MMM-Navigate, Issues with KY-040 rotary encoder
15 Posts 2 Posters 1.4k Views 2 Watching
    stinkycol @sdetweil
    @sdetweil I used MMM-GPIO-Notifications as i was using this on my other build to use simple buttons to swap pages.
    On the latest run I still get the errors:
    These are the entries in the config.js:
    This is the npm output as i move the KY040:
      stinkycol @sdetweil
      @sdetweil sorry I don’t write understand how you figured that the last one was causing the issue and is this an issue with boot/firmware/config? Did this mean that I should replace the gpio in the MMM-Navigate module on config.js to the sudonyms?
      GPIOPins:[DT, CLK, SW]
      S 1 Reply Last reply Apr 26, 2024, 3:35 PM Reply Quote 0
      • S Online
        sdetweil @stinkycol
        @stinkycol I looked at the line numbers reported in the stack trace dump that came along w the write error
        I do not know what the solution is
        S 1 Reply Last reply Apr 26, 2024, 3:36 PM Reply Quote 0
          stinkycol @sdetweil
          @sdetweil OK thanks for trying
          S 1 Reply Last reply Apr 26, 2024, 3:40 PM Reply Quote 0
          • S Online
            sdetweil @stinkycol
            @stinkycol the gpio notifications module does the gpio connection differently
            2 / 2
