    SolisCloud Solar PV
    16 Posts 6 Posters 5.6k Views 5 Watching
    • K Offline
      Kash 0
      I would like my MM to show the status of my Solar PV. There are quite a few modules, but none seem designed to work with the SolisCloud system. They have an API now, so theoretically it is possible (though beyond my rudimentary skills)
      Is there anybody who could help with that?
      mumblebajM R 2 Replies Last reply Reply Quote 0
        Rags @Kash 0
        @Kash-0 said in SolisCloud Solar PV:
        You are in Luck. I also wanted the same functionality, and I approached @dkinet . The MM module was developed by him on my request over a period of almost 6 months . I worked with him in testing out the module. Also based on inputs by me the module has been tweaked to address certain requirements for triggering the GPIO pin to control audio and visual alarms. 2024-01-28_14-46-05.png The module is functional and i have deployed it on my MM. The Inverter data is nicely displayed on the screen All it requires is a little beautification to suit the MM style and looks. I want to take this opportunity to profusely thank the developer for finding time to develop this module.
        https://github.com/dekinet/MMM-Soliscloud.git
        BKeyportB K 3 Replies Last reply Reply Quote 0
        • mumblebajM Offline
          mumblebaj Module Developer @Kash 0
          @Kash-0 Do you know the link to API documentation etc?
            Rags @Kash 0
            • BKeyportB Offline
              BKeyport Module Developer @Rags
              @Rags I would highly recommend that the module get listed on https://github.com/MagicMirrorOrg/MagicMirror/wiki/3rd-Party-Modules - with the author’s permission of course.
              • K Offline
                Kash 0 @Rags
                @Rags Oh my goodness, this is amazing!! Massive thanks to the developer (and you!) for the work already done, such a useful utility to have. Going to try an install it later today - wish me luck!
                • K Offline
                  Kash 0 @Rags
                  @Rags I ran into some snags on the install. It could be down to the dependencies - I wasn’t 100% sure where dependencies need to be installed.
                  I’ve put them in the MagicMirror folder (and they seemed to install fine there) but I get quite a few errors when I then try to run npm install in the Soliscloud folder.
                  Any advice?
                  The errors, if that’s helpful:
                  Magic@raspberrypi:~/MagicMirror/modules/MMM-Soliscloud $ npm install
                  npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                  npm WARN deprecated electron-rebuild@3.2.9: Please use @electron/rebuild moving forward.  There is no API change, just a package name change
                  npm WARN cleanup Failed to remove some directories [
                  npm WARN cleanup   [
                  npm WARN cleanup     '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/lzma-native',
                  npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/lzma-native/build/liblzma'] {
                  npm WARN cleanup       errno: -39,
                  npm WARN cleanup       code: 'ENOTEMPTY',
                  npm WARN cleanup       syscall: 'rmdir',
                  npm WARN cleanup       path: '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/lzma-native/build/liblzma'
                  npm WARN cleanup     }
                  npm WARN cleanup   ],
                  npm WARN cleanup   [
                  npm WARN cleanup     }
                  npm WARN cleanup   ]
                  npm WARN cleanup ]
                  npm ERR! code 1
                  npm ERR! path /home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll
                  npm ERR! command failed
                  npm ERR! command sh -c node-gyp rebuild
                  npm ERR! make: Entering directory '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll/build'
                  npm ERR!   CXX(target) Release/obj.target/epoll/src/epoll.o
                  npm ERR! make: Leaving directory '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll/build'
                  npm ERR! gyp info it worked if it ends with ok
                  npm ERR! gyp info using node-gyp@9.4.0
                  npm ERR! gyp info using node@21.6.1 | linux | arm64
                  npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                  npm ERR! gyp info spawn /usr/bin/python3
                  npm ERR! gyp info spawn args [
                  npm ERR! gyp info spawn args   '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/node-gyp/gyp/gyp_main.py',
                  npm ERR! gyp info spawn args   'binding.gyp',
                  npm ERR! gyp info spawn args   '-f',
                  npm ERR! gyp info spawn args   'make',
                  npm ERR! gyp info spawn args   '-I',
                  npm ERR! gyp info spawn args   '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll/build/config.gypi',
                  npm ERR! gyp info spawn args   '/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/node-gyp/addon.gypi',
                  npm ERR! gyp info spawn args   '/home/Magic/.cache/node-gyp/21.6.1/include/node/common.gypi',
                  npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                  npm ERR! gyp info spawn args   '-Dvisibility=default',
                  npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/Magic/.cache/node-gyp/21.6.1',
                  npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/node-gyp',
                  npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/Magic/.cache/node-gyp/21.6.1/<(target_arch)/node.lib',
                  npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll',
                  npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                  npm ERR! gyp info spawn args   '--depth=.',
                  npm ERR! gyp info spawn args   '--no-parallel',
                  npm ERR! gyp info spawn args   '--generator-output',
                  npm ERR! gyp info spawn args   'build',
                  npm ERR! gyp info spawn args   '-Goutput_dir=.'
                  npm ERR! gyp info spawn args ]
                  npm ERR! gyp info spawn make
                  npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                  npm ERR! In file included from /home/Magic/.cache/node-gyp/21.6.1/include/node/v8-array-buffer.h:12,
                  npm ERR!                  from /home/Magic/.cache/node-gyp/21.6.1/include/node/v8.h:24,
                  npm ERR!                  from ../src/epoll.cc:11:
                  npm ERR! /home/Magic/.cache/node-gyp/21.6.1/include/node/v8-local-handle.h: In instantiation of ‘v8::Local<T>::Local(v8::Local<S>) [with S = v8::Data; T = v8::Value]’:
                  npm ERR! ../../nan/nan_callbacks_12_inl.h:175:53:   required from here
                  npm ERR! /home/Magic/.cache/node-gyp/21.6.1/include/node/v8-local-handle.h:253:42: error: static assertion failed: type check
                  npm ERR!   253 |     static_assert(std::is_base_of<T, S>::value, "type check");
                  npm ERR!       |                                          ^~~~~
                  npm ERR! /home/Magic/.cache/node-gyp/21.6.1/include/node/v8-local-handle.h:253:42: note: ‘std::integral_constant<bool, false>::value’ evaluates to false
                  npm ERR! make: *** [epoll.target.mk:110: Release/obj.target/epoll/src/epoll.o] Error 1
                  npm ERR! gyp ERR! build error
                  npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
                  npm ERR! gyp ERR! stack     at ChildProcess.onExit (/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/node-gyp/lib/build.js:203:23)
                  npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
                  npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:294:12)
                  npm ERR! gyp ERR! System Linux 6.1.0-rpi7-rpi-v8
                  npm ERR! gyp ERR! command "/usr/bin/node" "/home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/.bin/node-gyp" "rebuild"
                  npm ERR! gyp ERR! cwd /home/Magic/MagicMirror/modules/MMM-Soliscloud/node_modules/epoll
                  npm ERR! gyp ERR! node -v v21.6.1
                  npm ERR! gyp ERR! node-gyp -v v9.4.0
                  npm ERR! gyp ERR! not ok
                  npm ERR! A complete log of this run can be found in: /home/Magic/.npm/_logs/2024-02-10T19_11_46_999Z-debug-0.log```
                  S R 2 Replies Last reply Reply Quote 0
                    sdetweil @Kash 0
                    @Kash-0 npm install, right… not nvm
                    • K Offline
                      Kash 0 @sdetweil
                      @sdetweil Yes, sorry! I’ll edit my original post
                        Rags @Kash 0
                        @Kash-0 Hello- 0. Well, I would suggest you to delete the existing folder (MMM-Solis Cloud if it exists) and then do a clean install in the MM Modules directory. The dependencies folder is created during NPM install in the same directory and are automatically registered ( I Guess) so there should not be any issue. Lots of my such issues with other modules were resolved by this method thanks to advice from @sdetweil .
                          sdetweil @Rags
                          @Rags just delete the node_modules folder and the npm install again
                          • K Offline
                            Kash 0 @sdetweil
                            @sdetweil said in SolisCloud Solar PV:
                            Thank you both. I deleted the folder node_modules from within the Soliscloud parent folder, then ran npm install again, but it produced the same result. I then deleted the Soliscloud folder and did a clean install of the module. Unfortunately, that also produced the same result. The biggest errors seem to be:
                            Failed to remove directories: There are warnings indicating that some directories could not be removed during cleanup, specifically related to the lzma-native dependency.
                            Error during epoll installation: The installation process encounters an error while trying to rebuild the epoll dependency.
                            Any and all help greatly appreciated :) - also, let me know if I should move the query to the Troubleshooting section.
                              sdetweil @Kash 0
                              @Kash-0 a few changes needed to the package…
                              try my pull request
                              cd to the module folder
                              git fetch origin pull/1/head:test_install
                              git checkout test_install
                              then npm install should work
                              npm install
                              • K Offline
                                Kash 0 @sdetweil
                                Nailed it! Thank you Sam, you absolute legend :)
                                  sdetweil @Kash 0
                                  @Kash-0 this change has been accepted into the base module. so
                                  to reset, in the module folder do
                                  git checkout main
                                  git pull
                                  no code change
                                    cyberphox @sdetweil
                                    Looks like a cool module - although I have 3 inverters for my setup and I see there is no way to add more than 1 currently?
                                      sdetweil @cyberphox
                                      @cyberphox I would open an issue on the module GitHub page to engage the author
