    Need Help with magicmirror
    15 Posts 2 Posters 3.0k Views 2 Watching
    • W Offline
      WM1600
      I tried installing majic mirror pictureframe from Tomshardware.
      Purchsed a rasberry pi 4
      assembled updated and got the unit functioning.
      installed MagicMirror
      had it running.
      then installed the magicmirror module.
      had issued getting the generate_token.js to function,
      determined i needed to use the command generate_token_v2.js (I think)
      also updated
      npm: ‘10.5.2’,
      node: ‘20.12.1’,
      got the magic mirror to display a google album.
      then I tried to make the unit boot on start-up.
      will@raspberrypi:/media/will $ sudo npm install -g pm2
      /usr/local/bin/node: 1: Syntax error: “)” unexpected
      Then I went back tried to update MM
      Now magicmirror will not run.
      (I have copies of the terminal if that helps)
      any ideas on where to look to get help?
      remove MM and re-install?
      Thanks,
      Will
        sdetweil @WM1600
        @WM1600 ok then…
        hm… trying to figure out the best way to fix this
        the bad node install is hard to get out of.
        I think redoing the sd card is the cleanest
        use my backup script to save the MagicMirror setup.
        it’s three files plus any addon files made by modules, like the token file for photos
        one little directory.
        if you use github then it can save all that to a private repo u build on github.
        otherwise copy the folder off somewhere you can get it back
        make the new sd card,
        boot, don’t update during bootup
        install MagicMirror using my install script
        which will update node/npm too
        then restore your MagicMirror setup
          sdetweil @WM1600
          @WM1600 rename the folder
          cd ~/
          mv MagicMirror MagicMirror. old
          then run my install script
          see
          it will do all the setup install node and npm,
          sometimes the problem
          for install is so messed up, you have to refresh the sd card and then run my script
          the script will also setup pm2 to launch at boot if you say yes at the prompt
          if the install is successful you an copy the two json files for Google photos from the prior folder
          • W Offline
            WM1600 @sdetweil
            @sdetweil thank you,
            I have re-installed Magic Mirror and chose to disable screen save and to start magicmirror on boot-up.
            the install worked for magicmirror and and when I go to the magic mirror folder in terminal and type “npm run start”, magicmirror will start.
            when I turn the terminal off and boot it up, It comes up with a magicmirror boot screen, but then the terminal continues to the normal start-up.
            At this point, I can still go to terminal and type npm run start and run magicmirror
            Am I missing a step to transition fully into magicmirror?
              sdetweil @WM1600
              @WM1600 can you do this
              pm2 flush
              sudo reboot
              then
              pm2 logs --lines=50
              • W Offline
                WM1600 @sdetweil
                ok,
                I have done those.
                no change
                  sdetweil @WM1600
                  @WM1600 what is the output of the pm2 logs command? I need to see
                  • W Offline
                    WM1600 @sdetweil
                    the terminal looks like this
                    will@raspberrypi:~ $ pm2 logs --lines=50
                    I do not see it doing anything.
                    [pm2.jpg](Input file contains unsupported image format)
                    I tried to upload the PM2.log but it says I can only upload picture files.
                    so I changed pm2.log to pm2.jpg. dont know it that will work.
                      sdetweil @WM1600
                      @WM1600
                      ok, let’s do.
                      pm2 status to see what apps it is managing
                      • W Offline
                        WM1600 @sdetweil
                        when I type in pm2 status
                        I dont see anything
                        this is the terminal copied:
                        will@raspberrypi:~ $ pm2 status
                          sdetweil @WM1600
                          @WM1600 hmmm weird
                          run the fixuppm2 script from here
                          • W Offline
                            WM1600 @sdetweil
                            I ran the following in terminal
                            will@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
                            the log will be saved in /home/will/MagicMirror/installers/pm2_setup.log
                            I have seen “Syntax error: “)” unexpected” before but that is the first time I have seen it twice
                            here is the log file:
                            pm2 setup starting - Sun Apr 28 11:19:37 EDT 2024
                            using parameter bash
                            system is Linux raspberrypi 6.6.28+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.28-1+rpt1 (2024-04-22) aarch64 GNU/Linux
                            the os is Distributor ID: Debian Description: Debian GNU/Linux 12 (bookworm) Release: 12 Codename: bookworm
                            node version v20.12.1
                            force installing latest npm version via npm
                            npm version 10.5.2
                            pm2 installed
                            pm2 installed, but does not work, uninstalling
                            pm2 not installed, installing
                            get the pm2 platform specific startup command
                            startup command =
                            pm2 startup command done
                            configure the pm2 config file for MagicMirror
                            the user is not pi
                            change pm2_MagicMirror.json
                            now using this config file pm2_MagicMirror_new.json
                            start MagicMirror via pm2 now
                            save MagicMirror pm2 config now
                            pm2 setup completed - Sun Apr 28 11:19:39 EDT 2024
                            pm2 setup starting - Sun Apr 28 20:25:03 EDT 2024
                            npm version 10.5.2
                            pm2 installed
                            startup command =
                            the user is not pi
                            pm2 setup completed - Sun Apr 28 20:25:05 EDT 2024
                            it is saying the user is not pi, but this is on a rasberry pi
                              sdetweil @WM1600
                              @WM1600 yes, your username is will, not pi
                              can you do
                              uname -a
                              file $(which bash)
                              I think you have a hybrid system
                              64 bit kernel
                              32 bit runtime
                              and you have the wrong (64 bit) node installed
                              • W Offline
                                WM1600 @sdetweil
                                will@raspberrypi:~ $ uname -a
                                will@raspberrypi:~ $ file $(which bash)
                                /usr/bin/bash: ELF 64-bit LSB pie executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=198ac6b0cc01bf774c5746a36a6fd31dead9bda5, for GNU/Linux 3.7.0, stripped
                                  sdetweil @WM1600
                                  @WM1600 ok then…
                                  • W Offline
                                    WM1600
                                    Sam,
                                    wanted to get back with you and let you know that the re-install worked.
                                    Thank you very much for the help, I could not have done it with out you!
                                    Will
