    Compliments module has stopped working
    16 Posts 2 Posters 1.9k Views 2 Watching
    • G Offline
      geekhouri @sdetweil
      @sdetweil thanks for your feedback, i have updated my config.js file but now i run into the config file error and MM does not load. Code is below as is the error after running config: check
                              module: "compliments",
                              position: "top_bar"
                               compliments: {
                                       anytime: ["Be Smart, Be Kind, Be Like Jesus!"],
                                      morning: ["Good morning!", "Enjoy your day!", "How was school"],
                                      afternoon: ["How was School?", "Finish Your homework?"],
                                      evening: ["Sweet Dreams", "You look nice!", "Ready for School"],
                                      "....-01-12": ["Happy new year!"]
                                      "....02-12": ["Happy Birthday E!"]
                                      "....03-12": ["Happy Birthday Z!"]
                                      "....05-12": ["Happy Birthday G!"]
      npm run config:check
      [24.01.2024 01:07.25.065] [INFO]  Checking file...  /home/gkhouri/MagicMirror/config/config.js
      [24.01.2024 01:07.25.165] [ERROR] Your configuration file contains syntax errors :(
      [24.01.2024 01:07.25.167] [ERROR] Line 68 column 4: Parsing error: Unexpected token config
      Line 68 is config: { …
      Thanks again
        sdetweil @geekhouri
        @geekhouri said in Compliments module has stopped working:
        yes, 99% of the time that means the line before was missing a trailing comma (which means more lines coming for this item)
        your last 4 lines of the compliments list do not have the trailing comma
        and the position line
        just because I didn’t include it my text above doesn’t mean it’s not required…
        • G Offline
          geekhouri @sdetweil
          @sdetweil made those changes and MM is working again however i the compliments are still not visible? Any thoughts?
            sdetweil @geekhouri
            @geekhouri also missing a close } before the last one
                                    position: "top_bar",
                                     compliments: {
                                            "....-01-12": ["Happy new year!"],
                                            "....02-12": ["Happy Birthday E!"],
                                            "....03-12": ["Happy Birthday Z!"],
                                            "....05-12": ["Happy Birthday G!"],
                                            }  // end of compliments
                                  }  // end of config
                      } // end of module
            you should see the error where you start mm…
            if using pm2, then
            pm2 logs --lines=50
            • G Offline
              geekhouri @sdetweil
              @sdetweil still nothing, here is my code in full and the pm2 logs:
                                       compliments: {
                                                      } //end of compliments
                                              } //end of config
                              }, //end of module
              Pm2 logs as follows:
              0|mm       |     at Object..js (node:internal/modules/cjs/loader:1326:10)
              0|mm       |     at Module.load (node:internal/modules/cjs/loader:1126:32)
              0|mm       |     at node:internal/modules/cjs/loader:967:12
              0|mm       | Warning: vkCreateInstance: Found no drivers!
              0|mm       | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
              0|mm       |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/v        ulkan/VulkanError.cpp:88)
              0|mm       |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vul        kan/BackendVk.cpp:458)
              0|mm       |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/Ba        ckendVk.cpp:344)
              0|mm       |     at Create (../../third_party/dawn/src/dawn/native/vulkan/Backen        dVk.cpp:266)
              0|mm       |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/Ba        ckendVk.cpp:521)
              0|mm       |
              0|mm       | /home/gkhouri/MagicMirror/node_modules/electron/dist/electron exite        d with signal SIGINT
              0|mm       | [24.01.2024 01:29.00.569] [ERROR] WARNING! Could not validate confi        g file. Starting with default configuration. Please correct syntax errors at or        above this line: /home/gkhouri/MagicMirror/config/config.js:68
              0|mm       |                    config: {
              0|mm       |                    ^^^^^^
              0|mm       |
              0|mm       | SyntaxError: Unexpected identifier 'config'
              0|mm       |     at internalCompileFunction (node:internal/vm:73:18)
              0|mm       |     at wrapSafe (node:internal/modules/cjs/loader:1185:20)
              0|mm       |     at Module._compile (node:internal/modules/cjs/loader:1227:27)
              0|mm       |     at Function._load (node:electron/js2c/asar_bundle:2:13327)
              0|mm       |     at Module.require (node:internal/modules/cjs/loader:1150:19)
              0|mm       |     at require (node:internal/modules/cjs/helpers:121:18)
              0|mm       |     at loadConfig (/home/gkhouri/MagicMirror/js/app.js:118:14)
              0|mm       |     at App.start (/home/gkhouri/MagicMirror/js/app.js:248:18)
              0|mm       |     at Object.<anonymous> (/home/gkhouri/MagicMirror/js/electron.js        :192:7)
              0|mm       |     at Module._compile (node:internal/modules/cjs/loader:1271:14)
              0|mm       |
              0|mm       |
                sdetweil @geekhouri
                0|mm | config: {
                0|mm | ^^^^^^
                0|mm |
                0|mm | SyntaxError: Unexpected identifier ‘config’
                I can only assume you haven’t saved the updated config… (I do that sometimes…oops)
                • G Offline
                  geekhouri @sdetweil
                  @sdetweil thanks again. Saved the file, flushed the logs rebooted and new log is below no new errrors and i think you previously stated the errors below cant be hidden. . Still no Compliments working (i’m at a loss now)
                  0|mm       |
                    sdetweil @geekhouri
                    @geekhouri ok, lets stop using pm2…
                    pm2 stop all
                    then
                    npm start
                    wait
                    if you are doing this on the MM screen
                    ctrl-q to stop mm (with pm2, it would restart it immediately… thats is job)
                    so, see anything in the output??
                    I used your config and it worked (on v2.26) without any issues
                    • G Offline
                      geekhouri @sdetweil
                      @sdetweil followed instructions however do not see anything in the output as below:
                      > magicmirror@2.26.0 start
                      [24.01.2024 12:20.55.171] [LOG]   Starting MagicMirror: v2.26.0
                      [24.01.2024 12:20.55.183] [LOG]   Loading config ...
                      [24.01.2024 12:20.55.193] [DEBUG] config template file not exists, no envsubst
                      [24.01.2024 12:20.55.205] [LOG]   Loading module helpers ...
                      [24.01.2024 12:20.55.209] [LOG]   No helper found for module: alert.
                      [24.01.2024 12:20.55.213] [LOG]   No helper found for module: clock.
                      [24.01.2024 12:20.55.689] [LOG]   Initializing new module helper ...
                      [24.01.2024 12:20.55.690] [LOG]   Module helper loaded: calendar
                      [24.01.2024 12:20.55.694] [LOG]   No helper found for module: compliments.
                      [24.01.2024 12:20.56.724] [LOG]   Initializing new module helper ...
                      [24.01.2024 12:20.56.726] [LOG]   Module helper loaded: MMM-DailyBibleVerse
                      [24.01.2024 12:20.56.857] [LOG]   Initializing new module helper ...
                      [24.01.2024 12:20.56.858] [LOG]   Module helper loaded: MMM-OpenWeatherMapForeca        st
                      [24.01.2024 12:20.56.862] [LOG]   No helper found for module: MMM-GoogleTrafficT        imes.
                      [24.01.2024 12:20.57.729] [LOG]   Initializing new module helper ...
                      [24.01.2024 12:20.57.730] [LOG]   Module helper loaded: MMM-WordOfTheDay
                      [24.01.2024 12:20.57.736] [LOG]   Initializing new module helper ...
                      [24.01.2024 12:20.57.737] [LOG]   Module helper loaded: MMM-GoogleSheets
                      [24.01.2024 12:20.58.082] [LOG]   Initializing new module helper ...
                      [24.01.2024 12:20.58.083] [LOG]   Module helper loaded: newsfeed
                      [24.01.2024 12:20.58.084] [LOG]   All module helpers loaded.
                      [24.01.2024 12:20.58.102] [LOG]   Starting server on port 8080 ...
                      [24.01.2024 12:20.58.926] [LOG]   Server started ...
                      [24.01.2024 12:20.58.929] [LOG]   Connecting socket for: calendar
                      [24.01.2024 12:20.58.930] [LOG]   Starting node helper for: calendar
                      [24.01.2024 12:20.58.932] [LOG]   Connecting socket for: MMM-DailyBibleVerse
                      [24.01.2024 12:20.58.933] [LOG]   Started node_helper.js for MMM-DailyBibleVerse        .
                      [24.01.2024 12:20.58.934] [LOG]   Connecting socket for: MMM-OpenWeatherMapForec        ast
                      [24.01.2024 12:20.58.936] [LOG]   ====================== Starting node_helper fo        r module [MMM-OpenWeatherMapForecast]
                      [24.01.2024 12:20.58.937] [LOG]   Connecting socket for: MMM-WordOfTheDay
                      [24.01.2024 12:20.58.938] [LOG]   Starting module helper: MMM-WordOfTheDay
                      [24.01.2024 12:20.58.939] [LOG]   Connecting socket for: MMM-GoogleSheets
                      [24.01.2024 12:20.58.940] [LOG]   ====================== Starting node_helper fo        r module [MMM-GoogleSheets]
                      [24.01.2024 12:20.58.941] [LOG]   Connecting socket for: newsfeed
                      [24.01.2024 12:20.58.942] [LOG]   Starting node helper for: newsfeed
                      [24.01.2024 12:20.58.944] [LOG]   Sockets connected & modules started ...
                      [24.01.2024 12:20.59.084] [LOG]   Launching application.
                      [24.01.2024 12:21.06.600] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/%40gmail.com/public/basic.ics - Interval: 604800000
                      [24.01.2024 12:21.07.000] [LOG]   MMM-DailyBibleVerse node helper received a socket notification: START - Payload: NIV
                      [24.01.2024 12:21.07.031] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                      [24.01.2024 12:21.07.046] [LOG]   Create new newsfetcher for url: https://www.9news.com.au/rss - Interval: 300000
                      [24.01.2024 12:21.07.054] [LOG]   Create new newsfetcher for url: https://www.smh.com.au/rss/feed.xml - Interval: 300000
                      [24.01.2024 12:21.08.318] [INFO]  Newsfeed-Fetcher: Broadcasting 17 items.
                      [24.01.2024 12:21.08.380] [LOG]   {"votd":{"text":"&ldquo;If any of you lacks wisdom, you should ask God, who gives generously to all without finding fault, and it will be given to you.&rdquo;","content":"If any of you lacks wisdom, you should ask God, who gives generously to all without finding fault, and it will be given to you.","display_ref":"James 1:5","reference":"James 1:5","permalink":"https:\/\/www.biblegateway.com\/passage\/?search=James%201:5&amp;version=NIV","copyright":" ","copyrightlink":"https:\/\/www.biblegateway.com\/versions\/index.php?action=getVersionInfo&amp;vid=31&amp;lang=2","audiolink":"https:\/\/www.biblegateway.com\/audio\/mclean\/niv\/Jas.1.5","day":"23","month":"01","year":"2024","version":"New International Version","version_id":"NIV","merchandising":""}}
                      [24.01.2024 12:21.09.117] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
                      [24.01.2024 12:21.09.136] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                      [24.01.2024 12:21.11.958] [INFO]  Calendar-Fetcher: Broadcasting 51 events from https://calendar.google.com/calendar/ical/%40gmail.com/public/basic.ics.
                          at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                          at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                          at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                          at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                          at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                      Can i reinstall the compliments module?
                        sdetweil @geekhouri
                        @geekhouri do
                        git checkout modules/default/compliments/compliments.js
