    MM failed after updating
    16 Posts 3 Posters 4.4k Views 3 Watching
      sdetweil @1a2a3a
      @1a2a3a thanks. i needed to see the actual npm install output
      use my backup/restore scripts
      https://github.com/sdetweil/MagicMirror-backup-restore
      1 1 Reply Last reply Reply Quote 0
      • 1 Offline
        1a2a3a @sdetweil
        @sdetweil thanks. still in the midst of transferring.
        why are you up so early? i recall you were some hours behind so when i posted this i figured i wouldnt get a response so soon hence my attempt of own answer.
          sdetweil @1a2a3a
          @1a2a3a i was on US west coast time for a couple months now back in central time. thanks for noticing…
          • 1 Offline
            1a2a3a @sdetweil
            @sdetweil i see. anyway, my calendar, stocks and google photo are not loading. it says check logs for details – where can i find the logs again?
            edit—
            its odd. when i run npm start dev, everything is working fine, everything loads.
            but when i run pm2 start MagicMirror - my cal, stocks and photos are not loading. am i suppose to let it sit there for awhile?
              sdetweil @1a2a3a
              @1a2a3a logs are output where the npm start is done.
              pm2 captures them
              do this
              pm2 stop all
              pm2 flush
              wait 15 seconds
              pm2 stop all
              pm2 logs --lines=75
                chrisfr1976 @sdetweil
                Same issue here:
                chris@MagicPi:~/MagicMirror $ pm2 logs --lines=75
                [TAILING] Tailing last 75 lines for [all] processes (change the value with --lines option)
                /home/chris/.pm2/pm2.log last 75 lines:
                PM2        | 2024-04-03T10:25:09: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2024-04-03T10:25:09: PM2 log: App [mm:0] online
                PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT]
                PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] online
                PM2        | 2024-04-03T10:25:48: PM2 log: Stopping app:mm id:0
                PM2        | 2024-04-03T10:25:48: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                PM2        | 2024-04-03T10:25:48: PM2 log: pid=3783 msg=process killed
                /home/chris/.pm2/logs/mm-out.log last 75 lines:
                /home/chris/.pm2/logs/Display-Drehen-out.log last 75 lines:
                /home/chris/.pm2/logs/Display-Drehen-error.log last 75 lines:
                /home/chris/.pm2/logs/mm-error.log last 75 lines:
                0|mm       | npm ERR! code EJSONPARSE
                0|mm       | npm ERR! JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
                0|mm       | npm ERR! JSON.parse Failed to parse JSON data.
                0|mm       | npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
                0|mm       |
                0|mm       | npm ERR! A complete log of this run can be found in: /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
                Complete log:
                0 verbose cli /usr/bin/node /usr/bin/npm
                1 info using npm@10.5.0
                2 info using node@v21.7.1
                3 timing npm:load:whichnode Completed in 5ms
                4 timing config:load:defaults Completed in 5ms
                5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 1ms
                6 timing config:load:builtin Completed in 2ms
                7 timing config:load:cli Completed in 6ms
                8 timing config:load:env Completed in 2ms
                9 timing config:load:file:/home/chris/MagicMirror/.npmrc Completed in 5ms
                10 timing config:load:project Completed in 7ms
                11 timing config:load:file:/home/chris/.npmrc Completed in 1ms
                12 timing config:load:user Completed in 1ms
                13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
                14 timing config:load:global Completed in 1ms
                15 timing config:load:setEnvs Completed in 3ms
                16 timing config:load Completed in 27ms
                17 timing npm:load:configload Completed in 27ms
                18 timing config:load:flatten Completed in 7ms
                19 timing npm:load:mkdirpcache Completed in 0ms
                20 timing npm:load:mkdirplogs Completed in 0ms
                21 verbose title npm start
                22 verbose argv "start"
                23 timing npm:load:setTitle Completed in 2ms
                24 timing npm:load:display Completed in 2ms
                25 verbose logfile logs-max:10 dir:/home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-
                26 verbose logfile /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
                27 timing npm:load:logFile Completed in 23ms
                28 timing npm:load:timers Completed in 0ms
                29 timing npm:load:configScope Completed in 0ms
                30 timing npm:load Completed in 107ms
                31 silly logfile start cleaning logs, removing 2 files
                32 timing command:run-script Completed in 21ms
                33 timing command:start Completed in 36ms
                34 verbose stack JSONParseError: Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
                34 verbose stack     at PackageJson.fromJSON (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:162:24)
                34 verbose stack     at PackageJson.load (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:156:17)
                34 verbose stack     at async PackageJson.normalize (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:115:5)
                34 verbose stack     at async RunScript.run (/usr/lib/node_modules/npm/lib/commands/run-script.js:72:27)
                34 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli-entry.js:61:5)
                35 verbose cwd /home/chris/MagicMirror
                36 verbose Linux 6.1.21-v7l+
                37 verbose node v21.7.1
                38 verbose npm  v10.5.0
                39 error code EJSONPARSE
                40 error JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
                41 error JSON.parse Failed to parse JSON data.
                41 error JSON.parse Note: package.json must be actual JSON, not just JavaScript.
                42 verbose exit 1
                43 timing npm Completed in 228ms
                44 verbose code 1
                45 error A complete log of this run can be found in: /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
                :anxious_face_with_sweat:
                Cheers,
                Chris.
                Regards, Chris.
                  sdetweil @chrisfr1976
                  @chrisfr1976 can you post the few lines of package.json around line 87
                  did you use my upgrade script?
                  if so can u email me the file
                  ~/MagicMirror/installers/upgrade.log
                  using the same userid as on this post at gmail
                    In the beginning I’ve used the described update method here:
                    https://docs.magicmirror.builders/getting-started/upgrade-guide.html
                    So only git pull && npm run install-mm was used. But I’ve used the back-up script you’ve provided. Then I found also your update script. I’ve used it then, too. But same error. I’ll send the update.log via email :-)
                    Here the lines around line 87. I’ve marked it to show the position only:
                      // Loads a package.json at given path and JSON parses
                      static async load (path, opts = {}) {
                        const p = new PackageJson()
                        // Avoid try/catch if we aren't going to create
                        if (!opts.create) {
                          return p.load(path)
                    *87*
                        try {
                          return await p.load(path)
                        } catch (err) {
                          if (!err.message.startsWith('Could not read package.json')) {
                            throw err
                          return await p.create(path)
                    Chris.
                    Regards, Chris.
                      @chrisfr1976 hm…
                      package.json looks like this
                        @sdetweil I was able to fix it. git reset --hard followed by npm run install-mm fixed the issue. I don’t know why but now everything is fine again. I’ll do a SD-card back-up now :-)
                        Regards, Chris.
                          @chrisfr1976 weird, thanks for the update
