    SolisCloud Solar PV
    16 Posts 6 Posters 4.7k Views 5 Watching
    • K Offline
      Kash 0 @sdetweil
      @sdetweil said in SolisCloud Solar PV:
      just delete the node_modules folder and the npm install again
      Thank you both. I deleted the folder node_modules from within the Soliscloud parent folder, then ran npm install again, but it produced the same result. I then deleted the Soliscloud folder and did a clean install of the module. Unfortunately, that also produced the same result. The biggest errors seem to be:
      Failed to remove directories: There are warnings indicating that some directories could not be removed during cleanup, specifically related to the lzma-native dependency.
      Error during epoll installation: The installation process encounters an error while trying to rebuild the epoll dependency.
      Any and all help greatly appreciated :) - also, let me know if I should move the query to the Troubleshooting section.
        sdetweil @Kash 0
        @Kash-0 a few changes needed to the package…
        try my pull request
        cd to the module folder
        git fetch origin pull/1/head:test_install
        git checkout test_install
        then npm install should work
        npm install
        • K Offline
          Kash 0 @sdetweil
          Nailed it! Thank you Sam, you absolute legend :)
            sdetweil @Kash 0
            @Kash-0 this change has been accepted into the base module. so
            to reset, in the module folder do
            git checkout main
            git pull
            no code change
            • C Offline
              cyberphox @sdetweil
              Looks like a cool module - although I have 3 inverters for my setup and I see there is no way to add more than 1 currently?
                sdetweil @cyberphox
                @cyberphox I would open an issue on the module GitHub page to engage the author
