    MM black screen
    4 Posts 2 Posters 781 Views 2 Watching
    • P Offline
      princemaxwell
      Hey,
      i get some errors in mm-error.log.
      • MM version 2.26.0
      • Pi4
      • bullseye
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      WARNING: v3dv is neither a complete nor a conformant Vulkan implementation. Testing use only.
      Warning: loader_scanned_icd_add: Driver /usr/lib/arm-linux-gnueabihf/libvulkan_radeon.so supports Vulkan 1.2, but only supports loader interface version 4. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
      Warning: loader_scanned_icd_add: Driver /usr/lib/arm-linux-gnueabihf/libvulkan_broadcom.so supports Vulkan 1.1, but only supports loader interface version 3. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
      Warning: loader_scanned_icd_add: Driver /usr/lib/arm-linux-gnueabihf/libvulkan_lvp.so supports Vulkan 1.1, but only supports loader interface version 1. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
      Warning: Layer VK_LAYER_MESA_device_select uses API version 1.2 which is older than the application specified API version of 1.3. May cause issues.
      Warning: terminator_CreateInstance: Manifest ICD for "/usr/lib/arm-linux-gnueabihf/libvulkan_broadcom.so" contained a 1.1 or greater API version, but does not support vkEnumerateInstanceVersion, treating as a 1.0 ICD
      Warning: terminator_CreateInstance: Driver /usr/lib/arm-linux-gnueabihf/libvulkan_lvp.so supports interface version 1 but still exposes VkSurfaceKHR create/destroy entrypoints (Policy #LDP_DRIVER_8)
      Warning: Vulkan textureCompressionBC feature required or both textureCompressionETC2 and textureCompressionASTC required.
       - While initializing adapter (backend=BackendType::Vulkan)
          at InitializeImpl (../../third_party/dawn/src/dawn/native/vulkan/PhysicalDeviceVk.cpp:159)
          at Initialize (../../third_party/dawn/src/dawn/native/PhysicalDevice.cpp:35)
      Can someone figure out the problem? The mirror is showing a black screen.
      • P Offline
        princemaxwell @sdetweil
        @sdetweil Ok, i got it.
        var config = {
        	address: "::", 	// Address to listen on, can be:
        	port: 8080,
        I had to change it to:
        address: "0.0.0.0",
        Was my mistake, i uploaded wrong config…
        Don’t know why the Vulkan errors are appearing…
          sdetweil @princemaxwell
          @princemaxwell I don’t think that is the problem.
          can u show the full console output
          • P Offline
            var config = {
            	port: 8080,
            address: "0.0.0.0",
              @princemaxwell the vulkan errors is a bug in electron. just warnings… ignore
