    Compliments module has stopped working
    16 Posts 2 Posters 1.9k Views 2 Watching
    • G Offline
      geekhouri @sdetweil
      @sdetweil thanks again. Saved the file, flushed the logs rebooted and new log is below no new errrors and i think you previously stated the errors below cant be hidden. . Still no Compliments working (i’m at a loss now)
      0|mm       | Warning: vkCreateInstance: Found no drivers!
      0|mm       | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
      0|mm       |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/v        ulkan/VulkanError.cpp:88)
      0|mm       |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vul        kan/BackendVk.cpp:458)
      0|mm       |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/Ba        ckendVk.cpp:344)
      0|mm       |     at Create (../../third_party/dawn/src/dawn/native/vulkan/Backen        dVk.cpp:266)
      0|mm       |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/Ba        ckendVk.cpp:521)
      0|mm       |
        sdetweil @geekhouri
        @geekhouri ok, lets stop using pm2…
        pm2 stop all
        then
        cd ~/MagicMirror
        npm start
        wait
        if you are doing this on the MM screen
        ctrl-q to stop mm (with pm2, it would restart it immediately… thats is job)
        so, see anything in the output??
        I used your config and it worked (on v2.26) without any issues
        • G Offline
          geekhouri @sdetweil
          @sdetweil followed instructions however do not see anything in the output as below:
          > magicmirror@2.26.0 start
          [24.01.2024 12:20.55.171] [LOG]   Starting MagicMirror: v2.26.0
          [24.01.2024 12:20.55.183] [LOG]   Loading config ...
          [24.01.2024 12:20.55.193] [DEBUG] config template file not exists, no envsubst
          [24.01.2024 12:20.55.205] [LOG]   Loading module helpers ...
          [24.01.2024 12:20.55.209] [LOG]   No helper found for module: alert.
          [24.01.2024 12:20.55.213] [LOG]   No helper found for module: clock.
          [24.01.2024 12:20.55.689] [LOG]   Initializing new module helper ...
          [24.01.2024 12:20.55.690] [LOG]   Module helper loaded: calendar
          [24.01.2024 12:20.55.694] [LOG]   No helper found for module: compliments.
          [24.01.2024 12:20.56.724] [LOG]   Initializing new module helper ...
          [24.01.2024 12:20.56.726] [LOG]   Module helper loaded: MMM-DailyBibleVerse
          [24.01.2024 12:20.56.857] [LOG]   Initializing new module helper ...
          [24.01.2024 12:20.56.858] [LOG]   Module helper loaded: MMM-OpenWeatherMapForeca        st
          [24.01.2024 12:20.56.862] [LOG]   No helper found for module: MMM-GoogleTrafficT        imes.
          [24.01.2024 12:20.57.729] [LOG]   Initializing new module helper ...
          [24.01.2024 12:20.57.730] [LOG]   Module helper loaded: MMM-WordOfTheDay
          [24.01.2024 12:20.57.736] [LOG]   Initializing new module helper ...
          [24.01.2024 12:20.57.737] [LOG]   Module helper loaded: MMM-GoogleSheets
          [24.01.2024 12:20.58.082] [LOG]   Initializing new module helper ...
          [24.01.2024 12:20.58.083] [LOG]   Module helper loaded: newsfeed
          [24.01.2024 12:20.58.084] [LOG]   All module helpers loaded.
          [24.01.2024 12:20.58.102] [LOG]   Starting server on port 8080 ...
          [24.01.2024 12:20.58.926] [LOG]   Server started ...
          [24.01.2024 12:20.58.929] [LOG]   Connecting socket for: calendar
          [24.01.2024 12:20.58.930] [LOG]   Starting node helper for: calendar
          [24.01.2024 12:20.58.932] [LOG]   Connecting socket for: MMM-DailyBibleVerse
          [24.01.2024 12:20.58.933] [LOG]   Started node_helper.js for MMM-DailyBibleVerse        .
          [24.01.2024 12:20.58.934] [LOG]   Connecting socket for: MMM-OpenWeatherMapForec        ast
          [24.01.2024 12:20.58.936] [LOG]   ====================== Starting node_helper fo        r module [MMM-OpenWeatherMapForecast]
          [24.01.2024 12:20.58.937] [LOG]   Connecting socket for: MMM-WordOfTheDay
          [24.01.2024 12:20.58.938] [LOG]   Starting module helper: MMM-WordOfTheDay
          [24.01.2024 12:20.58.939] [LOG]   Connecting socket for: MMM-GoogleSheets
          [24.01.2024 12:20.58.940] [LOG]   ====================== Starting node_helper fo        r module [MMM-GoogleSheets]
          [24.01.2024 12:20.58.941] [LOG]   Connecting socket for: newsfeed
          [24.01.2024 12:20.58.942] [LOG]   Starting node helper for: newsfeed
          [24.01.2024 12:20.58.944] [LOG]   Sockets connected & modules started ...
          [24.01.2024 12:20.59.084] [LOG]   Launching application.
          [24.01.2024 12:21.06.600] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/%40gmail.com/public/basic.ics - Interval: 604800000
          [24.01.2024 12:21.07.000] [LOG]   MMM-DailyBibleVerse node helper received a socket notification: START - Payload: NIV
          [24.01.2024 12:21.07.031] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
          [24.01.2024 12:21.07.046] [LOG]   Create new newsfetcher for url: https://www.9news.com.au/rss - Interval: 300000
          [24.01.2024 12:21.07.054] [LOG]   Create new newsfetcher for url: https://www.smh.com.au/rss/feed.xml - Interval: 300000
          [24.01.2024 12:21.08.318] [INFO]  Newsfeed-Fetcher: Broadcasting 17 items.
          [24.01.2024 12:21.08.380] [LOG]   {"votd":{"text":"“If any of you lacks wisdom, you should ask God, who gives generously to all without finding fault, and it will be given to you.”","content":"If any of you lacks wisdom, you should ask God, who gives generously to all without finding fault, and it will be given to you.","display_ref":"James 1:5","reference":"James 1:5","permalink":"https:\/\/www.biblegateway.com\/passage\/?search=James%201:5&version=NIV","copyright":" ","copyrightlink":"https:\/\/www.biblegateway.com\/versions\/index.php?action=getVersionInfo&vid=31&lang=2","audiolink":"https:\/\/www.biblegateway.com\/audio\/mclean\/niv\/Jas.1.5","day":"23","month":"01","year":"2024","version":"New International Version","version_id":"NIV","merchandising":""}}
          [24.01.2024 12:21.09.117] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
          [24.01.2024 12:21.09.136] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
          [24.01.2024 12:21.11.958] [INFO]  Calendar-Fetcher: Broadcasting 51 events from https://calendar.google.com/calendar/ical/%40gmail.com/public/basic.ics.
              at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
              at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
              at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
              at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
              at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
          Can i reinstall the compliments module?
            sdetweil @geekhouri
            @geekhouri do
            cd ~/MagicMirror
            git checkout modules/default/compliments/compliments.js
            • G Offline
              geekhouri @sdetweil
              @sdetweil said in Compliments module has stopped working:
              And that has fixed it… very strange. Thanks @sdetweil
                sdetweil @geekhouri
                @geekhouri glad you got it fixed
