    Compliments module has stopped working
    16 Posts 2 Posters 1.7k Views 2 Watching
      sdetweil @geekhouri
      @geekhouri 1st. you never edit our files.
      all config goes in config.js
      just because we arent showing all the config in the starter config.js doesn’t change this
      every module has the same general layout
        module: name,
         position: somewhere,
         config:{   // if needed to add or override the defaults for this module
              xxx:yhyy,     module specific config properties
               qqw:700
      next, what is the mm.sh error?, show me that file
      the Vulcan errors are a noise bug in electron we cannot hide.
      • G Offline
        geekhouri @sdetweil
        @sdetweil thanks for your reply. Just to be clear you mean i should not edit the compliments.js file and any configs should be in the config.js file (Sorry probably a newbie question but im still learning)
        The mm.sh code is listed below:
        cd ./MagicMirror
        DISPLAY=:0 npm start
        I hope this is what you are after.
          sdetweil @geekhouri
          @geekhouri the mm.sh should be
          ~ means logged on users home folder
          config.js, yes
               module:"compliments",
               position:"....."
                config:{
                     compliments:   your compliments config {.. }
          the system design is
          whatever is in config.js, overrides/replaces what is defined in the module defaults section
          • G Offline
            geekhouri @sdetweil
            @sdetweil thanks for your feedback, i have updated my config.js file but now i run into the config file error and MM does not load. Code is below as is the error after running config: check
                                    module: "compliments",
                                    position: "top_bar"
                                     compliments: {
                                             anytime: ["Be Smart, Be Kind, Be Like Jesus!"],
                                            morning: ["Good morning!", "Enjoy your day!", "How was school"],
                                            afternoon: ["How was School?", "Finish Your homework?"],
                                            evening: ["Sweet Dreams", "You look nice!", "Ready for School"],
                                            "....-01-12": ["Happy new year!"]
                                            "....02-12": ["Happy Birthday E!"]
                                            "....03-12": ["Happy Birthday Z!"]
                                            "....05-12": ["Happy Birthday G!"]
            npm run config:check
            [24.01.2024 01:07.25.065] [INFO]  Checking file...  /home/gkhouri/MagicMirror/config/config.js
            [24.01.2024 01:07.25.165] [ERROR] Your configuration file contains syntax errors :(
            [24.01.2024 01:07.25.167] [ERROR] Line 68 column 4: Parsing error: Unexpected token config
            Line 68 is config: { …
            Thanks again
              sdetweil @geekhouri
              @geekhouri said in Compliments module has stopped working:
              yes, 99% of the time that means the line before was missing a trailing comma (which means more lines coming for this item)
              your last 4 lines of the compliments list do not have the trailing comma
              and the position line
              just because I didn’t include it my text above doesn’t mean it’s not required…
              • G Offline
                geekhouri @sdetweil
                @sdetweil made those changes and MM is working again however i the compliments are still not visible? Any thoughts?
                  sdetweil @geekhouri
                  @geekhouri also missing a close } before the last one
                                          position: "top_bar",
                                           compliments: {
                                                  "....-01-12": ["Happy new year!"],
                                                  "....02-12": ["Happy Birthday E!"],
                                                  "....03-12": ["Happy Birthday Z!"],
                                                  "....05-12": ["Happy Birthday G!"],
                                                  }  // end of compliments
                                        }  // end of config
                            } // end of module
                  you should see the error where you start mm…
                  if using pm2, then
                  pm2 logs --lines=50
                  • G Offline
                    geekhouri @sdetweil
                    @sdetweil still nothing, here is my code in full and the pm2 logs:
                                             compliments: {
                                                            } //end of compliments
                                                    } //end of config
                                    }, //end of module
                    Pm2 logs as follows:
                    0|mm       |     at Object..js (node:internal/modules/cjs/loader:1326:10)
                    0|mm       |     at Module.load (node:internal/modules/cjs/loader:1126:32)
                    0|mm       |     at node:internal/modules/cjs/loader:967:12
                    0|mm       | Warning: vkCreateInstance: Found no drivers!
                    0|mm       | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                    0|mm       |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/v        ulkan/VulkanError.cpp:88)
                    0|mm       |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vul        kan/BackendVk.cpp:458)
                    0|mm       |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/Ba        ckendVk.cpp:344)
                    0|mm       |     at Create (../../third_party/dawn/src/dawn/native/vulkan/Backen        dVk.cpp:266)
                    0|mm       |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/Ba        ckendVk.cpp:521)
                    0|mm       |
                    0|mm       | /home/gkhouri/MagicMirror/node_modules/electron/dist/electron exite        d with signal SIGINT
                    0|mm       | [24.01.2024 01:29.00.569] [ERROR] WARNING! Could not validate confi        g file. Starting with default configuration. Please correct syntax errors at or        above this line: /home/gkhouri/MagicMirror/config/config.js:68
                    0|mm       |                    config: {
                    0|mm       |                    ^^^^^^
                    0|mm       |
                    0|mm       | SyntaxError: Unexpected identifier 'config'
                    0|mm       |     at internalCompileFunction (node:internal/vm:73:18)
                    0|mm       |     at wrapSafe (node:internal/modules/cjs/loader:1185:20)
                    0|mm       |     at Module._compile (node:internal/modules/cjs/loader:1227:27)
                    0|mm       |     at Function._load (node:electron/js2c/asar_bundle:2:13327)
                    0|mm       |     at Module.require (node:internal/modules/cjs/loader:1150:19)
                    0|mm       |     at require (node:internal/modules/cjs/helpers:121:18)
                    0|mm       |     at loadConfig (/home/gkhouri/MagicMirror/js/app.js:118:14)
                    0|mm       |     at App.start (/home/gkhouri/MagicMirror/js/app.js:248:18)
                    0|mm       |     at Object.<anonymous> (/home/gkhouri/MagicMirror/js/electron.js        :192:7)
                    0|mm       |     at Module._compile (node:internal/modules/cjs/loader:1271:14)
                    0|mm       |
                    0|mm       |
                      sdetweil @geekhouri
                      0|mm | config: {
                      0|mm | ^^^^^^
                      0|mm |
                      0|mm | SyntaxError: Unexpected identifier ‘config’
                      I can only assume you haven’t saved the updated config… (I do that sometimes…oops)
                      • G Offline
                        geekhouri @sdetweil
                        @sdetweil thanks again. Saved the file, flushed the logs rebooted and new log is below no new errrors and i think you previously stated the errors below cant be hidden. . Still no Compliments working (i’m at a loss now)
                        0|mm       |
