    MM failed after updating
    16 Posts 3 Posters 2.9k Views 3 Watching
    • 1 Offline
      1a2a3a
      Hi, after updating my MM, when i try to start i get this error.
      node_modules/.bin/electron: not found"
      what should i do?
        chrisfr1976 @sdetweil
        @sdetweil I was able to fix it. git reset --hard followed by npm run install-mm fixed the issue. I don’t know why but now everything is fine again. I’ll do a SD-card back-up now :-)
        Regards, Chris.
          sdetweil @1a2a3a
          @1a2a3a please tell me how you updated and what.platform you are on
          1 1 Reply Last reply Reply Quote 0
          • 1 Offline
            1a2a3a @sdetweil
            @sdetweil on pi 5. updated using your script. while attempting to google search for fixes, i seems to have broken more stuff. trying to rebuild again from scratch…using your script… to update again…
              sdetweil @1a2a3a
              @1a2a3a can you show me the ~/MagicMirror/installers/upgrade.log
              in the future ask for help first, vs apply random answers.
              you could have just tried installing the electon version.
              • 1 Offline
                1a2a3a @sdetweil
                @sdetweil i cant. i deleted the entire folder. just installed using your script. now transferring the modules folder from backup to the pi.
                thats what i did actually, installing the electron but it keep throwing error like npm ERR! signal sigint
                npm ERR! code E404
                  sdetweil @1a2a3a
                  @1a2a3a thanks. i needed to see the actual npm install output
                  use my backup/restore scripts
                  https://github.com/sdetweil/MagicMirror-backup-restore
                  • 1 Offline
                    1a2a3a @sdetweil
                    @sdetweil thanks. still in the midst of transferring.
                    why are you up so early? i recall you were some hours behind so when i posted this i figured i wouldnt get a response so soon hence my attempt of own answer.
                      sdetweil @1a2a3a
                      @1a2a3a i was on US west coast time for a couple months now back in central time. thanks for noticing…
                      • 1 Offline
                        1a2a3a @sdetweil
                        @sdetweil i see. anyway, my calendar, stocks and google photo are not loading. it says check logs for details – where can i find the logs again?
                        edit—
                        its odd. when i run npm start dev, everything is working fine, everything loads.
                        but when i run pm2 start MagicMirror - my cal, stocks and photos are not loading. am i suppose to let it sit there for awhile?
                          sdetweil @1a2a3a
                          @1a2a3a logs are output where the npm start is done.
                          pm2 captures them
                          do this
                          pm2 stop all
                          pm2 flush
                          wait 15 seconds
                          pm2 stop all
                          pm2 logs --lines=75
