inet6 fe80::3e7d:5421:775:6ad0/64 scope link
                  sdetweil @redink
                  @redink can you use the Raspi os config to turn off ipv6 addressing for this adapter?
                  one of the workarounds deals with incorrectly picking the network address to connect with given the client network…
                    redink @sdetweil
                    @sdetweil while messing with raspi-config over ssh, magicmirror lost connection to my wifi. I had to connect a keyboard and reconnect. But, before going back to your last suggestion I did two other things. I updated pm2 (as suggested by some other post). And in the browser console I noticed that I had an error about not being able to locate “CX3_shared.mjs”. I checked the MMM-CalendarExt3 repo, and found that file CX3_Shared/CX3_shared.mjs, which for some reason wasn’t getting pulled by a git pull. I manually copied it in, and the calendar sort of started working.
                    I should have paid better attention to the documentation, because I would have seen that I needed to run git submodule update --init --recursive to update the submodule.
                    The reason I say “sort of” is because my family calendar doesn’t show some repeating events, but I need to dig deeper into that.
                    I really appreciate all your help.
                      sdetweil @redink
                      @redink the submodule problem is because you didn’t run npm install on the Ext3 module.
                      ext3 gets its events from the default calendar.
                        redink @sdetweil
                        @sdetweil yeah, i probably just did a git pull
