    Compliments module has stopped working
    16 Posts 2 Posters 2.6k Views 2 Watching
      sdetweil @geekhouri
      @geekhouri said in Compliments module has stopped working:
      Line 68 column 4: Parsing error: Unexpected token config
      yes, 99% of the time that means the line before was missing a trailing comma (which means more lines coming for this item)
      your last 4 lines of the compliments list do not have the trailing comma
      and the position line
      just because I didn’t include it my text above doesn’t mean it’s not required…
      G 1 Reply Last reply
      • G
        geekhouri @sdetweil
        @sdetweil made those changes and MM is working again however i the compliments are still not visible? Any thoughts?
          sdetweil @geekhouri
          @geekhouri also missing a close } before the last one
                                  module: "compliments",
                                  position: "top_bar",
                                   compliments: {
                                           anytime: ["Be Smart, Be Kind, Be Like Jesus!"],
                                          morning: ["Good morning!", "Enjoy your day!", "How was school"],
                                          afternoon: ["How was School?", "Finish Your homework?"],
                                          evening: ["Sweet Dreams", "You look nice!", "Ready for School"],
                                          "....-01-12": ["Happy new year!"],
                                          "....02-12": ["Happy Birthday E!"],
                                          "....03-12": ["Happy Birthday Z!"],
                                          "....05-12": ["Happy Birthday G!"],
                                          }  // end of compliments
                                }  // end of config
                    } // end of module
          you should see the error where you start mm…
          if using pm2, then
          pm2 logs --lines=50
          • G
            geekhouri @sdetweil
            @sdetweil still nothing, here is my code in full and the pm2 logs:
                                     compliments: {
                                                    } //end of compliments
                                            } //end of config
                            }, //end of module
            Pm2 logs as follows:
            0|mm       |     at Object..js (node:internal/modules/cjs/loader:1326:10)
            0|mm       |     at Module.load (node:internal/modules/cjs/loader:1126:32)
            0|mm       |     at node:internal/modules/cjs/loader:967:12
            0|mm       | Warning: vkCreateInstance: Found no drivers!
            0|mm       | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
            0|mm       |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/v        ulkan/VulkanError.cpp:88)
            0|mm       |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vul        kan/BackendVk.cpp:458)
            0|mm       |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/Ba        ckendVk.cpp:344)
            0|mm       |     at Create (../../third_party/dawn/src/dawn/native/vulkan/Backen        dVk.cpp:266)
            0|mm       |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/Ba        ckendVk.cpp:521)
            0|mm       |
            0|mm       | /home/gkhouri/MagicMirror/node_modules/electron/dist/electron exite        d with signal SIGINT
            0|mm       | [24.01.2024 01:29.00.569] [ERROR] WARNING! Could not validate confi        g file. Starting with default configuration. Please correct syntax errors at or        above this line: /home/gkhouri/MagicMirror/config/config.js:68
            0|mm       |                    config: {
            0|mm       |                    ^^^^^^
            0|mm       |
            0|mm       | SyntaxError: Unexpected identifier 'config'
            0|mm       |     at internalCompileFunction (node:internal/vm:73:18)
            0|mm       |     at wrapSafe (node:internal/modules/cjs/loader:1185:20)
            0|mm       |     at Module._compile (node:internal/modules/cjs/loader:1227:27)
            0|mm       |     at Function._load (node:electron/js2c/asar_bundle:2:13327)
            0|mm       |     at Module.require (node:internal/modules/cjs/loader:1150:19)
            0|mm       |     at require (node:internal/modules/cjs/helpers:121:18)
            0|mm       |     at loadConfig (/home/gkhouri/MagicMirror/js/app.js:118:14)
            0|mm       |     at App.start (/home/gkhouri/MagicMirror/js/app.js:248:18)
            0|mm       |     at Object.<anonymous> (/home/gkhouri/MagicMirror/js/electron.js        :192:7)
            0|mm       |     at Module._compile (node:internal/modules/cjs/loader:1271:14)
            0|mm       |
            0|mm       |
              sdetweil @geekhouri
              0|mm | config: {
              0|mm | ^^^^^^
              0|mm |
              0|mm | SyntaxError: Unexpected identifier ‘config’
              I can only assume you haven’t saved the updated config… (I do that sometimes…oops)
              • G
                geekhouri @sdetweil
                @sdetweil thanks again. Saved the file, flushed the logs rebooted and new log is below no new errrors and i think you previously stated the errors below cant be hidden. . Still no Compliments working (i’m at a loss now)
                0|mm       |
                  sdetweil @geekhouri
                  @geekhouri ok, lets stop using pm2…
                  pm2 stop all
                  then
                  npm start
                  wait
                  if you are doing this on the MM screen
                  ctrl-q to stop mm (with pm2, it would restart it immediately… thats is job)
                  so, see anything in the output??
                  I used your config and it worked (on v2.26) without any issues
                  • G
                    geekhouri @sdetweil
                    @sdetweil followed instructions however do not see anything in the output as below:
                    > magicmirror@2.26.0 start
                    [24.01.2024 12:20.55.171] [LOG]   Starting MagicMirror: v2.26.0
                    [24.01.2024 12:20.55.183] [LOG]   Loading config ...
                    [24.01.2024 12:20.55.193] [DEBUG] config template file not exists, no envsubst
                    [24.01.2024 12:20.55.205] [LOG]   Loading module helpers ...
                    [24.01.2024 12:20.55.209] [LOG]   No helper found for module: alert.
                    [24.01.2024 12:20.55.213] [LOG]   No helper found for module: clock.
                    [24.01.2024 12:20.55.689] [LOG]   Initializing new module helper ...
                    [24.01.2024 12:20.55.690] [LOG]   Module helper loaded: calendar
                    [24.01.2024 12:20.55.694] [LOG]   No helper found for module: compliments.
                    [24.01.2024 12:20.56.724] [LOG]   Initializing new module helper ...
                    [24.01.2024 12:20.56.726] [LOG]   Module helper loaded: MMM-DailyBibleVerse
                    [24.01.2024 12:20.56.857] [LOG]   Initializing new module helper ...
                    [24.01.2024 12:20.56.858] [LOG]   Module helper loaded: MMM-OpenWeatherMapForeca        st
                    [24.01.2024 12:20.56.862] [LOG]   No helper found for module: MMM-GoogleTrafficT        imes.
                    [24.01.2024 12:20.57.729] [LOG]   Initializing new module helper ...
                    [24.01.2024 12:20.57.730] [LOG]   Module helper loaded: MMM-WordOfTheDay
                    [24.01.2024 12:20.57.736] [LOG]   Initializing new module helper ...
                    [24.01.2024 12:20.57.737] [LOG]   Module helper loaded: MMM-GoogleSheets
                    [24.01.2024 12:20.58.082] [LOG]   Initializing new module helper ...
                    [24.01.2024 12:20.58.083] [LOG]   Module helper loaded: newsfeed
                    [24.01.2024 12:20.58.084] [LOG]   All module helpers loaded.
                    [24.01.2024 12:20.58.102] [LOG]   Starting server on port 8080 ...
                    [24.01.2024 12:20.58.926] [LOG]   Server started ...
                    [24.01.2024 12:20.58.929] [LOG]   Connecting socket for: calendar
                    [24.01.2024 12:20.58.930] [LOG]   Starting node helper for: calendar
                    [24.01.2024 12:20.58.932] [LOG]   Connecting socket for: MMM-DailyBibleVerse
                    [24.01.2024 12:20.58.933] [LOG]   Started node_helper.js for MMM-DailyBibleVerse        .
                    [24.01.2024 12:20.58.934] [LOG]   Connecting socket for: MMM-OpenWeatherMapForec        ast
                    [24.01.2024 12:20.58.936] [LOG]   ====================== Starting node_helper fo        r module [MMM-OpenWeatherMapForecast]
                    [24.01.2024 12:20.58.937] [LOG]   Connecting socket for: MMM-WordOfTheDay
                    [24.01.2024 12:20.58.938] [LOG]   Starting module helper: MMM-WordOfTheDay
                    [24.01.2024 12:20.58.939] [LOG]   Connecting socket for: MMM-GoogleSheets
                    [24.01.2024 12:20.58.940] [LOG]   ====================== Starting node_helper fo        r module [MMM-GoogleSheets]
                    [24.01.2024 12:20.58.941] [LOG]   Connecting socket for: newsfeed
                    [24.01.2024 12:20.58.942] [LOG]   Starting node helper for: newsfeed
                    [24.01.2024 12:20.58.944] [LOG]   Sockets connected & modules started ...
                    [24.01.2024 12:20.59.084] [LOG]   Launching application.
                    [24.01.2024 12:21.06.600] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/%40gmail.com/public/basic.ics - Interval: 604800000
                    [24.01.2024 12:21.07.000] [LOG]   MMM-DailyBibleVerse node helper received a socket notification: START - Payload: NIV
                    [24.01.2024 12:21.07.031] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                    [24.01.2024 12:21.07.046] [LOG]   Create new newsfetcher for url: https://www.9news.com.au/rss - Interval: 300000
                    [24.01.2024 12:21.07.054] [LOG]   Create new newsfetcher for url: https://www.smh.com.au/rss/feed.xml - Interval: 300000
                    [24.01.2024 12:21.08.318] [INFO]  Newsfeed-Fetcher: Broadcasting 17 items.
                    [24.01.2024 12:21.08.380] [LOG]   {"votd":{"text":"&ldquo;If any of you lacks wisdom, you should ask God, who gives generously to all without finding fault, and it will be given to you.&rdquo;","content":"If any of you lacks wisdom, you should ask God, who gives generously to all without finding fault, and it will be given to you.","display_ref":"James 1:5","reference":"James 1:5","permalink":"https:\/\/www.biblegateway.com\/passage\/?search=James%201:5&amp;version=NIV","copyright":" ","copyrightlink":"https:\/\/www.biblegateway.com\/versions\/index.php?action=getVersionInfo&amp;vid=31&amp;lang=2","audiolink":"https:\/\/www.biblegateway.com\/audio\/mclean\/niv\/Jas.1.5","day":"23","month":"01","year":"2024","version":"New International Version","version_id":"NIV","merchandising":""}}
                    [24.01.2024 12:21.09.117] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
                    [24.01.2024 12:21.09.136] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                    [24.01.2024 12:21.11.958] [INFO]  Calendar-Fetcher: Broadcasting 51 events from https://calendar.google.com/calendar/ical/%40gmail.com/public/basic.ics.
                        at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                        at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                        at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                        at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                        at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                    Can i reinstall the compliments module?
                      sdetweil @geekhouri
                      @geekhouri do
                      git checkout modules/default/compliments/compliments.js
                      • G
                        geekhouri @sdetweil
                        @sdetweil said in Compliments module has stopped working:
                        And that has fixed it… very strange. Thanks @sdetweil
                          sdetweil @geekhouri
                          @geekhouri glad you got it fixed
