    MM failed after updating
    16 Posts 3 Posters 3.5k Views 3 Watching
    • 1 Offline
      1a2a3a @sdetweil
      @sdetweil i cant. i deleted the entire folder. just installed using your script. now transferring the modules folder from backup to the pi.
      thats what i did actually, installing the electron but it keep throwing error like npm ERR! signal sigint
      npm ERR! code E404
        sdetweil @1a2a3a
        @1a2a3a thanks. i needed to see the actual npm install output
        use my backup/restore scripts
        https://github.com/sdetweil/MagicMirror-backup-restore
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          1a2a3a @sdetweil
          @sdetweil thanks. still in the midst of transferring.
          why are you up so early? i recall you were some hours behind so when i posted this i figured i wouldnt get a response so soon hence my attempt of own answer.
            sdetweil @1a2a3a
            @1a2a3a i was on US west coast time for a couple months now back in central time. thanks for noticing…
            • 1 Offline
              1a2a3a @sdetweil
              @sdetweil i see. anyway, my calendar, stocks and google photo are not loading. it says check logs for details – where can i find the logs again?
              edit—
              its odd. when i run npm start dev, everything is working fine, everything loads.
              but when i run pm2 start MagicMirror - my cal, stocks and photos are not loading. am i suppose to let it sit there for awhile?
                sdetweil @1a2a3a
                @1a2a3a logs are output where the npm start is done.
                pm2 captures them
                do this
                pm2 stop all
                pm2 flush
                wait 15 seconds
                pm2 stop all
                pm2 logs --lines=75
                  chrisfr1976 @sdetweil
                  Same issue here:
                  chris@MagicPi:~/MagicMirror $ pm2 logs --lines=75
                  [TAILING] Tailing last 75 lines for [all] processes (change the value with --lines option)
                  /home/chris/.pm2/pm2.log last 75 lines:
                  PM2        | 2024-04-03T10:25:09: PM2 log: App [mm:0] starting in -fork mode-
                  PM2        | 2024-04-03T10:25:09: PM2 log: App [mm:0] online
                  PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT]
                  PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] starting in -fork mode-
                  PM2        | 2024-04-03T10:25:30: PM2 log: App [mm:0] online
                  PM2        | 2024-04-03T10:25:48: PM2 log: Stopping app:mm id:0
                  PM2        | 2024-04-03T10:25:48: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                  PM2        | 2024-04-03T10:25:48: PM2 log: pid=3783 msg=process killed
                  /home/chris/.pm2/logs/mm-out.log last 75 lines:
                  /home/chris/.pm2/logs/Display-Drehen-out.log last 75 lines:
                  /home/chris/.pm2/logs/Display-Drehen-error.log last 75 lines:
                  /home/chris/.pm2/logs/mm-error.log last 75 lines:
                  0|mm       | npm ERR! code EJSONPARSE
                  0|mm       | npm ERR! JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
                  0|mm       | npm ERR! JSON.parse Failed to parse JSON data.
                  0|mm       | npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
                  0|mm       |
                  0|mm       | npm ERR! A complete log of this run can be found in: /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
                  Complete log:
                  0 verbose cli /usr/bin/node /usr/bin/npm
                  1 info using npm@10.5.0
                  2 info using node@v21.7.1
                  3 timing npm:load:whichnode Completed in 5ms
                  4 timing config:load:defaults Completed in 5ms
                  5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 1ms
                  6 timing config:load:builtin Completed in 2ms
                  7 timing config:load:cli Completed in 6ms
                  8 timing config:load:env Completed in 2ms
                  9 timing config:load:file:/home/chris/MagicMirror/.npmrc Completed in 5ms
                  10 timing config:load:project Completed in 7ms
                  11 timing config:load:file:/home/chris/.npmrc Completed in 1ms
                  12 timing config:load:user Completed in 1ms
                  13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
                  14 timing config:load:global Completed in 1ms
                  15 timing config:load:setEnvs Completed in 3ms
                  16 timing config:load Completed in 27ms
                  17 timing npm:load:configload Completed in 27ms
                  18 timing config:load:flatten Completed in 7ms
                  19 timing npm:load:mkdirpcache Completed in 0ms
                  20 timing npm:load:mkdirplogs Completed in 0ms
                  21 verbose title npm start
                  22 verbose argv "start"
                  23 timing npm:load:setTitle Completed in 2ms
                  24 timing npm:load:display Completed in 2ms
                  25 verbose logfile logs-max:10 dir:/home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-
                  26 verbose logfile /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
                  27 timing npm:load:logFile Completed in 23ms
                  28 timing npm:load:timers Completed in 0ms
                  29 timing npm:load:configScope Completed in 0ms
                  30 timing npm:load Completed in 107ms
                  31 silly logfile start cleaning logs, removing 2 files
                  32 timing command:run-script Completed in 21ms
                  33 timing command:start Completed in 36ms
                  34 verbose stack JSONParseError: Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
                  34 verbose stack     at PackageJson.fromJSON (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:162:24)
                  34 verbose stack     at PackageJson.load (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:156:17)
                  34 verbose stack     at async PackageJson.normalize (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:115:5)
                  34 verbose stack     at async RunScript.run (/usr/lib/node_modules/npm/lib/commands/run-script.js:72:27)
                  34 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli-entry.js:61:5)
                  35 verbose cwd /home/chris/MagicMirror
                  36 verbose Linux 6.1.21-v7l+
                  37 verbose node v21.7.1
                  38 verbose npm  v10.5.0
                  39 error code EJSONPARSE
                  40 error JSON.parse Invalid package.json: JSONParseError: Expected double-quoted property name in JSON at position 3351 (line 87 column 1) while parsing near "...moment\": \"^2.30.1\",\n<<<<<<< Updated upst..."
                  41 error JSON.parse Failed to parse JSON data.
                  41 error JSON.parse Note: package.json must be actual JSON, not just JavaScript.
                  42 verbose exit 1
                  43 timing npm Completed in 228ms
                  44 verbose code 1
                  45 error A complete log of this run can be found in: /home/chris/.npm/_logs/2024-04-03T08_25_30_215Z-debug-0.log
                  :anxious_face_with_sweat:
                  Cheers,
                  Chris.
                  Regards, Chris.
                    sdetweil @chrisfr1976
                    @chrisfr1976 can you post the few lines of package.json around line 87
                    did you use my upgrade script?
                    if so can u email me the file
                    ~/MagicMirror/installers/upgrade.log
                    using the same userid as on this post at gmail
                      In the beginning I’ve used the described update method here:
                      https://docs.magicmirror.builders/getting-started/upgrade-guide.html
                      So only git pull && npm run install-mm was used. But I’ve used the back-up script you’ve provided. Then I found also your update script. I’ve used it then, too. But same error. I’ll send the update.log via email :-)
                      Here the lines around line 87. I’ve marked it to show the position only:
                        // Loads a package.json at given path and JSON parses
                        static async load (path, opts = {}) {
                          const p = new PackageJson()
                          // Avoid try/catch if we aren't going to create
                          if (!opts.create) {
                            return p.load(path)
                      *87*
                          try {
                            return await p.load(path)
                          } catch (err) {
                            if (!err.message.startsWith('Could not read package.json')) {
                              throw err
                            return await p.create(path)
                      Chris.
                      Regards, Chris.
                        @chrisfr1976 hm…
                        package.json looks like this
