    MM failed after updating
    16 Posts 3 Posters 3.5k Views 3 Watching
    • C Offline
      chrisfr1976 @sdetweil
      Same issue here:
      chris@MagicPi:~/MagicMirror $ pm2 logs --lines=75
      [TAILING] Tailing last 75 lines for [all] processes (change the value with --lines option)
      /home/chris/.pm2/pm2.log last 75 lines:
      PM2        | 2024-04-03T10:25:09: PM2 log: App [mm:0] starting in -fork mode-
      PM2        | 2024-04-03T10:25:09: PM2 log: App [mm:0] online
      PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT]
      PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] starting in -fork mode-
      PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] online
      PM2        | 2024-04-03T10:25:48: PM2 log: Stopping app:mm id:0
      PM2        | 2024-04-03T10:25:48: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
      PM2        | 2024-04-03T10:25:48: PM2 log: pid=3783 msg=process killed
      /home/chris/.pm2/logs/mm-out.log last 75 lines:
      /home/chris/.pm2/logs/Display-Drehen-out.log last 75 lines:
      /home/chris/.pm2/logs/Display-Drehen-error.log last 75 lines:
      /home/chris/.pm2/logs/mm-error.log last 75 lines:
      0|mm       | npm ERR! code EJSONPARSE
      0|mm       | npm ERR! JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
      0|mm       | npm ERR! JSON.parse Failed to parse JSON data.
      0|mm       | npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
      0|mm       |
      0|mm       | npm ERR! A complete log of this run can be found in: /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
      Complete log:
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@10.5.0
      2 info using node@v21.7.1
      3 timing npm:load:whichnode Completed in 5ms
      4 timing config:load:defaults Completed in 5ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 1ms
      6 timing config:load:builtin Completed in 2ms
      7 timing config:load:cli Completed in 6ms
      8 timing config:load:env Completed in 2ms
      9 timing config:load:file:/home/chris/MagicMirror/.npmrc Completed in 5ms
      10 timing config:load:project Completed in 7ms
      11 timing config:load:file:/home/chris/.npmrc Completed in 1ms
      12 timing config:load:user Completed in 1ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:setEnvs Completed in 3ms
      16 timing config:load Completed in 27ms
      17 timing npm:load:configload Completed in 27ms
      18 timing config:load:flatten Completed in 7ms
      19 timing npm:load:mkdirpcache Completed in 0ms
      20 timing npm:load:mkdirplogs Completed in 0ms
      21 verbose title npm start
      22 verbose argv "start"
      23 timing npm:load:setTitle Completed in 2ms
      24 timing npm:load:display Completed in 2ms
      25 verbose logfile logs-max:10 dir:/home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-
      26 verbose logfile /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
      27 timing npm:load:logFile Completed in 23ms
      28 timing npm:load:timers Completed in 0ms
      29 timing npm:load:configScope Completed in 0ms
      30 timing npm:load Completed in 107ms
      31 silly logfile start cleaning logs, removing 2 files
      32 timing command:run-script Completed in 21ms
      33 timing command:start Completed in 36ms
      34 verbose stack JSONParseError: Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
      34 verbose stack     at PackageJson.fromJSON (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:162:24)
      34 verbose stack     at PackageJson.load (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:156:17)
      34 verbose stack     at async PackageJson.normalize (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:115:5)
      34 verbose stack     at async RunScript.run (/usr/lib/node_modules/npm/lib/commands/run-script.js:72:27)
      34 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli-entry.js:61:5)
      35 verbose cwd /home/chris/MagicMirror
      36 verbose Linux 6.1.21-v7l+
      37 verbose node v21.7.1
      38 verbose npm  v10.5.0
      39 error code EJSONPARSE
      40 error JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
      41 error JSON.parse Failed to parse JSON data.
      41 error JSON.parse Note: package.json must be actual JSON, not just JavaScript.
      42 verbose exit 1
      43 timing npm Completed in 228ms
      44 verbose code 1
      45 error A complete log of this run can be found in: /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
      :anxious_face_with_sweat:
      Cheers,
      Chris.
      Regards, Chris.
        sdetweil @chrisfr1976
        @chrisfr1976 can you post the few lines of package.json around line 87
        did you use my upgrade script?
        if so can u email me the file
        ~/MagicMirror/installers/upgrade.log
        using the same userid as on this post at gmail
        • C Offline
          In the beginning I’ve used the described update method here:
          https://docs.magicmirror.builders/getting-started/upgrade-guide.html
          So only git pull && npm run install-mm was used. But I’ve used the back-up script you’ve provided. Then I found also your update script. I’ve used it then, too. But same error. I’ll send the update.log via email :-)
          Here the lines around line 87. I’ve marked it to show the position only:
            // Loads a package.json at given path and JSON parses
            static async load (path, opts = {}) {
              const p = new PackageJson()
              // Avoid try/catch if we aren't going to create
              if (!opts.create) {
                return p.load(path)
          *87*
              try {
                return await p.load(path)
              } catch (err) {
                if (!err.message.startsWith('Could not read package.json')) {
                  throw err
                return await p.create(path)
          Chris.
          Regards, Chris.
            @chrisfr1976 hm…
            package.json looks like this
            • C Offline
              @sdetweil I was able to fix it. git reset --hard followed by npm run install-mm fixed the issue. I don’t know why but now everything is fine again. I’ll do a SD-card back-up now :-)
              Regards, Chris.
                @chrisfr1976 weird, thanks for the update
