    Compliments module has stopped working
    16 Posts 2 Posters 2.5k Views 2 Watching
    • G Offline
      geekhouri
      I recently noticed the compliments are no longer showing up on my MM. I have tried troubleshooting, checking for updates etc… but cannot seem to contain the issue. My config and compliments.js is listed below:
                              module: "compliments",
                              position: "top_bar"
      /* MagicMirror²
       * Module: Compliments
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      Module.register("compliments", {
              // Module config defaults.
              defaults: {
                      compliments: {
                              anytime: ["Be Smart, Be Kind, Be Like Jesus!"],
                              morning: ["Good morning!", "Enjoy your day!", "How was your sleep?"],
                              afternoon: ["How was School?", "Finish Your homework?", "Looking good today!"],
                              evening: ["Sweet Dreams", "You look nice!", "Ready for Bed"],
                      updateInterval: 30000,
                      remoteFile: null,
                      fadeSpeed: 4000,
                      morningStartTime: 3,
                      morningEndTime: 12,
                      afternoonStartTime: 12,
                      afternoonEndTime: 17,
                      random: true
              lastIndexUsed: -1,
              // Set currentweather from module
              currentWeatherType: "",
              // Define required scripts.
              getScripts () {
                      return ["moment.js"];
              // Define start sequence.
              async start () {
                      Log.info(`Starting module: ${this.name}`);
                      this.lastComplimentIndex = -1;
                      if (this.config.remoteFile !== null) {
                              const response = await this.loadComplimentFile();
                              this.config.compliments = JSON.parse(response);
                              this.updateDom();
                      // Schedule update timer.
                      setInterval(() => {
                              this.updateDom(this.config.fadeSpeed);
                      }, this.config.updateInterval);
               * Generate a random index for a list of compliments.
               * @param {string[]} compliments Array with compliments.
               * @returns {number} a random index of given array
              randomIndex (compliments) {
                      if (compliments.length === 1) {
                              return 0;
                      const generate = function () {
                              return Math.floor(Math.random() * compliments.length);
                      let complimentIndex = generate();
                      while (complimentIndex === this.lastComplimentIndex) {
                      this.lastComplimentIndex = complimentIndex;
                      return complimentIndex;
      PM2 Logs as follows:
      /home/88888/.pm2/logs/mm-error.log last 15 lines:
      0|mm       | [15270:0123/174828.158857:ERROR:connection.cc(46)] X connection error received.
      0|mm       | [15270:0123/174828.160623:ERROR:connection.cc(46)] X connection error received.
      0|mm       | /home/88888/MagicMirror/mm.sh: line 1: cd: ./MagicMirror: No such file or directory
      0|mm       | Warning: vkCreateInstance: Found no drivers!
      0|mm       | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
      0|mm       |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
      0|mm       |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
      0|mm       |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
      0|mm       |     at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
      0|mm       |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
      Thanks in advance
      • G Offline
        geekhouri @sdetweil
        @sdetweil said in Compliments module has stopped working:
        git checkout modules/default/compliments/compliments.js
        And that has fixed it… very strange. Thanks @sdetweil
          sdetweil @geekhouri
          @geekhouri 1st. you never edit our files.
          all config goes in config.js
          just because we arent showing all the config in the starter config.js doesn’t change this
          every module has the same general layout
            module: name,
             position: somewhere,
             config:{   // if needed to add or override the defaults for this module
                  xxx:yhyy,     module specific config properties
                   qqw:700
          next, what is the mm.sh error?, show me that file
          the Vulcan errors are a noise bug in electron we cannot hide.
          • G Offline
            geekhouri @sdetweil
            @sdetweil thanks for your reply. Just to be clear you mean i should not edit the compliments.js file and any configs should be in the config.js file (Sorry probably a newbie question but im still learning)
            The mm.sh code is listed below:
            cd ./MagicMirror
            DISPLAY=:0 npm start
            I hope this is what you are after.
              sdetweil @geekhouri
              @geekhouri the mm.sh should be
              ~ means logged on users home folder
              config.js, yes
                   module:"compliments",
                   position:"....."
                    config:{
                         compliments:   your compliments config {.. }
              the system design is
              whatever is in config.js, overrides/replaces what is defined in the module defaults section
              • G Offline
                geekhouri @sdetweil
                @sdetweil thanks for your feedback, i have updated my config.js file but now i run into the config file error and MM does not load. Code is below as is the error after running config: check
                                        position: "top_bar"
                                         compliments: {
                                                morning: ["Good morning!", "Enjoy your day!", "How was school"],
                                                afternoon: ["How was School?", "Finish Your homework?"],
                                                evening: ["Sweet Dreams", "You look nice!", "Ready for School"],
                                                "....-01-12": ["Happy new year!"]
                                                "....02-12": ["Happy Birthday E!"]
                                                "....03-12": ["Happy Birthday Z!"]
                                                "....05-12": ["Happy Birthday G!"]
                npm run config:check
                [24.01.2024 01:07.25.065] [INFO]  Checking file...  /home/gkhouri/MagicMirror/config/config.js
                [24.01.2024 01:07.25.165] [ERROR] Your configuration file contains syntax errors :(
                [24.01.2024 01:07.25.167] [ERROR] Line 68 column 4: Parsing error: Unexpected token config
                Line 68 is config: { …
                Thanks again
                  sdetweil @geekhouri
                  @geekhouri said in Compliments module has stopped working:
                  yes, 99% of the time that means the line before was missing a trailing comma (which means more lines coming for this item)
                  your last 4 lines of the compliments list do not have the trailing comma
                  and the position line
                  just because I didn’t include it my text above doesn’t mean it’s not required…
                  • G Offline
                    geekhouri @sdetweil
                    @sdetweil made those changes and MM is working again however i the compliments are still not visible? Any thoughts?
                      sdetweil @geekhouri
                      @geekhouri also missing a close } before the last one
                                              position: "top_bar",
                                               compliments: {
                                                      "....-01-12": ["Happy new year!"],
                                                      "....02-12": ["Happy Birthday E!"],
                                                      "....03-12": ["Happy Birthday Z!"],
                                                      "....05-12": ["Happy Birthday G!"],
                                                      }  // end of compliments
                                            }  // end of config
                                } // end of module
                      you should see the error where you start mm…
                      if using pm2, then
                      pm2 logs --lines=50
                      • G Offline
                        geekhouri @sdetweil
                        @sdetweil still nothing, here is my code in full and the pm2 logs:
                                                 compliments: {
        } //end of compliments
                                                        } //end of config
                                        }, //end of module
                        Pm2 logs as follows:
                        0|mm       |     at Object..js (node:internal/modules/cjs/loader:1326:10)
                        0|mm       |     at Module.load (node:internal/modules/cjs/loader:1126:32)
                        0|mm       |     at node:internal/modules/cjs/loader:967:12
                        0|mm       |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/v        ulkan/VulkanError.cpp:88)
                        0|mm       |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vul        kan/BackendVk.cpp:458)
                        0|mm       |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/Ba        ckendVk.cpp:344)
                        0|mm       |     at Create (../../third_party/dawn/src/dawn/native/vulkan/Backen        dVk.cpp:266)
                        0|mm       |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/Ba        ckendVk.cpp:521)
                        0|mm       |
                        0|mm       | /home/gkhouri/MagicMirror/node_modules/electron/dist/electron exite        d with signal SIGINT
                        0|mm       | [24.01.2024 01:29.00.569] [ERROR] WARNING! Could not validate confi        g file. Starting with default configuration. Please correct syntax errors at or        above this line: /home/gkhouri/MagicMirror/config/config.js:68
                        0|mm       |                    config: {
                        0|mm       |                    ^^^^^^
                        0|mm       |
                        0|mm       | SyntaxError: Unexpected identifier 'config'
                        0|mm       |     at internalCompileFunction (node:internal/vm:73:18)
                        0|mm       |     at wrapSafe (node:internal/modules/cjs/loader:1185:20)
                        0|mm       |     at Module._compile (node:internal/modules/cjs/loader:1227:27)
                        0|mm       |     at Function._load (node:electron/js2c/asar_bundle:2:13327)
                        0|mm       |     at Module.require (node:internal/modules/cjs/loader:1150:19)
                        0|mm       |     at require (node:internal/modules/cjs/helpers:121:18)
                        0|mm       |     at loadConfig (/home/gkhouri/MagicMirror/js/app.js:118:14)
                        0|mm       |     at App.start (/home/gkhouri/MagicMirror/js/app.js:248:18)
                        0|mm       |     at Object.<anonymous> (/home/gkhouri/MagicMirror/js/electron.js        :192:7)
                        0|mm       |     at Module._compile (node:internal/modules/cjs/loader:1271:14)
                        0|mm       |
                        0|mm       |
                          sdetweil @geekhouri
                          0|mm | config: {
                          0|mm | ^^^^^^
                          0|mm |
                          0|mm | SyntaxError: Unexpected identifier ‘config’
                          I can only assume you haven’t saved the updated config… (I do that sometimes…oops)
                          • G Offline
                            geekhouri @sdetweil
                            @sdetweil thanks again. Saved the file, flushed the logs rebooted and new log is below no new errrors and i think you previously stated the errors below cant be hidden. . Still no Compliments working (i’m at a loss now)
                            0|mm       |
                              sdetweil @geekhouri
                              @geekhouri ok, lets stop using pm2…
                              pm2 stop all
                              then
                              npm start
                              wait
                              if you are doing this on the MM screen
                              ctrl-q to stop mm (with pm2, it would restart it immediately… thats is job)
                              so, see anything in the output??
                              I used your config and it worked (on v2.26) without any issues
                              • G Offline
                                geekhouri @sdetweil
                                @sdetweil followed instructions however do not see anything in the output as below:
                                > magicmirror@2.26.0 start
                                [24.01.2024 12:20.55.171] [LOG]   Starting MagicMirror: v2.26.0
                                [24.01.2024 12:20.55.183] [LOG]   Loading config ...
                                [24.01.2024 12:20.55.193] [DEBUG] config template file not exists, no envsubst
                                [24.01.2024 12:20.55.205] [LOG]   Loading module helpers ...
                                [24.01.2024 12:20.55.209] [LOG]   No helper found for module: alert.
                                [24.01.2024 12:20.55.213] [LOG]   No helper found for module: clock.
                                [24.01.2024 12:20.55.689] [LOG]   Initializing new module helper ...
                                [24.01.2024 12:20.55.690] [LOG]   Module helper loaded: calendar
                                [24.01.2024 12:20.55.694] [LOG]   No helper found for module: compliments.
                                [24.01.2024 12:20.56.724] [LOG]   Initializing new module helper ...
                                [24.01.2024 12:20.56.726] [LOG]   Module helper loaded: MMM-DailyBibleVerse
                                [24.01.2024 12:20.56.857] [LOG]   Initializing new module helper ...
                                [24.01.2024 12:20.56.858] [LOG]   Module helper loaded: MMM-OpenWeatherMapForeca        st
                                [24.01.2024 12:20.56.862] [LOG]   No helper found for module: MMM-GoogleTrafficT        imes.
                                [24.01.2024 12:20.57.729] [LOG]   Initializing new module helper ...
                                [24.01.2024 12:20.57.730] [LOG]   Module helper loaded: MMM-WordOfTheDay
                                [24.01.2024 12:20.57.736] [LOG]   Initializing new module helper ...
                                [24.01.2024 12:20.57.737] [LOG]   Module helper loaded: MMM-GoogleSheets
                                [24.01.2024 12:20.58.082] [LOG]   Initializing new module helper ...
                                [24.01.2024 12:20.58.083] [LOG]   Module helper loaded: newsfeed
                                [24.01.2024 12:20.58.084] [LOG]   All module helpers loaded.
                                [24.01.2024 12:20.58.102] [LOG]   Starting server on port 8080 ...
                                [24.01.2024 12:20.58.926] [LOG]   Server started ...
                                [24.01.2024 12:20.58.929] [LOG]   Connecting socket for: calendar
                                [24.01.2024 12:20.58.930] [LOG]   Starting node helper for: calendar
                                [24.01.2024 12:20.58.932] [LOG]   Connecting socket for: MMM-DailyBibleVerse
                                [24.01.2024 12:20.58.933] [LOG]   Started node_helper.js for MMM-DailyBibleVerse        .
                                [24.01.2024 12:20.58.934] [LOG]   Connecting socket for: MMM-OpenWeatherMapForec        ast
                                [24.01.2024 12:20.58.936] [LOG]   ====================== Starting node_helper fo        r module [MMM-OpenWeatherMapForecast]
                                [24.01.2024 12:20.58.937] [LOG]   Connecting socket for: MMM-WordOfTheDay
                                [24.01.2024 12:20.58.938] [LOG]   Starting module helper: MMM-WordOfTheDay
                                [24.01.2024 12:20.58.939] [LOG]   Connecting socket for: MMM-GoogleSheets
                                [24.01.2024 12:20.58.940] [LOG]   ====================== Starting node_helper fo        r module [MMM-GoogleSheets]
                                [24.01.2024 12:20.58.941] [LOG]   Connecting socket for: newsfeed
                                [24.01.2024 12:20.58.942] [LOG]   Starting node helper for: newsfeed
                                [24.01.2024 12:20.58.944] [LOG]   Sockets connected & modules started ...
                                [24.01.2024 12:20.59.084] [LOG]   Launching application.
                                [24.01.2024 12:21.06.600] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/%40gmail.com/public/basic.ics - Interval: 604800000
                                [24.01.2024 12:21.07.000] [LOG]   MMM-DailyBibleVerse node helper received a socket notification: START - Payload: NIV
                                [24.01.2024 12:21.07.031] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                [24.01.2024 12:21.07.046] [LOG]   Create new newsfetcher for url: https://www.9news.com.au/rss - Interval: 300000
                                [24.01.2024 12:21.07.054] [LOG]   Create new newsfetcher for url: https://www.smh.com.au/rss/feed.xml - Interval: 300000
                                [24.01.2024 12:21.08.318] [INFO]  Newsfeed-Fetcher: Broadcasting 17 items.
                                [24.01.2024 12:21.08.380] [LOG]   {"votd":{"text":"&ldquo;If any of you lacks wisdom, you should ask God, who gives generously to all without finding fault, and it will be given to you.&rdquo;","content":"If any of you lacks wisdom, you should ask God, who gives generously to all without finding fault, and it will be given to you.","display_ref":"James 1:5","reference":"James 1:5","permalink":"https:\/\/www.biblegateway.com\/passage\/?search=James%201:5&amp;version=NIV","copyright":" ","copyrightlink":"https:\/\/www.biblegateway.com\/versions\/index.php?action=getVersionInfo&amp;vid=31&amp;lang=2","audiolink":"https:\/\/www.biblegateway.com\/audio\/mclean\/niv\/Jas.1.5","day":"23","month":"01","year":"2024","version":"New International Version","version_id":"NIV","merchandising":""}}
                                [24.01.2024 12:21.09.117] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
                                [24.01.2024 12:21.09.136] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                [24.01.2024 12:21.11.958] [INFO]  Calendar-Fetcher: Broadcasting 51 events from https://calendar.google.com/calendar/ical/%40gmail.com/public/basic.ics.
                                Can i reinstall the compliments module?
                                  sdetweil @geekhouri
                                  @geekhouri do
                                  • G Offline
                                    geekhouri @sdetweil
                                      sdetweil @geekhouri
                                      @geekhouri glad you got it fixed
