    SolisCloud Solar PV
    16 Posts 6 Posters 5.6k Views 5 Watching
    • BKeyportB Offline
      BKeyport Module Developer @Rags
      @Rags I would highly recommend that the module get listed on https://github.com/MagicMirrorOrg/MagicMirror/wiki/3rd-Party-Modules - with the author’s permission of course.
      • K Offline
        Kash 0 @Rags
        @Rags Oh my goodness, this is amazing!! Massive thanks to the developer (and you!) for the work already done, such a useful utility to have. Going to try an install it later today - wish me luck!
        • K Offline
          Kash 0 @Rags
          @Rags I ran into some snags on the install. It could be down to the dependencies - I wasn’t 100% sure where dependencies need to be installed.
          I’ve put them in the MagicMirror folder (and they seemed to install fine there) but I get quite a few errors when I then try to run npm install in the Soliscloud folder.
          Any advice?
          The errors, if that’s helpful:
          Magic@raspberrypi:~/MagicMirror/modules/MMM-Soliscloud $ npm install
          npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
          npm WARN deprecated electron-rebuild@3.2.9: Please use @electron/rebuild moving forward.  There is no API change, just a package name change
          npm WARN cleanup Failed to remove some directories [
          npm WARN cleanup   [
          npm WARN cleanup     '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/lzma-native',
          npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/lzma-native/build/liblzma'] {
          npm WARN cleanup       errno: -39,
          npm WARN cleanup       code: 'ENOTEMPTY',
          npm WARN cleanup       syscall: 'rmdir',
          npm WARN cleanup       path: '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/lzma-native/build/liblzma'
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ]
          npm WARN cleanup ]
          npm ERR! code 1
          npm ERR! path /home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll
          npm ERR! command failed
          npm ERR! command sh -c node-gyp rebuild
          npm ERR! make: Entering directory '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll/build'
          npm ERR!   CXX(target) Release/obj.target/epoll/src/epoll.o
          npm ERR! make: Leaving directory '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll/build'
          npm ERR! gyp info it worked if it ends with ok
          npm ERR! gyp info using node-gyp@9.4.0
          npm ERR! gyp info using node@21.6.1 | linux | arm64
          npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
          npm ERR! gyp info spawn /usr/bin/python3
          npm ERR! gyp info spawn args [
          npm ERR! gyp info spawn args   '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/node-gyp/gyp/gyp_main.py',
          npm ERR! gyp info spawn args   'binding.gyp',
          npm ERR! gyp info spawn args   '-f',
          npm ERR! gyp info spawn args   'make',
          npm ERR! gyp info spawn args   '-I',
          npm ERR! gyp info spawn args   '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll/build/config.gypi',
          npm ERR! gyp info spawn args   '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/node-gyp/addon.gypi',
          npm ERR! gyp info spawn args   '/home/Magic/.cache/node-gyp/21.6.1/include/node/common.gypi',
          npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
          npm ERR! gyp info spawn args   '-Dvisibility=default',
          npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/Magic/.cache/node-gyp/21.6.1',
          npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/node-gyp',
          npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/Magic/.cache/node-gyp/21.6.1/<(target_arch)/node.lib',
          npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll',
          npm ERR! gyp info spawn args   '-Dnode_engine=v8',
          npm ERR! gyp info spawn args   '--depth=.',
          npm ERR! gyp info spawn args   '--no-parallel',
          npm ERR! gyp info spawn args   '--generator-output',
          npm ERR! gyp info spawn args   'build',
          npm ERR! gyp info spawn args   '-Goutput_dir=.'
          npm ERR! gyp info spawn args ]
          npm ERR! gyp info spawn make
          npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
          npm ERR! In file included from /home/Magic/.cache/node-gyp/21.6.1/include/node/v8-array-buffer.h:12,
          npm ERR!                  from /home/Magic/.cache/node-gyp/21.6.1/include/node/v8.h:24,
          npm ERR!                  from ../src/epoll.cc:11:
          npm ERR! /home/Magic/.cache/node-gyp/21.6.1/include/node/v8-local-handle.h: In instantiation of ‘v8::Local<T>::Local(v8::Local<S>) [with S = v8::Data; T = v8::Value]’:
          npm ERR! ../../nan/nan_callbacks_12_inl.h:175:53:   required from here
          npm ERR! /home/Magic/.cache/node-gyp/21.6.1/include/node/v8-local-handle.h:253:42: error: static assertion failed: type check
          npm ERR!   253 |     static_assert(std::is_base_of<T, S>::value, "type check");
          npm ERR!       |                                          ^~~~~
          npm ERR! /home/Magic/.cache/node-gyp/21.6.1/include/node/v8-local-handle.h:253:42: note: ‘std::integral_constant<bool, false>::value’ evaluates to false
          npm ERR! make: *** [epoll.target.mk:110: Release/obj.target/epoll/src/epoll.o] Error 1
          npm ERR! gyp ERR! build error
          npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
          npm ERR! gyp ERR! stack     at ChildProcess.onExit (/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/node-gyp/lib/build.js:203:23)
          npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
          npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:294:12)
          npm ERR! gyp ERR! System Linux 6.1.0-rpi7-rpi-v8
          npm ERR! gyp ERR! command "/usr/bin/node" "/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/.bin/node-gyp" "rebuild"
          npm ERR! gyp ERR! cwd /home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll
          npm ERR! gyp ERR! node -v v21.6.1
          npm ERR! gyp ERR! node-gyp -v v9.4.0
          npm ERR! gyp ERR! not ok
          npm ERR! A complete log of this run can be found in: /home/Magic/.npm/_logs/2024-02-10T19_11_46_999Z-debug-0.log```
          S R 2 Replies Last reply Reply Quote 0
            sdetweil @Kash 0
            @Kash-0 npm install, right… not nvm
            • K Offline
              Kash 0 @sdetweil
              @sdetweil Yes, sorry! I’ll edit my original post
                Rags @Kash 0
                @Kash-0 Hello- 0. Well, I would suggest you to delete the existing folder (MMM-Solis Cloud if it exists) and then do a clean install in the MM Modules directory. The dependencies folder is created during NPM install in the same directory and are automatically registered ( I Guess) so there should not be any issue. Lots of my such issues with other modules were resolved by this method thanks to advice from @sdetweil .
                  sdetweil @Rags
                  @Rags just delete the node_modules folder and the npm install again
                  • K Offline
                    Kash 0 @sdetweil
                    @sdetweil said in SolisCloud Solar PV:
                    Thank you both. I deleted the folder node_modules from within the Soliscloud parent folder, then ran npm install again, but it produced the same result. I then deleted the Soliscloud folder and did a clean install of the module. Unfortunately, that also produced the same result. The biggest errors seem to be:
                    Failed to remove directories: There are warnings indicating that some directories could not be removed during cleanup, specifically related to the lzma-native dependency.
                    Error during epoll installation: The installation process encounters an error while trying to rebuild the epoll dependency.
                    Any and all help greatly appreciated :) - also, let me know if I should move the query to the Troubleshooting section.
                      sdetweil @Kash 0
                      @Kash-0 a few changes needed to the package…
                      try my pull request
                      cd to the module folder
                      git fetch origin pull/1/head:test_install
                      git checkout test_install
                      then npm install should work
                      npm install
                      • K Offline
                        Kash 0 @sdetweil
                        Nailed it! Thank you Sam, you absolute legend :)
                          sdetweil @Kash 0
                          @Kash-0 this change has been accepted into the base module. so
                          to reset, in the module folder do
                          git checkout main
                          git pull
                          no code change
                            cyberphox @sdetweil
                            Looks like a cool module - although I have 3 inverters for my setup and I see there is no way to add more than 1 currently?
                              sdetweil @cyberphox
                              @cyberphox I would open an issue on the module GitHub page to engage the author
