Solved Need Help with magicmirror
I ran the following in terminal
will@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
the log will be saved in /home/will/MagicMirror/installers/pm2_setup.log
/usr/local/bin/node: 1: Syntax error: “)” unexpected
will@raspberrypi:~ $I have seen “Syntax error: “)” unexpected” before but that is the first time I have seen it twice
here is the log file:
pm2 setup starting - Sun Apr 28 11:19:37 EDT 2024
using parameter bash
system is Linux raspberrypi 6.6.28+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.28-1+rpt1 (2024-04-22) aarch64 GNU/Linux
the os is Distributor ID: Debian Description: Debian GNU/Linux 12 (bookworm) Release: 12 Codename: bookworm
node version v20.12.1
force installing latest npm version via npm
npm version 10.5.2
pm2 installed
pm2 installed, but does not work, uninstalling
pm2 not installed, installing
get the pm2 platform specific startup command
startup command =
pm2 startup command done
configure the pm2 config file for MagicMirror
the user is not pi
change pm2_MagicMirror.json
now using this config file pm2_MagicMirror_new.json
start MagicMirror via pm2 now
save MagicMirror pm2 config now
pm2 setup completed - Sun Apr 28 11:19:39 EDT 2024
pm2 setup starting - Sun Apr 28 20:25:03 EDT 2024
npm version 10.5.2
pm2 installed
startup command =
the user is not pi
pm2 setup completed - Sun Apr 28 20:25:05 EDT 2024it is saying the user is not pi, but this is on a rasberry pi
@WM1600 yes, your username is will, not pi
can you do
uname -a file $(which bash)
I think you have a hybrid system
64 bit kernel
32 bit runtimeand you have the wrong (64 bit) node installed
will@raspberrypi:~ $ uname -a
will@raspberrypi:~ $ file $(which bash)
/usr/bin/bash: ELF 64-bit LSB pie executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=198ac6b0cc01bf774c5746a36a6fd31dead9bda5, for GNU/Linux 3.7.0, stripped
will@raspberrypi:~ $ -
@WM1600 ok then…
hm… trying to figure out the best way to fix this
the bad node install is hard to get out of.
I think redoing the sd card is the cleanest
use my backup script to save the MagicMirror setup.
https://github.com/sdetweil/MagicMirror-backup-restoreit’s three files plus any addon files made by modules, like the token file for photos
one little directory.if you use github then it can save all that to a private repo u build on github.
otherwise copy the folder off somewhere you can get it back
make the new sd card,
boot, don’t update during bootup
install MagicMirror using my install script
which will update node/npm toothen restore your MagicMirror setup
Sam,
wanted to get back with you and let you know that the re-install worked.
Thank you very much for the help, I could not have done it with out you!
Will
